[GRASS-SVN] r69016 - in grass/branches/releasebranch_7_2/lib/python/temporal: . testsuite
Thu Jul 21 10:33:42 PDT 2016
Author: huhabla
Date: 2016-07-21 10:33:41 -0700 (Thu, 21 Jul 2016)
New Revision: 69016
   grass/branches/releasebranch_7_2/lib/python/temporal/temporal_algebra.py
   grass/branches/releasebranch_7_2/lib/python/temporal/temporal_operator.py
   grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster3d_algebra.py
   grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster_algebra.py
   grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster_base_algebra.py
   grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_algebra_mixed_stds.py
   grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_conditionals.py
   grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
   grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py
temporal framework: Implementation of a dry-run concept, some code cleanup
Modified: grass/branches/releasebranch_7_2/lib/python/temporal/temporal_algebra.py
--- grass/branches/releasebranch_7_2/lib/python/temporal/temporal_algebra.py	2016-07-21 13:03:39 UTC (rev 69015)
+++ grass/branches/releasebranch_7_2/lib/python/temporal/temporal_algebra.py	2016-07-21 17:33:41 UTC (rev 69016)
@@ -738,13 +738,13 @@
     def __init__(self, pid=None, run=True, debug=False, spatial=False,
-                 null=False, register_null=False, dry_run=False,  nprocs=1):
+                 register_null=False, dry_run=False, nprocs=1):
         self.run = run
         self.dry_run = dry_run              # Compute the processes and output but Do not start the processes
         self.process_chain_dict = {}        # This dictionary stores all processes, as well as the maps to register and remove
-        self.process_chain_dict["processes"] = []       # process decsription
+        self.process_chain_dict["processes"] = []       # The mapcalc and v.patch module calls
         self.process_chain_dict["register"] = []        # Maps that must be registered/updated or inserted in a new STDS
-        self.process_chain_dict["remove"] = []          # Maps that must be removed
+        self.process_chain_dict["remove"] = []          # The g.remove module calls
         self.process_chain_dict["STDS"] = {}            # The STDS that must be created
         self.debug = debug
@@ -753,7 +753,6 @@
         self.names = {}
         # Count map names
         self.spatial = spatial
-        self.null = null
         self.mapset = get_current_mapset()
         self.temporaltype = None
         self.msgr = get_tgis_message_interface()
@@ -787,7 +786,6 @@
                                     parse the expression, default is TemporalAlgebraLexer
              :return: True if successful, False otherwise
         l = lexer
         # Split the expression to ignore the left part
@@ -866,7 +864,7 @@
         :param mapclass:
         :param basename:
         :param overwrite:
-        :return: The process chain dictionary
+        :return: The process chain dictionary is dry-run was enabled, None otherwise
         self.lexer = TemporalAlgebraLexer()
         self.lexer.build()
@@ -881,7 +879,8 @@
         self.expression = expression
         self.parser.parse(expression)
-        return self.process_chain_dict
+        if self.dry_run is True:
+            return self.process_chain_dict
     def generate_map_name(self):
         """Generate an unique  map name and register it in the objects map list
@@ -1101,8 +1100,11 @@
                 m.inputs["name"].value = stringlist
                 m.flags["f"].value = True
                 # print(m.get_bash())
-                m.run()
+                self.process_chain_dict["remove"].append(m.get_dict())
+                if self.dry_run is False:
+                    m.run()
     def check_stds(self, input, clear=False,  stds_type=None,  check_type=True):
         """ Check if input space time dataset exist in database and return its map list.
@@ -1623,8 +1625,8 @@
               a8 at B - start: 8 end: 10
-        topologylist = ["EQUAL", "FOLLOWS", "PRECEDES", "OVERLAPS", "OVERLAPPED", \
-                        "DURING", "STARTS", "FINISHES", "CONTAINS", "STARTED", \
+        topologylist = ["EQUAL", "FOLLOWS", "PRECEDES", "OVERLAPS", "OVERLAPPED",
+                        "DURING", "STARTS", "FINISHES", "CONTAINS", "STARTED",
                         "FINISHED"]
         for topo in topolist:
@@ -1977,7 +1979,6 @@
             for ele in conditionlist:
                 if ele == '||':
                     ele_index = conditionlist.index(ele)
-                    topolist = conditionlist.pop(ele_index -1)
                     right = conditionlist.pop(ele_index)
                     left  = conditionlist.pop(ele_index - 2)
                     if any([left, right]):
@@ -1988,7 +1989,6 @@
                     recurse_compare(conditionlist)
                 if ele == '&&':
                     if all([left, right]):
@@ -1997,6 +1997,7 @@
                         result = False
                     conditionlist[ele_index - 2] = result
             resultlist = conditionlist
             return(resultlist)
@@ -2283,9 +2284,9 @@
         #    R = merge(A, B)
         expr : MERGE LPAREN stds COMMA stds RPAREN
-               | MERGE LPAREN expr COMMA stds RPAREN
-               | MERGE LPAREN stds COMMA expr RPAREN
-               | MERGE LPAREN expr COMMA expr RPAREN
+             | MERGE LPAREN expr COMMA stds RPAREN
+             | MERGE LPAREN stds COMMA expr RPAREN
+             | MERGE LPAREN expr COMMA expr RPAREN
         if self.run:
