[GRASS-SVN] r68925 - grass/branches/releasebranch_7_2/gui/wxpython/gui_core
svn_grass at osgeo.org
Sat Jul 9 16:57:27 PDT 2016
Author: annakrat
Date: 2016-07-09 16:57:27 -0700 (Sat, 09 Jul 2016)
New Revision: 68925
grass/branches/releasebranch_7_2/gui/wxpython/gui_core/forms.py
wxGUI: fix escape button to close dialogs and fix keyboard shortcuts on Mac, see #797 (merged from trunk, r68754)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/gui_core/forms.py
--- grass/branches/releasebranch_7_2/gui/wxpython/gui_core/forms.py 2016-07-09 23:40:26 UTC (rev 68924)
+++ grass/branches/releasebranch_7_2/gui/wxpython/gui_core/forms.py 2016-07-09 23:57:27 UTC (rev 68925)
@@ -550,7 +550,11 @@
# buttons
btnsizer = wx.BoxSizer(orient=wx.HORIZONTAL)
# cancel
- self.btn_cancel = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
+ if sys.platform == 'darwin':
+ # stock id automatically adds ctrl-c shortcut to close dialog
+ self.btn_cancel = wx.Button(parent=self.panel, label=_("Close"))
+ else:
+ self.btn_cancel = wx.Button(parent=self.panel, id=wx.ID_CLOSE)
self.btn_cancel.SetToolTipString(
_("Close this window without executing the command (Ctrl+Q)"))
btnsizer.Add(
@@ -562,7 +566,7 @@
# bind closing to ESC and CTRL+Q
self.Bind(wx.EVT_MENU, self.OnCancel, id=wx.ID_CLOSE)
accelTableList = [(wx.ACCEL_NORMAL, wx.WXK_ESCAPE, wx.ID_CLOSE)]
- accelTableList = [(wx.ACCEL_CTRL, ord('Q'), wx.ID_CLOSE)]
+ accelTableList.append((wx.ACCEL_CTRL, ord('Q'), wx.ID_CLOSE))
# TODO: bind Ctrl-t for tile windows here (trac #2004)
if self.get_dcmd is not None: # A callback has been set up
@@ -596,7 +600,11 @@
accelTableList.append((wx.ACCEL_CTRL, ord('R'), wx.ID_OK))
# copy
- self.btn_clipboard = wx.Button(parent=self.panel, id=wx.ID_COPY)
+ # stock id automatically adds ctrl-c shortcut to copy command
+ self.btn_clipboard = wx.Button(parent=self.panel, label=_("Copy"))
+ else:
+ self.btn_clipboard = wx.Button(parent=self.panel, id=wx.ID_COPY)
self.btn_clipboard.SetToolTipString(
_("Copy the current command string to the clipboard"))
btnsizer.Add(item=self.btn_clipboard, proportion=0,
