[GRASS-SVN] r69000 - grass/trunk/display/d.legend
Mon Jul 18 07:01:45 PDT 2016
Author: annakrat
Date: 2016-07-18 07:01:45 -0700 (Mon, 18 Jul 2016)
New Revision: 69000
   grass/trunk/display/d.legend/draw.c
   grass/trunk/display/d.legend/histogram.c
   grass/trunk/display/d.legend/local_proto.h
   grass/trunk/display/d.legend/main.c
d.legend: fix histograms for continuous gradient where categories are missing, add text after each label #3081 (by Adam Laza)
Modified: grass/trunk/display/d.legend/draw.c
--- grass/trunk/display/d.legend/draw.c	2016-07-18 13:54:01 UTC (rev 68999)
+++ grass/trunk/display/d.legend/draw.c	2016-07-18 14:01:45 UTC (rev 69000)
@@ -29,7 +29,7 @@
           double t_step, int colorb, int colorbg, struct Option *opt_use,
           struct Option *opt_at, struct Option *opt_fontsize,
           struct Option *opt_tstep, struct Option *opt_range, struct Flag *histo,
-          struct Flag *hidestr, int log_sc, int draw, int digits)
+          struct Flag *hidestr, int log_sc, int draw, int digits, char *units)
     char buff[512];
     int black, white;
@@ -53,7 +53,7 @@
     char DispFormat[5];         /*  %.Xf\0  */
     double maxCat;
     int horiz;
-    char *units;
+    char *units_bottom;
     double t_start;
     double max_hist;
     double txsiz, titsiz;
@@ -482,10 +482,27 @@
                         sprintf(buff, DispFormat, tcell);
                         if (!hide_catstr)       /* both */
                             strcat(buff, ")");
+                        D_text_size(txsiz, txsiz);
+                        D_get_text_box(buff,&bb,&bt, &bl, &br);
+                        LabelW = br - bl;
+                        if (LabelW > MaxLabelW) {
+                            MaxLabelW = LabelW;
+                            sprintf(MaxLabel, "%s", buff);
-                    if (!hide_catstr)   /* str */
+                    if (!hide_catstr) {  /* str */
                         sprintf(buff + strlen(buff), " %s", cstr);
+                        if (strlen(units)>0)
+                            strcat(buff, units);
+                        LabelW = br - bl;
                 else {          /* ie FP map */
                     if (hide_catnum)
                         buff[0] = 0;    /* no text */
@@ -501,8 +518,17 @@
                             val = dmax - k * (dmax - dmin) / (steps - 1);
                         sprintf(buff, DispFormat, val);
+                        LabelW = br - bl;
                 if (draw) {
                     if (!hide_catnum) {
@@ -571,13 +597,6 @@
                             D_text(buff);
-                D_text_size(txsiz, txsiz);
-                D_get_text_box(buff,&bb,&bt, &bl, &br);
-                LabelW = br - bl;
-                if (LabelW > MaxLabelW) {
-                    MaxLabelW = LabelW;
-                    sprintf(MaxLabel, DispFormat, val);
             }                   /* for */
@@ -595,6 +614,15 @@
                                   tick_values[i], dmin, dmax);
                 sprintf(buff, DispFormat, tick_values[i]);
+                LabelW = br - bl;
                 if (log_sc) {
                     coef = (log10(tick_values[i]) - log10(dmin)) / (log10(dmax) - log10(dmin));
@@ -648,15 +676,8 @@
                     D_use_color(color);
                     D_text(buff);
-                LabelW = br - bl;
-                    sprintf(MaxLabel, DispFormat, tick_values[i]);
         /* LABEL_STEP OPTION */
         if (opt_tstep->answer) {
@@ -666,6 +687,15 @@
                     num = ceil(log10(dmin)) + t_start;
                     val = pow(10,num);
+                    LabelW = br - bl;
                     coef = (log10(val) - log10(dmin)) / (log10(dmax) - log10(dmin));
                     if (draw){
                         if (!flip){
@@ -712,6 +742,7 @@
                         D_use_color(color);
                         D_text(buff);