             # Check input map.
@@ -2308,7 +2309,7 @@
                 typeB = maplistB[0].metadata.get_datatype()
                 if typeA != typeB:
-                    grass.fatal(_("Space time datasets to merge must have the same temporal type"))
+                    raise FatalError(_("Space time datasets to merge must have the same temporal type"))
                 resultlist = maplistA + maplistB
@@ -2323,34 +2324,40 @@
     def p_t_hash(self,t):
         t_hash_var : stds HASH stds
-                        | expr HASH stds
-                        | stds HASH expr
-                        | expr HASH expr
+                   | expr HASH stds
+                   | stds HASH expr
+                   | expr HASH expr
         if self.run:
             maplistA   = self.check_stds(t[1])
             maplistB   = self.check_stds(t[3])
             resultlist = self.get_temporal_topo_list(maplistA, maplistB,
-                                                        count_map = True)
+                                                     count_map = True)
             t[0] = resultlist
     def p_t_hash2(self,t):
         t_hash_var : stds T_HASH_OPERATOR stds
-                      | stds T_HASH_OPERATOR expr
-                      | expr T_HASH_OPERATOR stds
-                      | expr T_HASH_OPERATOR expr
+                   | stds T_HASH_OPERATOR expr
+                   | expr T_HASH_OPERATOR stds
+                   | expr T_HASH_OPERATOR expr
         if self.run:
-            topolist   = self.eval_toperator(t[2],  optype = 'hash')[0]
+            topolist   = self.eval_toperator(t[2], optype='hash')[0]
             resultlist = self.get_temporal_topo_list(maplistA, maplistB, topolist,
                                                      count_map = True)
             t[0] = resultlist
+    def p_t_hash_paren(self, t):
+        t_hash_var : LPAREN t_hash_var RPAREN
+        t[0] = t[2]
     def p_t_td_var(self, t):
         t_td_var : TD LPAREN stds RPAREN
@@ -2361,11 +2368,11 @@
             for map_i in maplist:
                 if map_i.is_time_absolute:
                     start, end = map_i.get_absolute_time()
-                    if end != None:
+                    if end is not None:
                         td = time_delta_to_relative_time(end - start)
                 else:
-                    start, end, unit = current.get_relative_time()
-                    if end != None:
+                    start, end, unit = map_i.get_relative_time()
                         td = end - start
                 if "map_value" in dir(map_i):
                     gvar = GlobalTemporalVar()
@@ -2424,8 +2431,8 @@
         #    A # B == 2
         #    td(A) < 31
-        t_var_expr :  t_td_var comp_op number
-                | t_hash_var comp_op number
+        t_var_expr : t_td_var comp_op number
+                   | t_hash_var comp_op number
         if self.run:
             maplist = self.check_stds(t[1])
@@ -2456,7 +2463,7 @@
         #    start_day(B) < start_month(A)
         t_var_expr : t_var LPAREN stds RPAREN comp_op number
-                | t_var LPAREN expr RPAREN comp_op number
+                   | t_var LPAREN expr RPAREN comp_op number
         # TODO:  Implement comparison operator for map lists.
         #| t_var LPAREN stds RPAREN comp_op t_var LPAREN stds RPAREN
@@ -2529,11 +2536,12 @@
             function = t[2] + t[3]
             aggregate = t[2]
             # Build conditional values based on topological relationships.
-            complist = self.get_temporal_topo_list(tvarexprA, tvarexprB, topolist = relations,
-                               compare_bool = True, compop = function[0], aggregate = aggregate)
+            complist = self.get_temporal_topo_list(tvarexprA, tvarexprB, topolist=relations,
+                                                   compare_bool=True, compop=function[0],
+                                                   aggregate=aggregate)
             # Set temporal extent based on topological relationships.
             resultlist = self.set_temporal_extent_list(complist, topolist = relations,
-                                temporal = temporal)
+                                                       temporal=temporal)
             t[0] = resultlist
@@ -2548,13 +2556,13 @@
             tvarexprA  = t[1]
             tvarexprB  = t[3]
             # Evaluate temporal comparison operator.
-            relations, temporal, function, aggregate  = self.eval_toperator(t[2],  optype = 'boolean')
+            relations, temporal, function, aggregate = self.eval_toperator(t[2],  optype='boolean')
+                               compare_bool=True, compop=function[0], aggregate=aggregate)
-            resultlist = self.set_temporal_extent_list(complist, topolist = relations,
+            resultlist = self.set_temporal_extent_list(complist, topolist=relations,
             t[0] = resultlist
@@ -2583,7 +2591,7 @@
             # Return map list.
             t[0] = selectlist
         else:
-            t[0] = t[1] , "*"
+            t[0] = t[1] + "*"
         if self.debug:
             print(str(t[1]),  "* = ", t[1], t[2], t[3])
@@ -2605,7 +2613,7 @@
             # Perform negative selection.
             selectlist = self.perform_temporal_selection(maplistA, maplistB,
-                                                         inverse = True)
+                                                         inverse=True)
             # Return map list.
             t[0] = selectlist
         else:
@@ -2614,17 +2622,16 @@
         if self.debug:
             print(t[1] + "* = ", t[1], t[2], t[3])
     def p_expr_t_select_operator(self, t):
         # Temporal equal selection
         # The temporal topology relation equals is implicit
         # Examples:
         #    A {!:} B  # Select the part of A that is temporally unequal to B
         #    A  {:} B  # Select the part of A that is temporally equal B
-        #    A {equals, !:} B    # Select the part of A that is temporally unequal to B
-        #    A {during, !:} B    # Select the part of A that is temporally not during B
-        #    A {overlaps, :} B   # Select the part of A that temporally overlaps B
-        #    A {overlaps|equals, :} B  # Select the part of A that temporally overlaps or equals B
+        #    A {!:, equals} B          # Select the part of A that is temporally unequal to B
+        #    A {!:, during} B          # Select the part of A that is temporally not during B
+        #    A {:, overlaps} B         # Select the part of A that temporally overlaps B
+        #    A {:, overlaps|equals} B  # Select the part of A that temporally overlaps or equals B
         expr : stds T_SELECT_OPERATOR stds
              | expr T_SELECT_OPERATOR stds
@@ -2633,8 +2640,8 @@
         if self.run:
