[GRASS-SVN] r68878 - in grass/trunk: imagery/i.aster.toar locale/po
svn_grass at osgeo.org
Thu Jul 7 01:11:38 PDT 2016
Author: neteler
Date: 2016-07-07 01:11:38 -0700 (Thu, 07 Jul 2016)
New Revision: 68878
grass/trunk/imagery/i.aster.toar/gain_aster.c
grass/trunk/imagery/i.aster.toar/main.c
grass/trunk/imagery/i.aster.toar/rad2ref_aster.c
grass/trunk/locale/po/grassmods_ar.po
grass/trunk/locale/po/grassmods_cs.po
grass/trunk/locale/po/grassmods_de.po
grass/trunk/locale/po/grassmods_el.po
grass/trunk/locale/po/grassmods_es.po
grass/trunk/locale/po/grassmods_fi.po
grass/trunk/locale/po/grassmods_fr.po
grass/trunk/locale/po/grassmods_it.po
grass/trunk/locale/po/grassmods_ja.po
grass/trunk/locale/po/grassmods_ko.po
grass/trunk/locale/po/grassmods_lv.po
grass/trunk/locale/po/grassmods_pl.po
grass/trunk/locale/po/grassmods_pt.po
grass/trunk/locale/po/grassmods_pt_br.po
grass/trunk/locale/po/grassmods_ro.po
grass/trunk/locale/po/grassmods_ru.po
grass/trunk/locale/po/grassmods_sl.po
grass/trunk/locale/po/grassmods_th.po
grass/trunk/locale/po/grassmods_tr.po
grass/trunk/locale/po/grassmods_vi.po
grass/trunk/locale/po/grassmods_zh.po
i.aster.toar: indent source code; avoid private PI definition; fix description line
Modified: grass/trunk/imagery/i.aster.toar/gain_aster.c
--- grass/trunk/imagery/i.aster.toar/gain_aster.c 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/imagery/i.aster.toar/gain_aster.c 2016-07-07 08:11:38 UTC (rev 68878)
@@ -14,139 +14,139 @@
/* HIGH GAIN */
if (gain_code == 0) {
- /* Band 1 */
- if (band_number == 0)
- result = 0.676;
- /* Band 2 */
- if (band_number == 1)
- result = 0.708;
- /* Band 3N */
- if (band_number == 2)
- result = 0.423;
- /* Band 3B */
- if (band_number == 3)
- result = 0.423;
- /* Band 4 */
- if (band_number == 4)
- result = 0.1087;
- /* Band 5 */
- if (band_number == 5)
- result = 0.0348;
- /* Band 6 */
- if (band_number == 6)
- result = 0.0313;
- /* Band 7 */
- if (band_number == 7)
- result = 0.0299;
- /* Band 8 */
- if (band_number == 8)
- result = 0.0209;
- /* Band 9 */
- if (band_number == 9)
- result = 0.0159;
+ /* Band 1 */
+ if (band_number == 0)
+ result = 0.676;
+ /* Band 2 */
+ if (band_number == 1)
+ result = 0.708;
+ /* Band 3N */
+ if (band_number == 2)
+ result = 0.423;
+ /* Band 3B */
+ if (band_number == 3)
+ result = 0.423;
+ /* Band 4 */
+ if (band_number == 4)
+ result = 0.1087;
+ /* Band 5 */
+ if (band_number == 5)
+ result = 0.0348;
+ /* Band 6 */
+ if (band_number == 6)
+ result = 0.0313;
+ /* Band 7 */
+ if (band_number == 7)
+ result = 0.0299;
+ /* Band 8 */
+ if (band_number == 8)
+ result = 0.0209;
+ /* Band 9 */
+ if (band_number == 9)
+ result = 0.0159;
/* NORMAL GAIN */
if (gain_code == 1) {
- /* Band 1 */
- result = 1.688;
- /* Band 2 */
- result = 1.415;
- /* Band 3N */
- result = 0.862;
- /* Band 3B */
- result = 0.862;
- /* Band 4 */
- result = 0.2174;
- /* Band 5 */
- result = 0.0696;
- /* Band 6 */
- result = 0.0625;
- /* Band 7 */
- result = 0.0597;
- /* Band 8 */
- result = 0.0417;
- /* Band 9 */
- result = 0.0318;
- /* Band 10 */
- if (band_number == 10)
- result = 0.006822;
- /* Band 11 */
- if (band_number == 11)
- result = 0.006780;
- /* Band 12 */
- if (band_number == 12)
- result = 0.006590;
- /* Band 13 */
- if (band_number == 13)
- result = 0.005693;
- /* Band 14 */
- if (band_number == 14)
- result = 0.005225;
+ /* Band 1 */
+ result = 1.688;
+ /* Band 2 */
+ result = 1.415;
+ /* Band 3N */
+ result = 0.862;
+ /* Band 3B */
+ result = 0.862;
+ /* Band 4 */
+ result = 0.2174;
