[GRASS-SVN] r68920 - grass/branches/releasebranch_7_2/lib/python/script
svn_grass at osgeo.org
Sat Jul 9 12:51:02 PDT 2016
Author: wenzeslaus
Date: 2016-07-09 12:51:01 -0700 (Sat, 09 Jul 2016)
New Revision: 68920
grass/branches/releasebranch_7_2/lib/python/script/raster3d.py
pythonlib: apply r60662 (stdin), r61388 (seed) and r61428 (env) to mapcalc3d (backport r68727)
Modified: grass/branches/releasebranch_7_2/lib/python/script/raster3d.py
--- grass/branches/releasebranch_7_2/lib/python/script/raster3d.py 2016-07-09 19:43:59 UTC (rev 68919)
+++ grass/branches/releasebranch_7_2/lib/python/script/raster3d.py 2016-07-09 19:51:01 UTC (rev 68920)
@@ -9,7 +9,7 @@
grass.raster3d_info(map)
-(C) 2008-2009 by the GRASS Development Team
+(C) 2008-2016 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
for details.
@@ -65,22 +65,28 @@
return kv
-def mapcalc3d(exp, quiet=False, verbose=False, overwrite=False, **kwargs):
+def mapcalc3d(exp, quiet=False, verbose=False, overwrite=False,
+ seed=None, env=None, **kwargs):
"""Interface to r3.mapcalc.
:param str exp: expression
:param bool quiet: True to run quietly (<tt>--q</tt>)
:param bool verbose: True to run verbosely (<tt>--v</tt>)
:param bool overwrite: True to enable overwriting the output (<tt>--o</tt>)
+ :param seed: an integer used to seed the random-number generator for the
+ rand() function, or 'auto' to generate a random seed
+ :param dict env: dictionary of environment variables for child process
:param kwargs:
+ if seed == 'auto':
+ seed = hash((os.getpid(), time.time())) % (2**32)
t = string.Template(exp)
e = t.substitute(**kwargs)
try:
- run_command('r3.mapcalc', expression=e,
- quiet=quiet,
- verbose=verbose,
- overwrite=overwrite)
+ write_command('r3.mapcalc', file='-', stdin=e, env=env, seed=seed,
+ quiet=quiet, verbose=verbose, overwrite=overwrite)
except CalledModuleError:
fatal(_("An error occurred while running r3.mapcalc"))
