[GRASS-SVN] r68975 - grass/trunk/gui/wxpython/modules
svn_grass at osgeo.org
Fri Jul 15 07:32:36 PDT 2016
Author: martinl
Date: 2016-07-15 07:32:36 -0700 (Fri, 15 Jul 2016)
New Revision: 68975
grass/trunk/gui/wxpython/modules/import_export.py
wxGUI/import: move override check from import settings tab to the main tab (it's commonly used option)
Modified: grass/trunk/gui/wxpython/modules/import_export.py
--- grass/trunk/gui/wxpython/modules/import_export.py 2016-07-15 13:14:26 UTC (rev 68974)
+++ grass/trunk/gui/wxpython/modules/import_export.py 2016-07-15 14:32:36 UTC (rev 68975)
@@ -11,7 +11,7 @@
- :class:`DxfImportDialog`
- :class:`ReprojectionDialog`
-(C) 2008-2015 by the GRASS Development Team
+(C) 2008-2016 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -80,6 +80,10 @@
self.list = LayersList(parent=self.panel, columns=columns)
self.list.LoadData()
+ self.override = wx.CheckBox(
+ parent=self.panel, id=wx.ID_ANY,
+ label=_("Override projection check (use current location's projection)"))
self.overwrite = wx.CheckBox(
label=_("Allow output files to overwrite existing files"))
@@ -167,6 +171,9 @@
flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND,
border=5)
+ dialogSizer.Add(item=self.override, proportion=0,
+ flag=wx.LEFT | wx.RIGHT | wx.BOTTOM, border=5)
dialogSizer.Add(item=self.overwrite, proportion=0,
@@ -313,7 +320,7 @@
layers = self.list.GetLayers()
- if differentProjLayers and '-o' not in self.getSettingsPageCmd():
+ if differentProjLayers and not self.override.IsChecked(): # '-o' not in self.getSettingsPageCmd():
dlg = ReprojectionDialog(
parent=self,
@@ -437,6 +444,9 @@
cmd.append('input=%s' % idsn)
cmd.append('output=%s' % output)
+ if self.override.IsChecked():
+ cmd.append('-o')
if self.overwrite.IsChecked():
cmd.append('--overwrite')
@@ -474,7 +484,7 @@
def _getBlackListedFlags(self):
"""Get flags which will not be showed in Settings page"""
- return ['overwrite']
+ return ['overwrite', 'o']
class OgrImportDialog(ImportDialog):
@@ -574,6 +584,9 @@
cmd.append('layer=%s' % layer)
+ cmd.append('-o')
@@ -615,7 +628,7 @@
class GdalOutputDialog(wx.Dialog):
