[GRASS-SVN] r68873 - grass/trunk/raster3d/r3.to.rast/testsuite
svn_grass at osgeo.org
Wed Jul 6 14:12:24 PDT 2016
Author: wenzeslaus
Date: 2016-07-06 14:12:24 -0700 (Wed, 06 Jul 2016)
New Revision: 68873
Added:
grass/trunk/raster3d/r3.to.rast/testsuite/test_nulls.py
r3.to.rast: add test for number of null values in the 2D raster
Copied: grass/trunk/raster3d/r3.to.rast/testsuite/test_nulls.py (from rev 68864, grass/trunk/raster3d/r3.to.rast/testsuite/test_small_data.py)
--- grass/trunk/raster3d/r3.to.rast/testsuite/test_nulls.py (rev 0)
+++ grass/trunk/raster3d/r3.to.rast/testsuite/test_nulls.py 2016-07-06 21:12:24 UTC (rev 68873)
@@ -0,0 +1,166 @@
+#!/usr/bin/env python
+# MODULE: test_small_data
+# AUTHOR: Vaclav Petras
+# PURPOSE: Fast test of nulls values based on the small test
+# COPYRIGHT: (C) 2016 by Vaclav Petras and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.script import list_strings
+# copied from the small test
+# generated by
+# g.region n=12 s=9 e=21 w=18 t=8 b=4 res=1 res3=1 -p3
+# r3.mapcalc "x = rand(0,10)" seed=100 && r3.out.ascii x prec=0
+# added nulls in the way that each raster has two null cells
+# so we can easily test it for all rasters together
+INPUT = """\
+version: grass7
+order: nsbt
+north: 12
+south: 9
+east: 21
+west: 18
+top: 8
+bottom: 4
+rows: 3
+cols: 3
+levels: 4
+6 5 1
+0 * 5
+1 7 *
+8 2 *
+* 4 2
+8 5 6
+1 2 8
+1 5 *
+1 1 *
+1 8 3
+6 * *
+5 1 7
+# created from the above data above
+OUTPUTS = [
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+6 5 1
+0 * 5
+1 7 *
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+8 2 *
+* 4 2
+8 5 6
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+1 2 8
+1 5 *
+1 1 *
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+1 8 3
+6 * *
+5 1 7
+# basically copy of the class from the small test
+class TestR3ToRastNulls(TestCase):
+ # TODO: replace by unified handing of maps
+ # mixing class and object attributes
+ to_remove_3d = []
+ to_remove_2d = []
+ rast3d = 'r3_to_rast_test_nulls'
+ rast2d = 'r3_to_rast_test_nulls'
+ rast2d_ref = 'r3_to_rast_test_nulls_ref'
+ rast2d_refs = []
+ def setUp(self):
+ self.use_temp_region()
+ self.runModule('r3.in.ascii', input='-', stdin_=INPUT,
+ output=self.rast3d)
+ self.to_remove_3d.append(self.rast3d)
+ self.runModule('g.region', raster_3d=self.rast3d)
+ for i, data in enumerate(OUTPUTS):
+ rast = "%s_%d" % (self.rast2d_ref, i)
+ self.runModule('r.in.ascii', input='-', stdin_=data,
+ output=rast)
+ self.to_remove_2d.append(rast)
+ self.rast2d_refs.append(rast)
+ def tearDown(self):
+ if self.to_remove_3d:
+ self.runModule('g.remove', flags='f', type='raster_3d',
+ name=','.join(self.to_remove_3d), verbose=True)
+ if self.to_remove_2d:
+ self.runModule('g.remove', flags='f', type='raster',
+ name=','.join(self.to_remove_2d), verbose=True)
+ self.del_temp_region()
+ def test_b(self):
+ self.assertModule('r3.to.rast', input=self.rast3d,
+ output=self.rast2d)
+ rasts = list_strings('raster', mapset=".",
+ pattern="%s_*" % self.rast2d,
+ exclude="%s_*" % self.rast2d_ref)
+ self.assertEquals(len(rasts), 4,
+ msg="Wrong number of 2D rasters present"
+ " in the mapset")
+ ref_info = dict(cells=9)
+ # only this tests the presence of nulls
+ ref_univar = dict(cells=9, null_cells=2)
+ for rast in rasts:
+ self.assertRasterExists(rast)
+ # the following doesn't make much sense because we just listed them
+ self.assertRasterFitsInfo(raster=rast, reference=ref_info,
+ precision=0)
+ self.assertRasterFitsUnivar(raster=rast, reference=ref_univar,
+ precision=0)
+ # check the actual values
+ # TODO: this does not check the position of nulls
+ # (it ignores nulls)
+ for rast_ref, rast in zip(self.rast2d_refs, rasts):
+ self.assertRastersNoDifference(actual=rast,
+ reference=rast_ref,
+ precision=0.1)
+if __name__ == '__main__':
+ test()