             # Check input stds.
-            maplistA     = self.check_stds(t[1])
-            maplistB     = self.check_stds(t[3])
+            maplistA = self.check_stds(t[1])
+            maplistB = self.check_stds(t[3])
             # Evaluate temporal operator.
             operators  = self.eval_toperator(t[2],  optype='select')
             # Check for negative selection.
@@ -2647,7 +2654,7 @@
                                                          topolist=operators[0],
                                                          inverse=negation)
             selectlist = self.set_granularity(selectlist, maplistB, operators[1],
-                operators[0])
+                                              operators[0])
             # Return map list.
             t[0] = selectlist
         else:
Modified: grass/branches/releasebranch_7_2/lib/python/temporal/temporal_operator.py
--- grass/branches/releasebranch_7_2/lib/python/temporal/temporal_operator.py	2016-07-21 13:03:39 UTC (rev 69015)
+++ grass/branches/releasebranch_7_2/lib/python/temporal/temporal_operator.py	2016-07-21 17:33:41 UTC (rev 69016)
@@ -159,27 +159,27 @@
     tokens = tokens + tuple(relations.values())
     # Regular expression rules for simple tokens
-    t_T_SELECT                = r':'
-    t_T_NOT_SELECT        = r'!:'
-    t_COMMA                    = r','
-    t_LEFTREF                  = '^[l|left]'
-    t_RIGHTREF                ='^[r|right]'
-    t_UNION                     = '^[u|union]'
-    t_DISJOINT                 = '^[d|disjoint]'
-    t_INTERSECT             = '^[i|intersect]'
-    t_HASH                      = r'\#'
-    t_OR                          = r'[\|]'
-    t_AND                        = r'[&]'
-    t_DISOR                     = r'\+'
-    t_XOR                         = r'\^'
-    t_NOT                         = r'\~'
-    t_MOD                       = r'[\%]'
-    t_DIV                         = r'[\/]'
-    t_MULT                      = r'[\*]'
-    t_ADD                       = r'[\+]'
-    t_SUB                        = r'[-]'
-    t_CLPAREN                = r'\{'
-    t_CRPAREN                = r'\}'
+    t_T_SELECT       = r':'
+    t_T_NOT_SELECT   = r'!:'
+    t_COMMA          = r','
+    t_LEFTREF        = '^[l|left]'
+    t_RIGHTREF       ='^[r|right]'
+    t_UNION          = '^[u|union]'
+    t_DISJOINT       = '^[d|disjoint]'
+    t_INTERSECT      = '^[i|intersect]'
+    t_HASH           = r'\#'
+    t_OR             = r'[\|]'
+    t_AND            = r'[&]'
+    t_DISOR          = r'\+'
+    t_XOR            = r'\^'
+    t_NOT            = r'\~'
+    t_MOD            = r'[\%]'
+    t_DIV            = r'[\/]'
+    t_MULT           = r'[\*]'
+    t_ADD            = r'[\+]'
+    t_SUB            = r'[-]'
+    t_CLPAREN        = r'\{'
+    t_CRPAREN        = r'\}'
     # These are the things that should be ignored.
     t_ignore = ' \t'
@@ -221,7 +221,7 @@
     # Handle errors.
     def t_error(self, t):
         raise SyntaxError("syntax error on line %d near '%s'" %
-            (t.lineno, t.value))
+                          (t.lineno, t.value))
     # Build the lexer
     def build(self,**kwargs):
@@ -246,17 +246,27 @@
         self.lexer = TemporalOperatorLexer()
         self.lexer.build()
         self.parser = yacc.yacc(module=self)
-        self.relations = None
-        self.temporal  = None
-        self.function  = None
-        self.aggregate = None
+        self.relations = None   # Temporal relations equals, contain, during, ...
+        self.temporal  = None   # Temporal operation like intersect, left, right, ...
+        self.function  = None   # Actual operation
+        self.aggregate = None   # Aggregation function
-    def parse(self, expression,  optype = 'relation'):
+    def parse(self, expression,  optype='relation'):
+        """Parse the expression and fill the object variables
+        :param expression:
+        :param optype: The parameter optype can be of type:
+                       - select   { :, during,   r}
+                       - boolean  {&&, contains, |}
+                       - raster   { *, equal,    |}
+                       - vector   { |, starts,   &}
+                       - hash     { #, during,   l}
+                       - relation {during}
+        :return:
         self.optype = optype
-        # The parameter optype can be of type: select {:, during, r}, boolean{&&, contains, |},
-        #                                                            raster{*, equal, |}, vector {|, starts, &},
-        #                                                            hash{#, during, l} or relation {during}.
     # Error rule for syntax errors.
     def p_error(self, t):
@@ -266,7 +276,6 @@
     tokens = TemporalOperatorLexer.tokens
     def p_relation_operator(self, t):
-        # The expression should always return a list of maps.