+ /* Band 5 */
+ result = 0.0696;
+ /* Band 6 */
+ result = 0.0625;
+ /* Band 7 */
+ result = 0.0597;
+ /* Band 8 */
+ result = 0.0417;
+ /* Band 9 */
+ result = 0.0318;
+ /* Band 10 */
+ if (band_number == 10)
+ result = 0.006822;
+ /* Band 11 */
+ if (band_number == 11)
+ result = 0.006780;
+ /* Band 12 */
+ if (band_number == 12)
+ result = 0.006590;
+ /* Band 13 */
+ if (band_number == 13)
+ result = 0.005693;
+ /* Band 14 */
+ if (band_number == 14)
+ result = 0.005225;
/* LOW GAIN 1 */
if (gain_code == 2) {
- /* Band 1 */
- result = 2.25;
- /* Band 2 */
- result = 1.89;
- /* Band 3N */
- result = 1.15;
- /* Band 3B */
- result = 1.15;
- /* Band 4 */
- result = 0.290;
- /* Band 5 */
- result = 0.0925;
- /* Band 6 */
- result = 0.0830;
- /* Band 7 */
- result = 0.0795;
- /* Band 8 */
- result = 0.0556;
- /* Band 9 */
- result = 0.0424;
+ /* Band 1 */
+ result = 2.25;
+ /* Band 2 */
+ result = 1.89;
+ /* Band 3N */
+ result = 1.15;
+ /* Band 3B */
+ result = 1.15;
+ /* Band 4 */
+ result = 0.290;
+ /* Band 5 */
+ result = 0.0925;
+ /* Band 6 */
+ result = 0.0830;
+ /* Band 7 */
+ result = 0.0795;
+ /* Band 8 */
+ result = 0.0556;
+ /* Band 9 */
+ result = 0.0424;
/* LOW GAIN 2 */
if (gain_code == 3) {
- /* Band 4 */
- result = 0.290;
- /* Band 5 */
- result = 0.409;
- /* Band 6 */
- result = 0.390;
- /* Band 7 */
- result = 0.332;
- /* Band 8 */
- result = 0.245;
- /* Band 9 */
- result = 0.265;
+ /* Band 4 */
+ result = 0.290;
+ /* Band 5 */
+ result = 0.409;
+ /* Band 6 */
+ result = 0.390;
+ /* Band 7 */
+ result = 0.332;
+ /* Band 8 */
+ result = 0.245;
+ /* Band 9 */
+ result = 0.265;
return result;
Modified: grass/trunk/imagery/i.aster.toar/main.c
--- grass/trunk/imagery/i.aster.toar/main.c 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/imagery/i.aster.toar/main.c 2016-07-07 08:11:38 UTC (rev 68878)
@@ -45,12 +45,11 @@
#define PI M_PI
double rad2ref_aster(double radiance, double doy, double sun_elevation,
- double k_exo);
+ double k_exo);
int main(int argc, char *argv[])
- struct Cell_head cellhd; /*region+header info */
- char *mapset; /*mapset name */
+ struct Cell_head cellhd; /*region+header info */
int nrows, ncols;
int row, col;
struct GModule *module;
@@ -58,11 +57,11 @@
struct Option *input1, *input2;
struct Flag *flag0, *flag1, *flag2;
struct Flag *flag3, *flag4, *flag5;
- struct History history; /*metadata */
+ struct History history; /*metadata */
- char *name; /*input raster name */
- char *result; /*output raster name */
+ char *name; /*input raster name */
+ char *result; /*output raster name */
/*Prepare new names for output files */
char result0[GNAME_MAX], result1[GNAME_MAX];
@@ -78,6 +77,7 @@
int infd[MAXFILES];
int outfd[MAXFILES];
char **names, **ptr;
/* For some strange reason infd[0] cannot be used later */
/* So nfiles is initialized with nfiles = 1 */
int nfiles = 1;
@@ -86,8 +86,8 @@
void *inrast[MAXFILES];
DCELL *outrast[MAXFILES];
RASTER_MAP_TYPE in_data_type[MAXFILES];
- RASTER_MAP_TYPE out_data_type = DCELL_TYPE; /* 0=numbers 1=text */
- double gain[MAXFILES], offset[MAXFILES];
+ RASTER_MAP_TYPE out_data_type = DCELL_TYPE; /* 0=numbers 1=text */
+ double gain[MAXFILES]; /* , offset[MAXFILES]; */
double kexo[MAXFILES];
double doy, sun_elevation;
@@ -102,7 +102,7 @@
G_add_keyword(_("satellite"));
G_add_keyword(_("ASTER"));
module->description =
- _("Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN.\n");
+ _("Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN.");
/* Define the different options */