                 t_start += t_step;
@@ -725,12 +756,14 @@
                 if (!horiz)
                     while (t_start <= dmax) {
                         sprintf(buff, DispFormat, t_start);
                         LabelW = br - bl;
                             MaxLabelW = LabelW;
-                            sprintf(MaxLabel, DispFormat, t_start);
                         if (draw) {
                             coef = (t_start - dmin) / ((dmax - dmin) * 1.0);
@@ -749,12 +782,14 @@
                 else
                         LabelW = br - bl;
                             MaxLabelW = LabelW;
                         if (draw) {
@@ -777,12 +812,14 @@
                 if (!horiz)
                         LabelW = br - bl;
                             MaxLabelW = LabelW;
                         if (draw) {
@@ -802,12 +839,14 @@
                 else
                         LabelW = br - bl;
                             MaxLabelW = LabelW;
                         if (draw) {
@@ -906,16 +945,16 @@
             /* units */
             /* print units label, if present */
             if (maptype == MAP_TYPE_RASTER2D)
-                units = Rast_read_units(map_name, "");
+                units_bottom = Rast_read_units(map_name, "");
             else
                 units = "";
             /* FIXME: does the raster3d really need to be opened to read the units?
-               units = Rast3d_get_unit(map_fid); */
+               units_bottom = Rast3d_get_unit(map_fid); */
-            if (!units)
-                units = "";
+            if (!units_bottom)
+                units_bottom = "";
-            if (strlen(units)) {
+            if (strlen(units_bottom)) {
                 D_text_size(titsiz, titsiz);
                 D_get_text_box(title, &bb, &bt, &bl, &br);
                 if (horiz) {
@@ -931,7 +970,7 @@
                 if (draw) {
                     D_use_color(color);
                     D_pos_abs(x_tit, y_tit);
-                    D_text(units);
+                    D_text(units_bottom);
         }                       /* end of display units) */
@@ -1128,33 +1167,38 @@
                 buff[0] = 0;
                 if (!hide_catnum) {     /* num */
                     sprintf(buff, DispFormat, (int)catlist[i]);
                     LabelW = br - bl;
                         MaxLabelW = LabelW;
-                        sprintf(MaxLabel, DispFormat, (int)catlist[i]);
                     if (!flip) {
                         LabelW = br - bl;
                             MaxLabelW = LabelW;
                     else {
                                 (int)catlist[catlistCount - i - 1]);
                         LabelW = br - bl;
                             MaxLabelW = LabelW;
-                                    (int)catlist[catlistCount - i - 1]);
@@ -1162,6 +1206,8 @@
                     LabelW = br - bl;
@@ -1177,45 +1223,53 @@
                         /* pass through format exactly as given by the user in
                            the use= command line parameter (helps with log scale) */
                         sprintf(buff, "%s", opt_use->answers[i]);
                         LabelW = br - bl;
                             MaxLabelW = LabelW;
-                            sprintf(MaxLabel, " %s", opt_use->answers[i]);
+                            sprintf(MaxLabel, " %s", buff);
                     else {
                         /* automatically generated/tuned decimal precision format */
                         sprintf(buff, DispFormat, catlist[i]);
                         LabelW = br - bl;
                             MaxLabelW = LabelW;
-                            sprintf(MaxLabel, DispFormat, catlist[i]);
                 else {
                     if (use_catlist){
                         sprintf(buff, "%s", opt_use->answers[catlistCount - i - 1]);
                         LabelW = br - bl;