         operator : CLPAREN relation CRPAREN
                  | CLPAREN relationlist CRPAREN
@@ -286,12 +295,11 @@
             t[0] = t[2]
     def p_relation_bool_operator(self, t):
-        operator : CLPAREN OR OR COMMA relation CRPAREN
-                | CLPAREN AND AND COMMA relation CRPAREN
-                | CLPAREN OR OR COMMA relationlist CRPAREN
-                | CLPAREN AND AND COMMA relationlist CRPAREN
+        operator : CLPAREN OR  OR  COMMA relation     CRPAREN
+                 | CLPAREN AND AND COMMA relation     CRPAREN
+                 | CLPAREN OR  OR  COMMA relationlist CRPAREN
+                 | CLPAREN AND AND COMMA relationlist CRPAREN
         if not self.optype == 'boolean':
             raise SyntaxError("invalid syntax")
@@ -308,16 +316,15 @@
             t[0] = t[2]
     def p_relation_bool_combi_operator(self, t):
-        operator : CLPAREN OR OR COMMA relation COMMA OR CRPAREN
-                | CLPAREN OR OR COMMA relation COMMA AND CRPAREN
-                | CLPAREN AND AND COMMA relation COMMA OR CRPAREN
-                | CLPAREN AND AND COMMA relation COMMA AND CRPAREN
-                | CLPAREN OR OR COMMA relationlist COMMA OR CRPAREN
-                | CLPAREN OR OR COMMA relationlist COMMA AND CRPAREN
-                | CLPAREN AND AND COMMA relationlist COMMA OR CRPAREN
-                | CLPAREN AND AND COMMA relationlist COMMA AND CRPAREN
+        operator : CLPAREN OR  OR  COMMA relation     COMMA OR  CRPAREN
+                 | CLPAREN OR  OR  COMMA relation     COMMA AND CRPAREN
+                 | CLPAREN AND AND COMMA relation     COMMA OR  CRPAREN
+                 | CLPAREN AND AND COMMA relation     COMMA AND CRPAREN
+                 | CLPAREN OR  OR  COMMA relationlist COMMA OR  CRPAREN
+                 | CLPAREN OR  OR  COMMA relationlist COMMA AND CRPAREN
+                 | CLPAREN AND AND COMMA relationlist COMMA OR  CRPAREN
+                 | CLPAREN AND AND COMMA relationlist COMMA AND CRPAREN
@@ -334,12 +341,11 @@
             t[0] = t[2]
     def p_relation_bool_combi_operator2(self, t):
-        operator : CLPAREN OR OR COMMA relation COMMA temporal CRPAREN
-                | CLPAREN AND AND COMMA relation COMMA temporal CRPAREN
-                | CLPAREN OR OR COMMA relationlist COMMA temporal CRPAREN
-                | CLPAREN AND AND COMMA relationlist COMMA temporal CRPAREN
+        operator : CLPAREN OR  OR  COMMA relation     COMMA temporal CRPAREN
+                 | CLPAREN AND AND COMMA relation     COMMA temporal CRPAREN
+                 | CLPAREN OR  OR  COMMA relationlist COMMA temporal CRPAREN
+                 | CLPAREN AND AND COMMA relationlist COMMA temporal CRPAREN
@@ -356,16 +362,15 @@
             t[0] = t[2]
     def p_relation_bool_combi_operator3(self, t):
-        operator : CLPAREN OR OR COMMA relation COMMA OR COMMA temporal CRPAREN
-                | CLPAREN OR OR COMMA relation COMMA AND COMMA temporal CRPAREN
-                | CLPAREN AND AND COMMA relation COMMA OR COMMA temporal CRPAREN
-                | CLPAREN AND AND COMMA relation COMMA AND COMMA temporal CRPAREN
-                | CLPAREN OR OR COMMA relationlist COMMA OR COMMA temporal CRPAREN
-                | CLPAREN OR OR COMMA relationlist COMMA AND COMMA temporal CRPAREN
-                | CLPAREN AND AND COMMA relationlist COMMA OR COMMA temporal CRPAREN
-                | CLPAREN AND AND COMMA relationlist COMMA AND COMMA temporal CRPAREN
+        operator : CLPAREN OR  OR  COMMA relation     COMMA OR  COMMA temporal CRPAREN
+                 | CLPAREN OR  OR  COMMA relation     COMMA AND COMMA temporal CRPAREN
+                 | CLPAREN AND AND COMMA relation     COMMA OR  COMMA temporal CRPAREN
+                 | CLPAREN AND AND COMMA relation     COMMA AND COMMA temporal CRPAREN
+                 | CLPAREN OR  OR  COMMA relationlist COMMA OR  COMMA temporal CRPAREN
+                 | CLPAREN OR  OR  COMMA relationlist COMMA AND COMMA temporal CRPAREN
+                 | CLPAREN AND AND COMMA relationlist COMMA OR  COMMA temporal CRPAREN
+                 | CLPAREN AND AND COMMA relationlist COMMA AND COMMA temporal CRPAREN
@@ -382,13 +387,12 @@
             t[0] = t[2]
     def p_select_relation_operator(self, t):
         operator : CLPAREN select CRPAREN
-                    | CLPAREN select COMMA relation CRPAREN
-                    | CLPAREN select COMMA relationlist CRPAREN
-                    | CLPAREN select COMMA relation COMMA temporal CRPAREN
-                    | CLPAREN select COMMA relationlist COMMA temporal CRPAREN
+                 | CLPAREN select COMMA relation     CRPAREN
+                 | CLPAREN select COMMA relationlist CRPAREN
+                 | CLPAREN select COMMA relation     COMMA temporal CRPAREN
+                 | CLPAREN select COMMA relationlist COMMA temporal CRPAREN
         if not self.optype == 'select':
@@ -398,10 +402,6 @@
                 self.relations = ['equal']
                 self.temporal  = "l"
                 self.function  = t[2]
-            elif len(t) == 5:
-                self.relations = ['equal']
-                self.temporal  = t[3]
-                self.function  = t[2]
             elif len(t) == 6:
                 if isinstance(t[4], list):
                     self.relations = t[4]
@@ -419,13 +419,12 @@
             t[0] = t[2]
     def p_hash_relation_operator(self, t):
         operator : CLPAREN HASH CRPAREN
-                    | CLPAREN HASH COMMA relation CRPAREN
-                    | CLPAREN HASH COMMA relationlist CRPAREN
-                    | CLPAREN HASH COMMA relation COMMA temporal CRPAREN
-                    | CLPAREN HASH COMMA relationlist COMMA temporal CRPAREN
+                 | CLPAREN HASH COMMA relation     CRPAREN
+                 | CLPAREN HASH COMMA relationlist CRPAREN
+                 | CLPAREN HASH COMMA relation     COMMA temporal CRPAREN
+                 | CLPAREN HASH COMMA relationlist COMMA temporal CRPAREN
         if not self.optype == 'hash':
@@ -435,10 +434,6 @@
                 self.temporal  = "l"
