[GRASS-SVN] r68988 - in grass/branches/releasebranch_6_4: include/iostream lib/iostream
svn_grass at osgeo.org
Sat Jul 16 11:01:34 PDT 2016
Author: neteler
Date: 2016-07-16 11:01:34 -0700 (Sat, 16 Jul 2016)
New Revision: 68988
grass/branches/releasebranch_6_4/include/iostream/mm.h
grass/branches/releasebranch_6_4/lib/iostream/mm.cc
libiostream: use exception specifiers only for C++ versions older than C++11 (trunk, r68818)
Modified: grass/branches/releasebranch_6_4/include/iostream/mm.h
--- grass/branches/releasebranch_6_4/include/iostream/mm.h 2016-07-16 17:08:13 UTC (rev 68987)
+++ grass/branches/releasebranch_6_4/include/iostream/mm.h 2016-07-16 18:01:34 UTC (rev 68988)
@@ -21,6 +21,11 @@
#include <sys/types.h>
+// GCC with C++98 and -fexceptions requires exception
+// specifiers, however with C++11 and newer, using them causes an error.
+#if __cplusplus < 201103L
+#define GRASS_MM_USE_EXCEPTION_SPECIFIER
+#endif /* __cplusplus < 201103L */
#define MM_REGISTER_VERSION 2
@@ -110,10 +115,17 @@
void print();
friend class mm_register_init;
- friend void * operator new(size_t) throw(std::bad_alloc);
- friend void * operator new[](size_t) throw(std::bad_alloc);
+#ifdef GRASS_MM_USE_EXCEPTION_SPECIFIER
+ friend void * operator new(size_t) throw (std::bad_alloc);
+ friend void * operator new[] (size_t) throw (std::bad_alloc);
friend void operator delete(void *) throw();
friend void operator delete[](void *) throw();
+#else
+ friend void * operator new(size_t);
+ friend void * operator new[] (size_t);
+ friend void operator delete(void *) noexcept;
+ friend void operator delete[](void *) noexcept;
+#endif /* GRASS_MM_USE_EXCEPTION_SPECIFIER */
Modified: grass/branches/releasebranch_6_4/lib/iostream/mm.cc
--- grass/branches/releasebranch_6_4/lib/iostream/mm.cc 2016-07-16 17:08:13 UTC (rev 68987)
+++ grass/branches/releasebranch_6_4/lib/iostream/mm.cc 2016-07-16 18:01:34 UTC (rev 68988)
@@ -1,22 +1,40 @@
- * MODULE: iostream
+ * MODULE: iostream
* COPYRIGHT (C) 2007 Laura Toma
+ * Iostream is a library that implements streams, external memory
+ * sorting on streams, and an external memory priority queue on
+ * streams. These are the fundamental components used in external
+ * memory algorithms.
+ * Credits: The library was developed by Laura Toma. The kernel of
+ * class STREAM is based on the similar class existent in the GPL TPIE
+ * project developed at Duke University. The sorting and priority
+ * queue have been developed by Laura Toma based on communications
+ * with Rajiv Wickremesinghe. The library was developed as part of
+ * porting Terraflow to GRASS in 2001. PEARL upgrades in 2003 by
+ * Rajiv Wickremesinghe as part of the Terracost project.
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+ * General Public License for more details. *
// A simple registration based memory manager.
#include <stdio.h>
@@ -256,7 +274,11 @@
-void* operator new[] (size_t sz) throw(std::bad_alloc) {
+void* operator new[] (size_t sz) throw (std::bad_alloc) {
+#else
+void* operator new[] (size_t sz) {
void *p;
MM_DEBUG cout << "new: sz=" << sz << ", register "
@@ -307,7 +329,11 @@
-void* operator new (size_t sz) throw(std::bad_alloc) {
+void* operator new (size_t sz) throw (std::bad_alloc) {
+#else
+void* operator new (size_t sz) {
void *p;
@@ -359,7 +385,11 @@
void operator delete (void *ptr) throw() {
+#else
+void operator delete (void *ptr) noexcept {
size_t sz;
void *p;
@@ -399,7 +429,11 @@
void operator delete[] (void *ptr) throw() {
+#else
+void operator delete[] (void *ptr) noexcept {
size_t sz;
void *p;
