[GRASS-SVN] r68952 - sandbox/bo/i.segment.gsoc2016/i.segment
Wed Jul 13 13:47:27 PDT 2016
Author: hao2309
Date: 2016-07-13 13:47:26 -0700 (Wed, 13 Jul 2016)
New Revision: 68952
   sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h
   sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
   sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c
   sandbox/bo/i.segment.gsoc2016/i.segment/region_growing.c
added merge smaller region function
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h
--- sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h	2016-07-12 19:29:37 UTC (rev 68951)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/iseg.h	2016-07-13 20:47:26 UTC (rev 68952)
@@ -150,7 +150,7 @@
 int rclist_drop(struct rclist *, struct rc *);
 void rclist_destroy(struct rclist *);
 /* write_output.c */
 int write_output(struct globals *);
 int close_files(struct globals *);
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-07-12 19:29:37 UTC (rev 68951)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-07-13 20:47:26 UTC (rev 68952)
@@ -16,6 +16,18 @@
 #define INCR 1024
+/* extern functions */
+extern int merge_regions(struct ngbr_stats *, struct reg_stats *, /* Ri */
+                         struct ngbr_stats *, struct reg_stats *, /* Rk */
+			 int,
+			 struct globals *);
+extern int set_candidate_flag(struct ngbr_stats *, int , struct globals *);
+extern int find_best_neighbor(struct ngbr_stats *, struct reg_stats *,
+			      struct NB_TREE *, struct ngbr_stats *,
+			      struct reg_stats *, double *, int,
 /* standard gauss funtion:
  * a * exp(-(x - m)^2 / (2 * stddev^2)
  * a is not needed because the sum of weights is calculated for each
@@ -36,11 +48,11 @@
 int clump(struct globals *globals)
-    register int row, col,nin,diag;
+    register int row, col,nin;
     register int i, n;
     /* input */
     DCELL **prev_in, **cur_in, **temp_in;
-    int bcol;
+    int bcol, diag;
     double threshold,thresh2;
 	struct ngbr_stats Rin, Rcur, Rabove, Rleft, Rdiag;
     /* output */
@@ -388,6 +400,137 @@
     return TRUE;
+int merge_small(struct globals *globals){
+	register int row, col;
+    register int i, n;
+	double alpha2, Ri_similarity;
+	int n_merges;
+	struct ngbr_stats Ri,
+                      Rk,
+	              Rk_bestn,         /* Rk's best neighbor */
+		      *next;
+	struct NB_TREE *Ri_ngbrs, *Rk_ngbrs;
+	struct reg_stats Ri_rs, Rk_rs, Rk_bestn_rs;
+	int Ri_nn, Rk_nn; /* number of neighbors for Ri/Rk */
+	/* init neighbor stats */
+    Ri.mean = G_malloc(globals->datasize);
+    Rk.mean = G_malloc(globals->datasize);
+    Rk_bestn.mean = G_malloc(globals->datasize);
+    Ri_ngbrs = nbtree_create(globals->nbands, globals->datasize);
+    Rk_ngbrs = nbtree_create(globals->nbands, globals->datasize);
+	/* init region stats */
+    Ri_rs.mean = G_malloc(globals->datasize);
+    Ri_rs.sum = G_malloc(globals->datasize);
+    Rk_rs.mean = G_malloc(globals->datasize);
+    Rk_rs.sum = G_malloc(globals->datasize);
+    Rk_bestn_rs.mean = G_malloc(globals->datasize);
+    Rk_bestn_rs.sum = G_malloc(globals->datasize);
+    /* final pass, ignore threshold and force a merge for small segments with their best neighbor */
+    if (globals->min_segment_size > 1) {
+	G_message(_("Merging segments smaller than %d cells..."), globals->min_segment_size);
+	alpha2 = globals->alpha * globals->alpha;
+	flag_clear_all(globals->candidate_flag);
+	n_merges = 0;
+	globals->candidate_count = 0;
+	/* Set candidate flag to true/1 for all non-NULL cells */
+	for (row = globals->row_min; row < globals->row_max; row++) {
+	    for (col = globals->col_min; col < globals->col_max; col++) {
+		if (!(FLAG_GET(globals->null_flag, row, col))) {
+		    FLAG_SET(globals->candidate_flag, row, col);
+		    globals->candidate_count++;
+	G_debug(4, "Starting to process %ld candidate cells",
+		globals->candidate_count);
+	/* process candidate cells */
+	G_percent_reset();
+	    G_percent(row - globals->row_min,
+	              globals->row_max - globals->row_min, 4);
+		int do_merge = 1;
+		if (!(FLAG_GET(globals->candidate_flag, row, col)))
+		    continue;
+		Ri.row = row;
+		Ri.col = col;
+		/* get segment id */
+		Segment_get(&globals->rid_seg, (void *) &Ri.id, row, col);
+		if (Ri.id < 0)
+		    continue;
+		Ri_rs.id = Ri.id;
+		/* get segment size */