-            elif len(t) == 5:
             elif len(t) == 6:
@@ -459,10 +454,10 @@
         operator : CLPAREN arithmetic CRPAREN
-                    | CLPAREN arithmetic COMMA relation CRPAREN
-                    | CLPAREN arithmetic COMMA relationlist CRPAREN
-                    | CLPAREN arithmetic COMMA relation COMMA temporal CRPAREN
-                    | CLPAREN arithmetic COMMA relationlist COMMA temporal CRPAREN
+                 | CLPAREN arithmetic COMMA relation     CRPAREN
+                 | CLPAREN arithmetic COMMA relationlist CRPAREN
+                 | CLPAREN arithmetic COMMA relation     COMMA temporal CRPAREN
+                 | CLPAREN arithmetic COMMA relationlist COMMA temporal CRPAREN
         if not self.optype == 'raster':
@@ -472,10 +467,6 @@
                 self.temporal  = "l"
-            elif len(t) == 5:
             elif len(t) == 6:
@@ -496,10 +487,10 @@
         operator : CLPAREN overlay CRPAREN
-                    | CLPAREN overlay COMMA relation CRPAREN
-                    | CLPAREN overlay COMMA relationlist CRPAREN
-                    | CLPAREN overlay COMMA relation COMMA temporal CRPAREN
-                    | CLPAREN overlay COMMA relationlist COMMA temporal CRPAREN
+                 | CLPAREN overlay COMMA relation     CRPAREN
+                 | CLPAREN overlay COMMA relationlist CRPAREN
+                 | CLPAREN overlay COMMA relation     COMMA temporal CRPAREN
+                 | CLPAREN overlay COMMA relationlist COMMA temporal CRPAREN
         if not self.optype == 'overlay':
@@ -509,10 +500,6 @@
                 self.temporal  = "l"
-            elif len(t) == 5:
             elif len(t) == 6:
@@ -572,10 +559,10 @@
         # The list of relations.
         temporal : LEFTREF
-                | RIGHTREF
-                | UNION
-                | DISJOINT
-                | INTERSECT
+                 | RIGHTREF
+                 | UNION
+                 | DISJOINT
+                 | INTERSECT
         t[0] = t[1]
@@ -602,10 +589,10 @@
         overlay : AND
-                   | OR
-                   | XOR
-                   | DISOR
-                   | NOT
+                | OR
+                | XOR
+                | DISOR
+                | NOT
         t[0] = t[1]
Modified: grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster3d_algebra.py
--- grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster3d_algebra.py	2016-07-21 13:03:39 UTC (rev 69015)
+++ grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster3d_algebra.py	2016-07-21 17:33:41 UTC (rev 69016)
@@ -17,9 +17,13 @@
 class TemporalRaster3DAlgebraParser(TemporalRasterBaseAlgebraParser):
     """The temporal raster algebra class"""
-    def __init__(self, pid=None, run=False, debug=True, spatial = False, nprocs = 1, register_null = False):
-        TemporalRasterBaseAlgebraParser.__init__(self, pid, run, debug, spatial, nprocs, register_null)
+    def __init__(self, pid=None, run=False, debug=True, spatial=False,
+        TemporalRasterBaseAlgebraParser.__init__(self, pid=pid, run=run, debug=debug,
+                                                 spatial=spatial, register_null=register_null,
+                                                 dry_run=dry_run, nprocs=nprocs)
         self.m_mapcalc = pymod.Module('r3.mapcalc')
         self.m_mremove = pymod.Module('g.remove')
Modified: grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster_algebra.py
--- grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster_algebra.py	2016-07-21 13:03:39 UTC (rev 69015)
+++ grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster_algebra.py	2016-07-21 17:33:41 UTC (rev 69016)
@@ -59,9 +59,13 @@
 class TemporalRasterAlgebraParser(TemporalRasterBaseAlgebraParser):
         self.m_mapcalc = pymod.Module('r.mapcalc')
@@ -91,6 +95,9 @@
     ######################### Temporal functions ##############################
     def p_statement_assign(self, t):
@@ -101,6 +108,7 @@
         TemporalRasterBaseAlgebraParser.p_statement_assign(self, t)
     def p_ts_neighbour_operation(self, t):
+        # Spatial and temporal neighbour operations via indexing
         # Examples:
         # A[1,0]
         # B[-2]
Modified: grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster_base_algebra.py
--- grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster_base_algebra.py	2016-07-21 13:03:39 UTC (rev 69015)
+++ grass/branches/releasebranch_7_2/lib/python/temporal/temporal_raster_base_algebra.py	2016-07-21 17:33:41 UTC (rev 69016)
@@ -138,12 +138,15 @@
         ('left', 'AND', 'OR', 'T_COMP_OPERATOR', 'MOD', 'DIV', 'MULT',
          'T_ARITH1_OPERATOR'))
-    def __init__(self, pid=None, run = True, debug = False, spatial = False, \
-                  nprocs = 1, register_null = False):
-        TemporalAlgebraParser.__init__(self, pid, run, debug, spatial)
-        self.nprocs = nprocs
-        self.register_null = register_null
+    def __init__(self, pid=None, run=True,
+                 debug=False, spatial=False,
+                 dry_run=False, nprocs=1):
+        TemporalAlgebraParser.__init__(self, pid=pid, run=run, debug=debug,
     def check_null(self, t):
         try:
             int(t)
@@ -152,10 +155,10 @@
             return "null()"
-    def get_temporal_topo_list(self, maplistA, maplistB = None, topolist = ["EQUAL"],
-                               assign_val = False, count_map = False, compare_bool = False,
-                               compare_cmd = False,  compop = None, aggregate = None,
-                               new = False,  convert = False,  operator_cmd = False):
+    def get_temporal_topo_list(self, maplistA, maplistB=None, topolist=["EQUAL"],
+                               assign_val=False, count_map=False, compare_bool=False,
+                               compare_cmd=False,  compop=None, aggregate=None,
+                               new=False,  convert=False,  operator_cmd=False):
         """Build temporal topology for two space time data sets, copy map objects
           for given relation into map list.