                             MaxLabelW = LabelW;
-                            sprintf(MaxLabel, " %s", opt_use->answers[catlistCount - i - 1]);
                     else {
                         sprintf(buff, DispFormat, catlist[catlistCount - i - 1]);
                         LabelW = br - bl;
                             MaxLabelW = LabelW;
Modified: grass/trunk/display/d.legend/histogram.c
--- grass/trunk/display/d.legend/histogram.c	2016-07-18 13:54:01 UTC (rev 68999)
+++ grass/trunk/display/d.legend/histogram.c	2016-07-18 14:01:45 UTC (rev 69000)
@@ -149,6 +149,7 @@
             dist_stats.maxcat);
     for (i = dist_stats.mincat, ystep = 0; i <= dist_stats.maxcat; i++) {
+        cell_count = 0;
         if (!ptr)
             break;
Modified: grass/trunk/display/d.legend/local_proto.h
--- grass/trunk/display/d.legend/local_proto.h	2016-07-18 13:54:01 UTC (rev 68999)
+++ grass/trunk/display/d.legend/local_proto.h	2016-07-18 14:01:45 UTC (rev 69000)
@@ -42,4 +42,4 @@
           double, int, int, double, double, double *, int, int, int, double,
           double, const char *, double *, double, int, int, struct Option *,
           struct Option *, struct Option *, struct Option *, struct Option *,
-          struct Flag *, struct Flag *, int, int, int);
+          struct Flag *, struct Flag *, int, int, int, char *);
Modified: grass/trunk/display/d.legend/main.c
--- grass/trunk/display/d.legend/main.c	2016-07-18 13:54:01 UTC (rev 68999)
+++ grass/trunk/display/d.legend/main.c	2016-07-18 14:01:45 UTC (rev 69000)
@@ -54,7 +54,7 @@
         *opt_thin, *opt_labelnum, *opt_at, *opt_use, *opt_range,
         *opt_font, *opt_path, *opt_charset, *opt_fontsize, *opt_title,
         *opt_ticks, *opt_tstep, *opt_brdcolor, *opt_bgcolor,
-        *opt_tit_fontsize, *opt_digits;
+        *opt_tit_fontsize, *opt_digits, *opt_units;
     struct Flag *hidestr, *hidenum, *hidenodata, *smooth, *flipit, *histo,
         *showtick, *showbg, *log_sc;
     double X0, X1, Y0, Y1;
@@ -64,6 +64,7 @@
     int catlistCount, use_catlist, ticksCount;
     double fontsize;
     char *title;
+    char *units;
     double *tick_values;
     double t_step;
     int colorb, colorbg;
@@ -126,6 +127,14 @@
         _("Thinning factor (thin=10 gives cats 0,10,20...)");
     opt_thin->guisection = _("Advanced");
+    opt_units = G_define_option();
+    opt_units->key = "units";
+    opt_units->type = TYPE_STRING;
+    opt_units->required = NO;
+    opt_units->description =
+            _("Units to display after labels (e.g. meters)");
+    opt_units->guisection = _("Advanced");
     opt_labelnum = G_define_option();
     opt_labelnum->key = "labelnum";
     opt_labelnum->type = TYPE_INTEGER;
@@ -306,6 +315,12 @@
     else
         title = "";
+    if (opt_units->answer) {
+        units = opt_units->answer;
+    else
+        units = "";
     hide_catstr = hidestr->answer;      /* note hide_catstr gets changed and re-read below */
     hide_catnum = hidenum->answer;
     show_ticks = showtick->answer;
@@ -461,7 +476,7 @@
              UserRangeMax, catlist, catlistCount, use_catlist, ticksCount,
              fontsize, tit_fontsize, title, tick_values, t_step, colorb,
              colorbg, opt_use, opt_at, opt_fontsize, opt_tstep,
-             opt_range, histo, hidestr, log_scale, 0, digits);
+             opt_range, histo, hidestr, log_scale, 0, digits, units);
     draw(map_name, maptype, color, thin, lines, steps, fp, label_indent,
          hide_catnum, hide_catstr, show_ticks, hide_nodata, do_smooth, cats,
@@ -469,7 +484,7 @@
          catlist, catlistCount, use_catlist, ticksCount, fontsize,
          tit_fontsize, title, tick_values, t_step, colorb, colorbg, opt_use,
          opt_at, opt_fontsize, opt_tstep, opt_range, histo,
-         hidestr, log_scale, 1, digits);
+         hidestr, log_scale, 1, digits, units);
     D_close_driver();