input = G_define_standard_option(G_OPT_R_INPUTS);
@@ -152,7 +152,7 @@
if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
+ exit(EXIT_FAILURE);
names = input->answers;
ptr = input->answers;
@@ -166,21 +166,22 @@
/*Prepare the output file names */
- sprintf(result0,"%s%s", result, ".1");
- sprintf(result1,"%s%s", result, ".2");
- sprintf(result2,"%s%s", result, ".3N");
- sprintf(result3,"%s%s", result, ".3B");
- sprintf(result4,"%s%s", result, ".4");
- sprintf(result5,"%s%s", result, ".5");
- sprintf(result6,"%s%s", result, ".6");
- sprintf(result7,"%s%s", result, ".7");
- sprintf(result8,"%s%s", result, ".8");
- sprintf(result9,"%s%s", result, ".9");
- sprintf(result10,"%s%s", result, ".10");
- sprintf(result11,"%s%s", result, ".11");
- sprintf(result12,"%s%s", result, ".12");
- sprintf(result13,"%s%s", result, ".13");
- sprintf(result14,"%s%s", result, ".14");
+ sprintf(result0, "%s%s", result, ".1");
+ sprintf(result1, "%s%s", result, ".2");
+ sprintf(result2, "%s%s", result, ".3N");
+ sprintf(result3, "%s%s", result, ".3B");
+ sprintf(result4, "%s%s", result, ".4");
+ sprintf(result5, "%s%s", result, ".5");
+ sprintf(result6, "%s%s", result, ".6");
+ sprintf(result7, "%s%s", result, ".7");
+ sprintf(result8, "%s%s", result, ".8");
+ sprintf(result9, "%s%s", result, ".9");
+ sprintf(result10, "%s%s", result, ".10");
+ sprintf(result11, "%s%s", result, ".11");
+ sprintf(result12, "%s%s", result, ".12");
+ sprintf(result13, "%s%s", result, ".13");
+ sprintf(result14, "%s%s", result, ".14");
/*Prepare radiance boundaries */
@@ -188,23 +189,23 @@
int gain_code = 1;
for (i = 0; i < MAXFILES; i++) {
- /*0 - High (Not Applicable for band 10-14: TIR) */
- /*1 - Normal */
- /*2 - Low 1(Not Applicable for band 10-14: TIR) */
- /*3 - Low 2(Not Applicable for Band 1-3N/B & 10-14) */
- if (flag1->answer && i <= 3)
- gain_code = 0;
- if (flag2->answer && i >= 4 && i <= 9)
- gain_code = 0;
- if (flag3->answer && i <= 3)
- gain_code = 2;
- if (flag4->answer && i >= 4 && i <= 9)
- gain_code = 2;
- if (flag5->answer && i >= 4 && i <= 9)
- gain_code = 3;
- gain[i] = gain_aster(i, gain_code);
- /* Reset to NORMAL GAIN */
- gain_code = 1;
+ /*0 - High (Not Applicable for band 10-14: TIR) */
+ /*1 - Normal */
+ /*2 - Low 1(Not Applicable for band 10-14: TIR) */
+ /*3 - Low 2(Not Applicable for Band 1-3N/B & 10-14) */
+ if (flag1->answer && i <= 3)
+ gain_code = 0;
+ if (flag2->answer && i >= 4 && i <= 9)
+ gain_code = 0;
+ if (flag3->answer && i <= 3)
+ gain_code = 2;
+ if (flag4->answer && i >= 4 && i <= 9)
+ gain_code = 2;
+ if (flag5->answer && i >= 4 && i <= 9)
+ gain_code = 3;
+ gain[i] = gain_aster(i, gain_code);
+ /* Reset to NORMAL GAIN */
+ gain_code = 1;
@@ -226,23 +227,23 @@
for (; *ptr != NULL; ptr++) {
- if (nfiles > MAXFILES)
- G_fatal_error(_("Too many input maps. Only %d allowed."),
- MAXFILES);
- name = *ptr;
- /* Allocate input buffer */
- in_data_type[nfiles-1] = Rast_map_type(name, "");
- /* For some strange reason infd[0] cannot be used later */
- /* So nfiles is initialized with nfiles = 1 */
- infd[nfiles] = Rast_open_old(name, "");
+ if (nfiles > MAXFILES)
+ G_fatal_error(_("Too many input maps. Only %d allowed."),
+ MAXFILES);
+ name = *ptr;
+ /* Allocate input buffer */
+ in_data_type[nfiles - 1] = Rast_map_type(name, "");
+ /* For some strange reason infd[0] cannot be used later */
+ /* So nfiles is initialized with nfiles = 1 */
+ infd[nfiles] = Rast_open_old(name, "");
- Rast_get_cellhd(name, "", &cellhd);
- inrast[nfiles-1] = Rast_allocate_buf(in_data_type[nfiles-1]);