@@ -182,8 +185,8 @@
           :return: List of maps from maplistA that fulfil the topological relationships
                   to maplistB specified in topolist.
                         "FINISHED"]
         complementdict = {"EQUAL": "EQUAL", "FOLLOWS" : "PRECEDES",
                           "PRECEDES" : "FOLLOWS", "OVERLAPS" : "OVERLAPPED",
@@ -284,7 +287,7 @@
             leftsub = sub_cmdstring(map_i)
             rightsub = sub_cmdstring(relmap)
             if operator == None:
-                self.msgr.fatal("Error: Can't build command string for map %s, operator is missing" \
+                self.msgr.fatal("Error: Can't build command string for map %s, operator is missing"
                     %(map_i.get_map_id()))
             cmdstring = "(%s %s %s)" %(leftsub, operator,  rightsub)
         return(cmdstring)
@@ -360,17 +363,17 @@
                 for relationmap in relationmaplist:
                     # Create r.mapcalc expression string for the operation.
                     cmdstring = self.build_command_string(leftcmd,
-        relationmap,
-        operator = operator,
-        cmd_type = "operator")
+                                                          relationmap,
+                                                          operator=operator,
+                                                          cmd_type="operator")
                     leftcmd = cmdstring
         # Add command list to result map.
         map_i.cmd_list = cmdstring
         return(cmdstring)
-    def set_temporal_extent_list(self, maplist, topolist = ["EQUAL"], temporal = 'l' ,
-                                                        cmd_bool = False, cmd_type = None,  operator = None):
+    def set_temporal_extent_list(self, maplist, topolist=["EQUAL"], temporal='l' ,
+                                 cmd_bool=False, cmd_type=None,  operator=None):
         """ Change temporal extent of map list based on temporal relations to
                 other map list and given temporal operator.
@@ -393,8 +396,8 @@
             # Loop over temporal related maps and create overlay modules.
             tbrelations = map_i.get_temporal_relations()
             # Generate an intermediate map for the result map list.
-            map_new = self.generate_new_map(base_map=map_i, bool_op = 'and',
-        copy = True,  rename = True)
+            map_new = self.generate_new_map(base_map=map_i, bool_op='and',
+                                            copy=True,  rename=True)
             # Combine temporal and spatial extents of intermediate map with related maps.
@@ -402,11 +405,11 @@
                     for map_j in (tbrelations[topo]):
                         if temporal == 'r':
                         # Create overlayed map extent.
-                        returncode = self.overlay_map_extent(map_new, map_j, 'and', \
-        temp_op = temporal)
+                        returncode = self.overlay_map_extent(map_new, map_j, 'and',
+                                                             temp_op = temporal)
                         # Stop the loop if no temporal or spatial relationship exist.
                         if returncode == 0:
@@ -418,9 +421,9 @@
                             if cmd_bool:
                                 cmdstring = self.build_command_string(map_i,
-        map_j,
-        cmd_type = cmd_type)
+        map_j,
+        cmd_type=cmd_type)
                                 # Conditional append of module command.
                                 map_new.cmd_list = cmdstring
                             # Write map object to result dictionary.
@@ -436,10 +439,10 @@
         return(resultlist)
-    def build_condition_cmd_list(self, iflist, thenlist,  elselist = None,
-                                                        condition_topolist = ["EQUAL"],
-                                                        conclusion_topolist = ["EQUAL"],
-                                                        temporal = 'l', null = False):
+    def build_condition_cmd_list(self, iflist, thenlist,  elselist=None,
+                                 condition_topolist=["EQUAL"],
+                                 conclusion_topolist=["EQUAL"],
+                                 temporal='l', null=False):
         """This function build the r.mapcalc command strings for spatial conditionals.
             For Example: 'if(a1 == 1, b1, c2)'
@@ -464,10 +467,10 @@
             # Build conclusion command map list.
             conclusiontopolist = self.get_temporal_topo_list(thenlist, elselist,  conclusion_topolist)
             conclusionlist = self.set_temporal_extent_list(conclusiontopolist,
-        topolist = conclusion_topolist,
-        temporal = temporal ,
-        cmd_bool = True,
-        cmd_type = "conclusion")
+                                                           topolist = conclusion_topolist,
+                                                           temporal = temporal ,
+                                                           cmd_bool = True,
+                                                           cmd_type = "conclusion")
         # Check if any conclusion is a numeric statements.
         elif any([isinstance(thenlist, str), isinstance(elselist, str)]):
             conclusionlist = []
@@ -477,9 +480,9 @@
                 numinput = elselist
                 for map_i in listinput:
-                    cmdstring = self.build_command_string( map_i,
-        numinput,
-        cmd_type = 'conclusion')
+                    cmdstring = self.build_command_string(map_i,
+                                                          numinput,
+                                                          cmd_type = 'conclusion')
