[GRASS-SVN] r68841 - grass-addons/grass7/raster/r.geomorphon
svn_grass at osgeo.org
Sun Jul 3 09:52:13 PDT 2016
Author: martinl
Date: 2016-07-03 09:52:13 -0700 (Sun, 03 Jul 2016)
New Revision: 68841
grass-addons/grass7/raster/r.geomorphon/main.c
g.geomorphon: use standardized option: dem -> elevation, option description/guisections uppercase
Modified: grass-addons/grass7/raster/r.geomorphon/main.c
--- grass-addons/grass7/raster/r.geomorphon/main.c 2016-07-03 15:56:29 UTC (rev 68840)
+++ grass-addons/grass7/raster/r.geomorphon/main.c 2016-07-03 16:52:13 UTC (rev 68841)
@@ -30,34 +30,34 @@
int main(int argc, char **argv)
IO rasters[] = { /* rasters stores output buffers */
- {"dem", YES, "Input dem", "input", UNKNOWN, -1, NULL}, /* WARNING: this one map is input */
- {"forms", NO, "Most common geomorphic forms", "patterns", CELL_TYPE,
+ {"elevation", YES, "Input dem", "input", UNKNOWN, -1, NULL}, /* WARNING: this one map is input */
+ {"forms", NO, "Most common geomorphic forms", "Patterns", CELL_TYPE,
-1, NULL},
- {"ternary", NO, "code of ternary patterns", "patterns", CELL_TYPE, -1,
+ {"ternary", NO, "Code of ternary patterns", "Patterns", CELL_TYPE, -1,
NULL},
- {"positive", NO, "code of binary positive patterns", "patterns",
+ {"positive", NO, "Code of binary positive patterns", "Patterns",
CELL_TYPE, -1, NULL},
- {"negative", NO, "code of binary negative patterns", "patterns",
+ {"negative", NO, "Code of binary negative patterns", "Patterns",
{"intensity", NO,
- "rasters containing mean relative elevation of the form", "geometry",
+ "Rasters containing mean relative elevation of the form", "Geometry",
FCELL_TYPE, -1, NULL},
{"exposition", NO,
- "rasters containing maximum difference between extend and central cell",
- "geometry", FCELL_TYPE, -1, NULL},
+ "Rasters containing maximum difference between extend and central cell",
+ "Geometry", FCELL_TYPE, -1, NULL},
{"range", NO,
- "rasters containing difference between max and min elevation of the form extend",
- {"variance", NO, "rasters containing variance of form boundary",
- {"elongation", NO, "rasters containing local elongation", "geometry",
+ "Rasters containing difference between max and min elevation of the form extend",
+ {"variance", NO, "Rasters containing variance of form boundary",
+ {"elongation", NO, "Rasters containing local elongation", "Geometry",
- {"azimuth", NO, "rasters containing local azimuth of the elongation",
- {"extend", NO, "rasters containing local extend (area) of the form",
- {"width", NO, "rasters containing local width of the form",
+ {"azimuth", NO, "Rasters containing local azimuth of the elongation",
+ {"extend", NO, "Rasters containing local extend (area) of the form",
+ {"width", NO, "Rasters containing local width of the form",
}; /* adding more maps change IOSIZE macro */
CATCOLORS ccolors[CNT] = { /* colors and cats for forms */
@@ -100,12 +100,13 @@
{ /* interface parameters */
module = G_define_module();
module->description =
- _("Calculate geomorphons (terrain forms)and associated geometry using machine vision approach");
- G_add_keyword("Geomorphons");
- G_add_keyword("Terrain patterns");
- G_add_keyword("Machine vision geomorphometry");
+ _("Calculates geomorphons (terrain forms) and associated geometry using machine vision approach.");
+ G_add_keyword(_("raster"));
+ G_add_keyword(_("geomorphons"));
+ G_add_keyword(_("terrain patterns"));
+ G_add_keyword(_("machine vision geomorphometry"));
- opt_input = G_define_standard_option(G_OPT_R_INPUT);
+ opt_input = G_define_standard_option(G_OPT_R_ELEV);
opt_input->key = rasters[0].name;
opt_input->required = rasters[0].required;
opt_input->description = _(rasters[0].description);
