[GRASS-SVN] r68876 - in grass/trunk/raster3d/r3.to.rast: . testsuite
svn_grass at osgeo.org
Wed Jul 6 20:26:14 PDT 2016
Author: wenzeslaus
Date: 2016-07-06 20:26:13 -0700 (Wed, 06 Jul 2016)
New Revision: 68876
Added:
grass/trunk/raster3d/r3.to.rast/testsuite/test_a_b_coeff.py
grass/trunk/raster3d/r3.to.rast/main.c
r3.to.rast: add multiply and add coeff options
Modified: grass/trunk/raster3d/r3.to.rast/main.c
--- grass/trunk/raster3d/r3.to.rast/main.c 2016-07-06 21:58:36 UTC (rev 68875)
+++ grass/trunk/raster3d/r3.to.rast/main.c 2016-07-07 03:26:13 UTC (rev 68876)
@@ -27,6 +27,8 @@
typedef struct {
struct Option *input, *output;
struct Option *type;
+ struct Option *coeff_a;
+ struct Option *coeff_b;
struct Flag *mask;
struct Flag *res; /*If set, use the same resolution as the input map */
} paramType;
@@ -37,7 +39,8 @@
void fatal_error(void *map, int *fd, int depths, char *errorMsg); /*Simple Error message */
void set_params(); /*Fill the paramType structure */
void g3d_to_raster(void *map, RASTER3D_Region region, int *fd,
- int output_type); /*Write the raster */
+ int output_type, int use_coeffs, double coeff_a,
+ double coeff_b); /*Write the raster */
int open_output_map(const char *name, int res_type); /*opens the outputmap */
void close_output_map(int fd); /*close the map */
@@ -106,6 +109,20 @@
param.type = G_define_standard_option(G_OPT_R_TYPE);
param.type->required = NO;
+ param.coeff_a = G_define_option();
+ param.coeff_a->key = "multiply";
+ param.coeff_a->type = TYPE_DOUBLE;
+ param.coeff_a->required = NO;
+ param.coeff_a->label = _("Value to multiply the raster values with");
+ param.coeff_a->description = _("Coefficient a in the equation y = ax + b");
+ param.coeff_b = G_define_option();
+ param.coeff_b->key = "add";
+ param.coeff_b->type = TYPE_DOUBLE;
+ param.coeff_b->required = NO;
+ param.coeff_b->label = _("Value to add to the raster values");
+ param.coeff_b->description = _("Coefficient b in the equation y = ax + b");
param.mask = G_define_flag();
param.mask->key = 'm';
param.mask->description = _("Use 3D raster mask (if exists) with input map");
@@ -121,8 +138,11 @@
/* Write the slices to seperate raster maps ******************************** */
+/* coefficients are used only when needed, otherwise the original values
+ * is preserved as well as possible */
- int output_type)
+ double coeff_b)
CELL c1 = 0;
FCELL f1 = 0;
@@ -164,16 +184,24 @@
for (x = 0; x < cols; x++) {
if (typeIntern == FCELL_TYPE) {
Rast3d_get_value(map, x, y, z, &f1, typeIntern);
- if (Rast3d_is_null_value_num(&f1, FCELL_TYPE))
+ if (Rast3d_is_null_value_num(&f1, FCELL_TYPE)) {
Rast_set_null_value(ptr, 1, output_type);
- else
+ else {
+ if (use_coeffs)
+ f1 = coeff_a * f1 + coeff_b;
Rast_set_f_value(ptr, f1, output_type);
} else {
Rast3d_get_value(map, x, y, z, &d1, typeIntern);
- if (Rast3d_is_null_value_num(&d1, DCELL_TYPE))
+ if (Rast3d_is_null_value_num(&d1, DCELL_TYPE)) {
- else
+ else {
+ if (use_coeffs)
+ d1 = coeff_a * d1 + coeff_b;
Rast_set_d_value(ptr, d1, output_type);
ptr = G_incr_void_ptr(ptr, cell_size);
@@ -219,6 +247,9 @@
int *fd = NULL, output_type, cols, rows;
char *RasterFileName;
int overwrite = 0;
+ int use_coeffs = 0; /* bool */
+ double coeff_a = 1;
+ double coeff_b = 0;
/* Initialize GRASS */
G_gisinit(argv[0]);
@@ -243,6 +274,14 @@
Rast3d_fatal_error(_("3D raster map <%s> not found"),
param.input->answer);
+ /* coefficients to modify the map */
+ if (param.coeff_a->answer || param.coeff_b->answer)
+ use_coeffs = 1;
+ if (param.coeff_a->answer)
+ coeff_a = atof(param.coeff_a->answer);
+ if (param.coeff_b->answer)
+ coeff_b = atof(param.coeff_b->answer);
/*Set the defaults */
Rast3d_init_defaults();
@@ -313,7 +352,6 @@
