[GRASS-SVN] r68857 - grass-addons/grass7/vector/v.civil
svn_grass at osgeo.org
Mon Jul 4 06:48:40 PDT 2016
Author: jfc
Date: 2016-07-04 06:48:40 -0700 (Mon, 04 Jul 2016)
New Revision: 68857
grass-addons/grass7/vector/v.civil/road_tables.py
grass-addons/grass7/vector/v.civil/v.road.py
v.road update rewrite_obj funtion
Modified: grass-addons/grass7/vector/v.civil/road_tables.py
--- grass-addons/grass7/vector/v.civil/road_tables.py 2016-07-04 12:53:22 UTC (rev 68856)
+++ grass-addons/grass7/vector/v.civil/road_tables.py 2016-07-04 13:48:40 UTC (rev 68857)
@@ -8,6 +8,8 @@
# from grass.pygrass.vector.table import Link
import time
import grass.script as grass
+import grass.lib.vector as libvect
+from grass.pygrass.errors import GrassError
from grass.pygrass.vector.geometry import Point
from grass.pygrass.vector import sql
@@ -465,15 +467,36 @@
"""Return
self.polygon.open('rw', self.layer, with_z=True)
+ cat = attrs[0]
- if isinstance(obj, Point):
- type_obj = 'points'
- else:
- type_obj = 'lines'
+ if obj.gtype == 1:
+ vtype = 'points'
+ elif obj.gtype == 2:
+ vtype = 'lines'
+ elif obj.gtype == 3:
+ vtype = 'boundary'
+ elif obj.gtype == 4:
+ vtype = 'centroid'
- obj_org = self.polygon.cat(attrs[0], type_obj, self.layer)[0]
- obj_org.x, obj_org.y, obj_org.z = obj.x, obj.y, obj.z
- self.polygon.rewrite(obj_org, attrs[0], attrs[1:])
+ line = self.polygon.cat(cat, vtype, self.layer)[0]
+ if self.polygon.table is not None and attrs:
+ self.polygon.table.update(key=line.cat, values=attrs[1:])
+ elif self.polygon.table is None and attrs:
+ print("Table for vector {name} does not exist, attributes not"
+ " loaded".format(name=self.name))
+ # libvect.Vect_cat_set(obj.c_cats, self.layer, line.cat)
+ result = libvect.Vect_rewrite_line(self.polygon.c_mapinfo,
+ line.id, obj.gtype,
+ obj.c_points,
+ line.c_cats)
+ if result == -1:
+ raise GrassError("Not able to write the vector feature.")
+ # return offset into file where the feature starts
+ obj.offset = result
self.polygon.table.conn.commit()
self.polygon.close()
Modified: grass-addons/grass7/vector/v.civil/v.road.py
--- grass-addons/grass7/vector/v.civil/v.road.py 2016-07-04 12:53:22 UTC (rev 68856)
+++ grass-addons/grass7/vector/v.civil/v.road.py 2016-07-04 13:48:40 UTC (rev 68857)
@@ -680,8 +680,7 @@
# if 'nnbathy' in tinraster:
# tin.nnbathy()
- else:
- sys.exit(0)
+ sys.exit(0)
################### Backup ##################