                     # Append map to result map list.
@@ -491,8 +494,8 @@
                     cmdstring = self.build_command_string(numinput,
-        map_i,
+                                                          map_i,
@@ -509,8 +512,8 @@
             for map_i in iflist:
-        conclusionlist,
-        cmd_type = 'condition')
+                                                      conclusionlist,
+                                                      cmd_type = 'condition')
@@ -519,12 +522,12 @@
         elif isinstance(conclusionlist,  list):
             # Build result command map list between conditions and conclusions.
             conditiontopolist = self.get_temporal_topo_list(iflist, conclusionlist,
-        topolist = condition_topolist)
+                                                            topolist=condition_topolist)
             resultlist = self.set_temporal_extent_list(conditiontopolist,
-        topolist = condition_topolist,
-        temporal = 'r' ,
-        cmd_bool = True,
-        cmd_type = "condition")
+                                                       topolist=condition_topolist,
+                                                       temporal='r',
+                                                       cmd_bool=True,
+                                                       cmd_type="condition")
             return(resultlist)
@@ -543,7 +546,6 @@
             if isinstance(t[3], list):
                 num = len(t[3])
                 count = 0
-                returncode = 0
                 register_list = []
                 for i in range(num):
                     # Check if resultmap names exist in GRASS database.
@@ -572,12 +574,14 @@
                         m_expression = newident + "=" + map_i.cmd_list
                         m.inputs["expression"].value = str(m_expression)
                         m.flags["overwrite"].value = self.overwrite
+                        #print(m.get_bash())
+                        self.process_chain_dict["processes"].append(m.get_dict())
                             process_queue.put(m)
                     elif map_i.map_exists():
-                        # Copy map if it exists
+                        # Copy map if it exists b = a
                         map_test = map_i.get_new_instance(newident + "@" + self.mapset)
                         map_test.set_temporal_extent(map_i.get_temporal_extent())
                         map_test.set_spatial_extent(map_i.get_spatial_extent())
@@ -588,12 +592,16 @@
                     else:
                         self.msgr.error(_("Error computing map <%s>"%map_i.get_id()))
-                    count  += 1
+                    count += 1
                     process_queue.wait()
@@ -603,29 +611,35 @@
                 # Open connection to temporal database.
                 dbif, connect = init_dbif(self.dbif)
                 # Create result space time dataset.
                     resultstds = open_new_stds(t[1], self.stdstype,
                                                'absolute', t[1], t[1],
                                                'mean', self.dbif,
                                                overwrite = self.overwrite)
                 for map_i in register_list:
-                    # Get meta data from grass database.
-                    map_i.load()
-                    # Do not register empty maps if not required
-                    # In case of a null map continue, do not register null maps
-                    if map_i.metadata.get_min() is None and \
-                       map_i.metadata.get_max() is None:
-                        if not self.register_null:
-                            self.removable_maps[map_i.get_name()] = map_i
-                            continue
+                    # Put the map into the process dictionary
+                    start, end = map_i.get_temporal_extent_as_tuple()
+                    self.process_chain_dict["register"].append((map_i.get_name(), str(start), str(end)))
+                        # Get meta data from grass database.
+                        map_i.load()
+                        # Do not register empty maps if not required
+                        # In case of a null map continue, do not register null maps
+                        if map_i.metadata.get_min() is None and \
+                           map_i.metadata.get_max() is None:
+                            if not self.register_null:
+                                self.removable_maps[map_i.get_name()] = map_i
+                                continue
                     if map_i.is_in_db(dbif) and self.overwrite:
                         # Update map in temporal database.
                             map_i.update_all(dbif)
-                    elif map_i.is_in_db(dbif) and self.overwrite == False:
+                    elif map_i.is_in_db(dbif) and self.overwrite is False:
                         # Raise error if map exists and no overwrite flag is given.
                         self.msgr.fatal("Error raster map %s exist in temporal database. "
                                         "Use overwrite flag."%map_i.get_map_id())
@@ -639,6 +653,10 @@
                     resultstds.update_from_registered_maps(dbif)
+                self.process_chain_dict["STDS"]["name"] = t[1]
+                self.process_chain_dict["STDS"]["stdstype"] = self.stdstype
+                self.process_chain_dict["STDS"]["temporal_type"] = 'absolute'
                 dbif.close()
                 t[0] = register_list
                 # Remove intermediate maps
@@ -713,14 +731,14 @@
             resultlist = []
             for map_i in topolist:
-                map_new = self.generate_new_map(base_map=map_i, bool_op = 'and', copy = True)
+                map_new = self.generate_new_map(base_map=map_i, bool_op='and', copy=True)
                 count = 0
                 for map_j in (tbrelations['EQUAL']):
-                                                            temp_op = 'l')
+                                                         temp_op='l')
                     if returncode == 0:
                         break
@@ -733,8 +751,8 @@
                     cmdstring = self.build_command_string(map_i, map_j,
-        operator = t[2],
+                                                          operator=t[2],
                     count += 1
@@ -751,23 +769,23 @@
     def p_arith1_operation_numeric1(self, t):