output_type = Rast3d_file_type_map(map);
/*prepare the filehandler */
fd = (int *) G_malloc(region.depths * sizeof (int));
@@ -350,7 +388,7 @@
/*Create the Rastermaps */
- g3d_to_raster(map, region, fd, output_type);
+ g3d_to_raster(map, region, fd, output_type, use_coeffs, coeff_a, coeff_b);
/*Loop over all output maps! close */
Copied: grass/trunk/raster3d/r3.to.rast/testsuite/test_a_b_coeff.py (from rev 68864, grass/trunk/raster3d/r3.to.rast/testsuite/test_small_data.py)
--- grass/trunk/raster3d/r3.to.rast/testsuite/test_a_b_coeff.py (rev 0)
+++ grass/trunk/raster3d/r3.to.rast/testsuite/test_a_b_coeff.py 2016-07-07 03:26:13 UTC (rev 68876)
@@ -0,0 +1,160 @@
+#!/usr/bin/env python
+# MODULE: test_small_data
+# AUTHOR: Vaclav Petras
+# PURPOSE: Fast test using a small example
+# COPYRIGHT: (C) 2016 by Vaclav Petras and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.script import list_strings
+# generated by
+# g.region n=12 s=9 e=21 w=18 t=8 b=4 res=1 res3=1 -p3
+# r3.mapcalc "x = rand(0,10)" seed=100 && r3.out.ascii x prec=0
+INPUT = """\
+version: grass7
+order: nsbt
+north: 12
+south: 9
+east: 21
+west: 18
+top: 8
+bottom: 4
+rows: 3
+cols: 3
+levels: 4
+6 5 1
+0 7 5
+1 7 1
+8 2 1
+3 4 2
+8 5 6
+1 2 8
+1 5 5
+1 1 3
+1 8 3
+6 5 1
+5 1 7
+# created from the above and template from
+# r.mapcalc "x = rand(0,10)" seed=100 && r.out.ascii x prec=0
+OUTPUTS = [
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+12.5 10.5 2.5
+0.5 14.5 10.5
+2.5 14.5 2.5
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+16.5 4.5 2.5
+6.5 8.5 4.5
+16.5 10.5 12.5
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+2.5 4.5 16.5
+2.5 10.5 10.5
+2.5 2.5 6.5
+north: 12
+south: 9
+east: 21
+west: 18
+rows: 3
+cols: 3
+2.5 16.5 6.5
+12.5 10.5 2.5
+10.5 2.5 14.5
+class TestR3ToRast(TestCase):
+ # TODO: replace by unified handing of maps
+ # mixing class and object attributes
+ to_remove_3d = []
+ to_remove_2d = []
+ rast3d = 'r3_to_rast_test_a_b_coeff'
+ rast2d = 'r3_to_rast_test_a_b_coeff'
+ rast2d_ref = 'r3_to_rast_test_a_b_coeff_ref'
+ rast2d_refs = []
+ def setUp(self):
+ self.use_temp_region()
+ self.runModule('r3.in.ascii', input='-', stdin_=INPUT,
+ output=self.rast3d)
+ self.to_remove_3d.append(self.rast3d)
+ self.runModule('g.region', raster_3d=self.rast3d)
+ for i, data in enumerate(OUTPUTS):
+ rast = "%s_%d" % (self.rast2d_ref, i)
+ self.runModule('r.in.ascii', input='-', stdin_=data,
+ output=rast)
+ self.to_remove_2d.append(rast)
+ self.rast2d_refs.append(rast)
+ def tearDown(self):
+ if self.to_remove_3d:
+ self.runModule('g.remove', flags='f', type='raster_3d',
+ name=','.join(self.to_remove_3d), verbose=True)
+ if self.to_remove_2d:
+ self.runModule('g.remove', flags='f', type='raster',
+ name=','.join(self.to_remove_2d), verbose=True)
+ self.del_temp_region()
+ def test_a_b_coeff(self):
+ self.assertModule('r3.to.rast', input=self.rast3d,
+ output=self.rast2d, multiply=2, add=0.5)
+ rasts = list_strings('raster', mapset=".",
+ pattern="%s_*" % self.rast2d,
+ exclude="%s_*" % self.rast2d_ref)
+ self.assertEquals(len(rasts), 4,
+ msg="Wrong number of 2D rasters present"
+ " in the mapset")
+ ref_info = dict(cells=9)
+ ref_univar = dict(cells=9, null_cells=0)
+ for rast in rasts:
+ self.assertRasterExists(rast)
+ # the following doesn't make much sense because we just listed them
+ self.assertRasterFitsInfo(raster=rast, reference=ref_info,
+ precision=0)
+ self.assertRasterFitsUnivar(raster=rast, reference=ref_univar,
+ precision=0)
+ # check the actual values
+ for rast_ref, rast in zip(self.rast2d_refs, rasts):
+ self.assertRastersNoDifference(actual=rast,
+ reference=rast_ref,
+ precision=0.1)
+if __name__ == '__main__':
+ test()
