[GRASS-SVN] r68906 - grass/branches/releasebranch_7_2/gui/wxpython/modules
svn_grass at osgeo.org
Sat Jul 9 05:48:41 PDT 2016
Author: martinl
Date: 2016-07-09 05:48:41 -0700 (Sat, 09 Jul 2016)
New Revision: 68906
grass/branches/releasebranch_7_2/gui/wxpython/modules/histogram.py
d.histogram launched from map display toolbar doesn't work (fixes #2899) (merge r68905 from trunk)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/modules/histogram.py
--- grass/branches/releasebranch_7_2/gui/wxpython/modules/histogram.py 2016-07-09 12:46:26 UTC (rev 68905)
+++ grass/branches/releasebranch_7_2/gui/wxpython/modules/histogram.py 2016-07-09 12:48:41 UTC (rev 68906)
@@ -60,6 +60,7 @@
self.resize = False # indicates whether or not a resize event has taken place
self.dragimg = None # initialize variable for map panning
self.pen = None # pen for drawing zoom boxes, etc.
+ self._oldfont = self._oldencoding = None
# Event bindings
@@ -72,7 +73,7 @@
# Render output objects
self.mapfile = None # image file to be rendered
- self.img = "" # wx.Image object (self.mapfile)
+ self.img = None # wx.Image object (self.mapfile)
self.imagedict = {} # images and their PseudoDC ID's for painting and dragging
@@ -223,28 +224,32 @@
Debug.msg(
2, "BufferedWindow.UpdateHist(%s): render=%s" %
(img, self.render))
- oldfont = ""
- oldencoding = ""
+ if not self.render:
+ return
+ # render new map images
+ # set default font and encoding environmental variables
+ if "GRASS_FONT" in os.environ:
+ self._oldfont = os.environ["GRASS_FONT"]
+ if self.parent.font:
+ os.environ["GRASS_FONT"] = self.parent.font
+ if "GRASS_ENCODING" in os.environ:
+ self._oldencoding = os.environ["GRASS_ENCODING"]
+ if self.parent.encoding is not None and self.parent.encoding != "ISO-8859-1":
+ os.environ[GRASS_ENCODING] = self.parent.encoding
- if self.render:
- # render new map images
- # set default font and encoding environmental variables
- if "GRASS_FONT" in os.environ:
- oldfont = os.environ["GRASS_FONT"]
- if self.parent.font != "":
- os.environ["GRASS_FONT"] = self.parent.font
- if "GRASS_ENCODING" in os.environ:
- oldencoding = os.environ["GRASS_ENCODING"]
- if self.parent.encoding is not None and self.parent.encoding != "ISO-8859-1":
- os.environ[GRASS_ENCODING] = self.parent.encoding
+ # using active comp region
+ self.Map.GetRegion(update=True)
- # using active comp region
- self.Map.GetRegion(update=True)
+ self.Map.width, self.Map.height = self.GetClientSize()
+ self.mapfile = self.Map.Render(force=self.render)
+ self.Map.GetRenderMgr().renderDone.connect(self.UpdateHistDone)
- self.Map.width, self.Map.height = self.GetClientSize()
- self.mapfile = self.Map.Render(force=self.render)
- self.img = self.GetImage()
- self.resize = False
+ def UpdateHistDone(self):
+ """Histogram image generated, finish rendering."""
+ self.img = self.GetImage()
+ self.resize = False
if not self.img:
return
@@ -261,17 +266,16 @@
self.resize = False
# update statusbar
- # Debug.msg (3, "BufferedWindow.UpdateHist(%s): region=%s" % self.Map.region)
self.Map.SetRegion()
self.parent.statusbar.SetStatusText(
"Image/Raster map <%s>" %
self.parent.mapname)
- if oldfont != "":
- os.environ["GRASS_FONT"] = oldfont
- if oldencoding != "":
- os.environ["GRASS_ENCODING"] = oldencoding
+ if self._oldfont:
+ os.environ["GRASS_FONT"] = self._oldfont
+ if self._oldencoding:
+ os.environ["GRASS_ENCODING"] = self._oldencoding
def EraseMap(self):
"""Erase the map display
