[GRASS-SVN] r68897 - grass-addons/grass7/raster/r.exdet
Sat Jul 9 05:00:35 PDT 2016
Author: pvanbosgeo
Date: 2016-07-09 05:00:35 -0700 (Sat, 09 Jul 2016)
New Revision: 68897
   grass-addons/grass7/raster/r.exdet/r.exdet.html
fix html
Modified: grass-addons/grass7/raster/r.exdet/r.exdet.html
--- grass-addons/grass7/raster/r.exdet/r.exdet.html	2016-07-08 15:38:03 UTC (rev 68896)
+++ grass-addons/grass7/raster/r.exdet/r.exdet.html	2016-07-09 12:00:35 UTC (rev 68897)
@@ -1,6 +1,6 @@
 <h2>DESCRIPTION</h2>
-<p>Correlative species distribution models (SDMs) often involve some
+Correlative species distribution models (SDMs) often involve some
 degree of projection into conditions non-analogous to those under
 which it has been calibrated. This projection into areas with novel
 environmental condtions is risky as it may be ecologically and
@@ -49,9 +49,9 @@
 example 1 below), or another region (e.g., when comparing conditions
 in one country with those in another country; see example 2 below).
 In the second case, the projected data can be defined by raster
-layers covering a different region. One can also use a <a href=
-"http://grass.osgeo.org/grass64/manuals/g.region.html">region</a> to
-define the projected area (see example 3 below).
+layers covering a different region. One can also use a
+<a href="http://grass.osgeo.org/grass64/manuals/g.region.html">region</a>
+to define the projected area (see example 3 below).
 <h2>EXAMPLES</h2>
@@ -61,7 +61,7 @@
 <h3>Example 2</h3>
-<p>You can download a sample data set from <a href=
+You can download a sample data set from <a href=
 "http://www.climond.org/ExDet.aspx">http://www.climond.org/ExDet</a>.
 The sample data contains 4 clipped Bioclim variable layers for
 Australia and South Africa sourced from the CliMond dataset. In this
@@ -80,7 +80,7 @@
 <h2>CITATION</h2>
-<p>When using this tool, please use the citation to the original paper describing the method in your publications or other derived products:
+When using this tool, please use the citation to the original paper describing the method in your publications or other derived products:
 <ul><li>Mesgaran, M.B., Cousens, R.D. and Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity & Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.</li></ul>
@@ -91,8 +91,10 @@
 <h2>REFERENCES</h2>
-<p>[1] Mesgaran, M.B., Cousens, R.D. and Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity &  Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.
+[1] Mesgaran, M.B., Cousens, R.D. and Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity &  Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.
 <p>[2] ExDet: An stand alone extrapolation detection tool for the modelling of species distributions. URL: <a href="http://www.climond.org/ExDet.aspx">http://www.climond.org/ExDet.aspx</a>
 <p>[3] Elith, J., Kearney, M. and Phillips, S. 2010. The art of modelling range-shifting species. Methods in Ecology and Evolution 1:330-342.
 <h2>SEE ALSO</h2>