+		fetch_reg_stats(Ri.row, Ri.col, &Ri_rs, globals);
+		memcpy(Ri.mean, Ri_rs.mean, globals->datasize);
+		Ri.count = Ri_rs.count;
+		if (Ri.count >= globals->min_segment_size) {
+		    set_candidate_flag(&Ri, FALSE, globals);
+		    do_merge = 0;
+		while (do_merge) {
+		    do_merge = 0;
+		    /* merge all smaller than min size */
+		    if (Ri.count < globals->min_segment_size)
+			do_merge = 1;
+		    Ri_nn = 0;
+		    Ri_similarity = 2;
+		    Rk.id = 0;
+		    if (do_merge) {
+			/* find Ri's best neighbor, clear candidate flag */
+			Ri_nn = find_best_neighbor(&Ri, &Ri_rs, Ri_ngbrs,
+						   &Rk, &Rk_rs,
+						   &Ri_similarity, 1,
+						   globals);
+		    do_merge = 0;
+		    if (Rk.id != 0) {
+			/* merge Ri with Rk */
+			/* do not clear candidate flag for Rk */
+			merge_regions(&Ri, &Ri_rs, &Rk, &Rk_rs, 0, globals);
+			n_merges++;
+			    do_merge = 1;
+	G_percent(1, 1, 1);
+	return TRUE;
 int mean_shift(struct globals *globals)
     int row, col, t, n1, n2;
@@ -540,8 +683,6 @@
 		if (diff2 > alpha2)
 		    n_changes++;
-		// G_message(_("row: %d, col: %d, diff2 is: %f"),row,col,diff2);
 	    }/* end col iteration */
 	}/* end row iteration */
     }/* end while iteration */
@@ -550,14 +691,16 @@
     else
 	G_message(_("Mean shift converged after %d iterations"), t);
+	/* part 2 clustering the similar pixel to segment ID */
 	if (clump(globals) != TRUE)
 	G_fatal_error(_("Error in clustering segments"));
-    *         Part 3 identify connected components         *
-    *    Merge small super-pixel to bigger super-pixels    *
+	/* part 3 Merge small super-pixel to bigger super-pixels  */
+	if (merge_small(globals) != TRUE)
+	G_fatal_error(_("Error in Merging smaller segments"));
     return TRUE;
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c	2016-07-12 19:29:37 UTC (rev 68951)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/parse_args.c	2016-07-13 20:47:26 UTC (rev 68952)
@@ -58,7 +58,7 @@
     ms_suffix->required = NO;
     ms_suffix->answer = "_ms";
     ms_suffix->description = _("If also output the intermediam shifted-value band");
-    ms_spatial_bandwidth->guisection = _("MS_Settings");
+    ms_suffix->guisection = _("MS_Settings");
 	ms_range_bandwidth = G_define_option();
     ms_range_bandwidth->key = "ms_range_bandwidth";
@@ -89,7 +89,6 @@
     min_segment_size->label = _("Minimum number of cells in a segment");
     min_segment_size->description =
 	_("The final step will merge small segments with their best neighbor");
-    min_segment_size->guisection = _("RG_Settings");
 #ifdef _OR_SHAPE_
     radio_weight = G_define_option();
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/region_growing.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/region_growing.c	2016-07-12 19:29:37 UTC (rev 68951)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/region_growing.c	2016-07-13 20:47:26 UTC (rev 68952)
@@ -26,7 +26,7 @@
 #define MIN(a,b) ( ((a) < (b)) ? (a) : (b) )
 /* internal functions */
-static int merge_regions(struct ngbr_stats *, struct reg_stats *, /* Ri */
+int merge_regions(struct ngbr_stats *, struct reg_stats *, /* Ri */
 			 int,
 			 struct globals *);
@@ -37,8 +37,8 @@
 			    struct ngbr_stats *,    /* Ri's best neighbor */
 			    struct reg_stats *,
 		            struct globals *);
-static int set_candidate_flag(struct ngbr_stats *, int , struct globals *);
-static int find_best_neighbor(struct ngbr_stats *, struct reg_stats *,
+int set_candidate_flag(struct ngbr_stats *, int , struct globals *);
+int find_best_neighbor(struct ngbr_stats *, struct reg_stats *,
 			      struct globals *);
@@ -570,7 +570,7 @@
-static int find_best_neighbor(struct ngbr_stats *Ri,
+int find_best_neighbor(struct ngbr_stats *Ri,
 			      struct reg_stats *Ri_rs,
 			      struct ngbr_stats *Rk,
@@ -1019,7 +1019,7 @@
     return count;
-static int merge_regions(struct ngbr_stats *Ri, struct reg_stats *Ri_rs,
+int merge_regions(struct ngbr_stats *Ri, struct reg_stats *Ri_rs,
 		         struct ngbr_stats *Rk, struct reg_stats *Rk_rs,
 		         int do_cand, struct globals *globals)
@@ -1224,7 +1224,7 @@
     return TRUE;
-static int set_candidate_flag(struct ngbr_stats *head, int value, struct globals *globals)
+int set_candidate_flag(struct ngbr_stats *head, int value, struct globals *globals)
     int n, R_id;
     struct rc next, ngbr_rc;