- nfiles++;
+ Rast_get_cellhd(name, "", &cellhd);
+ inrast[nfiles - 1] = Rast_allocate_buf(in_data_type[nfiles - 1]);
+ nfiles++;
nfiles--;
- if (nfiles < MAXFILES)
- G_fatal_error(_("The input band number should be 15"));
+ if (nfiles < MAXFILES)
+ G_fatal_error(_("The input band number should be 15"));
/* Allocate output buffer, use input map data_type */
@@ -250,7 +251,7 @@
ncols = Rast_window_cols();
- outrast[i] = Rast_allocate_buf(out_data_type);
+ outrast[i] = Rast_allocate_buf(out_data_type);
outfd[1] = Rast_open_new(result0, 1);
outfd[2] = Rast_open_new(result1, 1);
@@ -273,46 +274,46 @@
DCELL d[MAXFILES];
for (row = 0; row < nrows; row++) {
- G_percent(row, nrows, 2);
- /* read input map */
- for (i = 1; i <= MAXFILES; i++)
- Rast_get_row(infd[i], inrast[i-1], row, in_data_type[i-1]);
+ G_percent(row, nrows, 2);
+ /* read input map */
+ for (i = 1; i <= MAXFILES; i++)
+ Rast_get_row(infd[i], inrast[i - 1], row, in_data_type[i - 1]);
- /*process the data */
- for (col = 0; col < ncols; col++) {
- for (i = 0; i < MAXFILES; i++) {
- switch (in_data_type[i]) {
- case CELL_TYPE:
- d[i] = (double)((CELL *) inrast[i])[col];
- break;
- case FCELL_TYPE:
- d[i] = (double)((FCELL *) inrast[i])[col];
- break;
- case DCELL_TYPE:
- d[i] = (double)((DCELL *) inrast[i])[col];
- break;
- /* if radiance mode or Thermal band */
- if (radiance || i >= 10) {
- dout[i] = gain[i] * (d[i] - 1.0);
- /* if reflectance default mode and Not Thermal Band */
- else {
- dout[i] =
- rad2ref_aster(dout[i], doy, sun_elevation, kexo[i]);
- outrast[i][col] = dout[i];
- Rast_put_row(outfd[i], outrast[i-1], out_data_type);
+ /*process the data */
+ for (col = 0; col < ncols; col++) {
+ for (i = 0; i < MAXFILES; i++) {
+ switch (in_data_type[i]) {
+ case CELL_TYPE:
+ d[i] = (double)((CELL *) inrast[i])[col];
+ break;
+ case FCELL_TYPE:
+ d[i] = (double)((FCELL *) inrast[i])[col];
+ break;
+ case DCELL_TYPE:
+ d[i] = (double)((DCELL *) inrast[i])[col];
+ break;
+ /* if radiance mode or Thermal band */
+ if (radiance || i >= 10) {
+ dout[i] = gain[i] * (d[i] - 1.0);
+ /* if reflectance default mode and Not Thermal Band */
+ else {
+ dout[i] =
+ rad2ref_aster(dout[i], doy, sun_elevation, kexo[i]);
+ outrast[i][col] = dout[i];
+ Rast_put_row(outfd[i], outrast[i - 1], out_data_type);
for (i = 1; i <= MAXFILES; i++) {
- G_free(inrast[i-1]);
- Rast_close(infd[i]);
- G_free(outrast[i-1]);
- Rast_close(outfd[i]);
+ G_free(inrast[i - 1]);
+ Rast_close(infd[i]);
+ G_free(outrast[i - 1]);
+ Rast_close(outfd[i]);
exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.aster.toar/rad2ref_aster.c
--- grass/trunk/imagery/i.aster.toar/rad2ref_aster.c 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/imagery/i.aster.toar/rad2ref_aster.c 2016-07-07 08:11:38 UTC (rev 68878)
@@ -1,18 +1,19 @@
-#include<stdio.h>
-#include<math.h>
-#include<stdlib.h>
+#include <stdio.h>
+#include <math.h>
+#include <stdlib.h>
+#include <grass/gis.h>
-#define PI 3.1415926
+#define PI M_PI
/* Conversion of Radiance to Reflectance for ASTER */
- double k_exo)
+ double k_exo)
double result, ds;
ds = (1 + 0.01672 * sin(2 * PI * (doy - 93.5) / 365));
result =
- (radiance /
- ((cos((90 - sun_elevation) * PI / 180) / (PI * ds * ds)) * k_exo));
+ (radiance /
+ ((cos((90 - sun_elevation) * PI / 180) / (PI * ds * ds)) * k_exo));
return result;
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_ar.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42248,7 +42248,7 @@
#: ../imagery/i.aster.toar/main.c:105
msgid ""
