[GRASS-SVN] r68852 - grass-addons/grass7/raster/r.geomorphon
svn_grass at osgeo.org
Mon Jul 4 04:25:26 PDT 2016
Author: neteler
Date: 2016-07-04 04:25:26 -0700 (Mon, 04 Jul 2016)
New Revision: 68852
grass-addons/grass7/raster/r.geomorphon/geom.c
grass-addons/grass7/raster/r.geomorphon/main.c
grass-addons/grass7/raster/r.geomorphon/memory.c
r.geomorphon: fixed unused variables; shadowed declaration to be fixed
Modified: grass-addons/grass7/raster/r.geomorphon/geom.c
--- grass-addons/grass7/raster/r.geomorphon/geom.c 2016-07-04 10:18:05 UTC (rev 68851)
+++ grass-addons/grass7/raster/r.geomorphon/geom.c 2016-07-04 11:25:26 UTC (rev 68852)
@@ -1,5 +1,5 @@
#include "local_proto.h"
-static double dirs[8] = { 0.7854, 0., 5.4978, 4.7124, 3.9270, 3.1416, 2.3562, 1.5708 }; /* radians */
+/* static double dirs[8] = { 0.7854, 0., 5.4978, 4.7124, 3.9270, 3.1416, 2.3562, 1.5708 };*/ /* radians */
static double sins[8] = { 0.7071067812, 0, -0.7071067812, -1, -0.7071067812, 0, 0.7071067812, 1 }; /* sinus */
static double coss[8] = { 0.7071067812, 1, 0.7071067812, 0, -0.7071067812, -1, -0.7071067812, 0 }; /* cosinus */
@@ -19,7 +19,6 @@
unsigned int code = 10000, tmp_code, rev_code = 10000, tmp_rev_code;
int power = 1;
int i, j, k;
- int res;
for (i = 0; i < 8; i++) {
pattern[i] = value % 3;
Modified: grass-addons/grass7/raster/r.geomorphon/main.c
--- grass-addons/grass7/raster/r.geomorphon/main.c 2016-07-04 10:18:05 UTC (rev 68851)
+++ grass-addons/grass7/raster/r.geomorphon/main.c 2016-07-04 11:25:26 UTC (rev 68852)
@@ -88,9 +88,9 @@
struct History history;
- int i, j, n;
+ int i;
int meters = 0, multires = 0, extended = 0; /* flags */
- int row, cur_row, col, radius;
+ int row, cur_row, col;
int pattern_size;
double max_resolution;
char prefix[20];
@@ -310,7 +310,6 @@
PATTERN *pattern;
PATTERN patterns[4];
void *pointer_buf;
- int formA, formB, formC;
double search_dist = search_distance;
double skip_dist = skip_distance;
double flat_dist = flat_distance;
@@ -487,7 +486,7 @@
if (opt_output[o_range]->answer)
write_contrast_colors(opt_output[o_range]->answer);
- G_done_msg("");
+ G_done_msg(" ");
exit(EXIT_SUCCESS);
} /* end of multiresolution */
Modified: grass-addons/grass7/raster/r.geomorphon/memory.c
--- grass-addons/grass7/raster/r.geomorphon/memory.c 2016-07-04 10:18:05 UTC (rev 68851)
+++ grass-addons/grass7/raster/r.geomorphon/memory.c 2016-07-04 11:25:26 UTC (rev 68852)
@@ -4,10 +4,8 @@
int row, col;
- int fd;
char *mapset;
struct Cell_head cellhd;
- int bufsize;
void *tmp_buf;
mapset = (char *)G_find_raster2(rast->elevname, "");
@@ -72,7 +70,7 @@
int i;
int col;
void *tmp_buf;
- FCELL *tmp_elev_buf, *slope_tmp, *aspect_tmp;
+ FCELL *tmp_elev_buf;
tmp_buf = Rast_allocate_buf(elevation.raster_type);
tmp_elev_buf = elevation.elev[0];
@@ -128,7 +126,7 @@
int write_contrast_colors(char *raster)
struct Colors colors;
- struct Categories cats;
+ /* struct Categories cats; */
FCOLORS fcolors[9] = { /* colors for positive openness */
{-2500, 0, 0, 50, NULL},