"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
#: ../imagery/i.aster.toar/main.c:109
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_cs.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42804,7 +42804,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_de.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42927,7 +42927,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_el.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -40593,7 +40593,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_es.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -43028,7 +43028,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_fi.po
--- grass/trunk/locale/po/grassmods_fi.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_fi.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -38949,7 +38949,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_fr.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -44966,7 +44966,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_it.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42103,7 +42103,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_ja.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42115,7 +42115,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_ko.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -40818,7 +40818,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_lv.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42160,7 +42160,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_pl.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42168,7 +42168,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt.po
--- grass/trunk/locale/po/grassmods_pt.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_pt.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -43382,7 +43382,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_pt_br.po
--- grass/trunk/locale/po/grassmods_pt_br.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_pt_br.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -43305,7 +43305,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ro.po
--- grass/trunk/locale/po/grassmods_ro.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_ro.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -39697,7 +39697,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_ru.po
--- grass/trunk/locale/po/grassmods_ru.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_ru.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42893,7 +42893,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_sl.po
--- grass/trunk/locale/po/grassmods_sl.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_sl.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42544,7 +42544,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_th.po
--- grass/trunk/locale/po/grassmods_th.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_th.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42376,7 +42376,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_tr.po
--- grass/trunk/locale/po/grassmods_tr.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_tr.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -41566,7 +41566,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_vi.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42891,7 +42891,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po 2016-07-07 05:33:07 UTC (rev 68877)
+++ grass/trunk/locale/po/grassmods_zh.po 2016-07-07 08:11:38 UTC (rev 68878)
@@ -42427,7 +42427,7 @@
msgid ""
-"from ASTER DN.\n"
+"from ASTER DN."
msgstr ""