         expr : stds MOD number
-            | expr MOD number
-            | stds DIV number
-            | expr DIV number
-            | stds MULT number
-            | expr MULT number
-            | stds MOD numberstr
-            | expr MOD numberstr
-            | stds DIV numberstr
-            | expr DIV numberstr
-            | stds MULT numberstr
-            | expr MULT numberstr
-            | stds MOD mapexpr
-            | expr MOD mapexpr
-            | stds DIV mapexpr
-            | expr DIV mapexpr
-            | stds MULT mapexpr
-            | expr MULT mapexpr
+             | expr MOD number
+             | stds DIV number
+             | expr DIV number
+             | stds MULT number
+             | expr MULT number
+             | stds MOD numberstr
+             | expr MOD numberstr
+             | stds DIV numberstr
+             | expr DIV numberstr
+             | stds MULT numberstr
+             | expr MULT numberstr
+             | stds MOD mapexpr
+             | expr MOD mapexpr
+             | stds DIV mapexpr
+             | expr DIV mapexpr
+             | stds MULT mapexpr
+             | expr MULT mapexpr
         # Check input stds.
@@ -796,23 +814,23 @@
     def p_arith1_operation_numeric2(self, t):
         expr : number MOD stds
-            | number MOD expr
-            | number DIV stds
-            | number DIV expr
-            | number MULT stds
-            | number MULT expr
-            | numberstr MOD stds
-            | numberstr MOD expr
-            | numberstr DIV stds
-            | numberstr DIV expr
-            | numberstr MULT stds
-            | numberstr MULT expr
-            | mapexpr MOD stds
-            | mapexpr MOD expr
-            | mapexpr DIV stds
-            | mapexpr DIV expr
-            | mapexpr MULT stds
-            | mapexpr MULT expr
+             | number MOD expr
+             | number DIV stds
+             | number DIV expr
+             | number MULT stds
+             | number MULT expr
+             | numberstr MOD stds
+             | numberstr MOD expr
+             | numberstr DIV stds
+             | numberstr DIV expr
+             | numberstr MULT stds
+             | numberstr MULT expr
+             | mapexpr MOD stds
+             | mapexpr MOD expr
+             | mapexpr DIV stds
+             | mapexpr DIV expr
+             | mapexpr MULT stds
+             | mapexpr MULT expr
         # Check input stds.
         maplist = self.check_stds(t[3])
@@ -863,15 +881,15 @@
             resultlist = []
                 count = 0
-                                                            temp_op = 'l')
+                                                         temp_op='l')
                     if returncode == 0:
                         break
@@ -884,8 +902,8 @@
-        operator = t[2],
+                                                          operator=t[2],
                     count += 1
@@ -903,17 +921,17 @@
     def p_arith2_operation_numeric1(self, t):
         expr : stds ADD number
-            | expr ADD number
-            | stds SUB number
-            | expr SUB number
-            | stds ADD numberstr
-            | expr ADD numberstr
-            | stds SUB numberstr
-            | expr SUB numberstr
-            | stds ADD mapexpr
-            | expr ADD mapexpr
-            | stds SUB mapexpr
-            | expr SUB mapexpr
+             | expr ADD number
+             | stds SUB number
+             | expr SUB number
+             | stds ADD numberstr
+             | expr ADD numberstr
+             | stds SUB numberstr
+             | expr SUB numberstr
+             | stds ADD mapexpr
+             | expr ADD mapexpr
+             | stds SUB mapexpr
+             | expr SUB mapexpr
         # Check input stds.
@@ -941,17 +959,17 @@
     def p_arith2_operation_numeric2(self, t):
         expr : number ADD stds
-            | number ADD expr
-            | number SUB stds
-            | number SUB expr
-            | numberstr ADD stds
-            | numberstr ADD expr
-            | numberstr SUB stds
-            | numberstr SUB expr
-            | mapexpr ADD stds
-            | mapexpr ADD expr
-            | mapexpr SUB stds
-            | mapexpr SUB expr
+             | number ADD expr
+             | number SUB stds
+             | number SUB expr
+             | numberstr ADD stds
+             | numberstr ADD expr
+             | numberstr SUB stds
+             | numberstr SUB expr
+             | mapexpr ADD stds
+             | mapexpr ADD expr
+             | mapexpr SUB stds
+             | mapexpr SUB expr
         # Check input stds.
@@ -989,13 +1007,13 @@
             # Check input stds.
-            relations, temporal, function, aggregate = self.eval_toperator(t[2],  optype = 'raster')
+            relations, temporal, function, aggregate = self.eval_toperator(t[2],  optype='raster')
-            complist = self.get_temporal_topo_list(maplistA, maplistB, topolist = relations,
-                               operator_cmd = True, compop = function)
+            complist = self.get_temporal_topo_list(maplistA, maplistB, topolist=relations,
+                                                   operator_cmd=True, compop=function)
         t[0] = resultlist
@@ -1018,11 +1036,11 @@
         t[0] = resultlist
@@ -1033,10 +1051,10 @@
     def p_arith_operation_numeric_string(self, t):
         numberstr : number ADD number
-            | number SUB number
-            | number DIV number
-            | number MULT number
-            | number MOD number
+                  | number SUB number
+                  | number DIV number
+                  | number MULT number
+                  | number MOD number
         numstring = "(%s %s %s)" %(t[1], t[2], t[3])
@@ -1064,8 +1082,7 @@
         t[0] = t[1]
         if self.debug:
-            for map in resultlist:
-                print(map.cmd_list)
+            print(t[1])
     def p_mapcalc_operation1(self, t):
@@ -1248,8 +1265,9 @@
             aggregate = t[2]
-            complist = self.get_temporal_topo_list(s_var_exprA, s_var_exprB, topolist = relations,
-                               compare_cmd = True, compop = function, aggregate = aggregate)
+            complist = self.get_temporal_topo_list(s_var_exprA, s_var_exprB, topolist=relations,
+                                                   compare_cmd=True, compop=function,
@@ -1272,13 +1290,14 @@
             s_var_exprA = self.check_stds(t[1])
             s_var_exprB = self.check_stds(t[3])
             t[0] = resultlist
@@ -1299,10 +1318,10 @@
         ifmaplist = self.check_stds(t[3])
         thenmaplist = self.check_stds(t[5])
         resultlist = self.build_condition_cmd_list(ifmaplist, thenmaplist,
-        elselist = None,
-        temporal = 'r', null = False)
+                                                   elselist=None,
+                                                   temporal='r', null=False)
         t[0] = resultlist
         if self.debug:
@@ -1355,10 +1374,10 @@
         ifmaplist = self.check_stds(t[5])
         thenmaplist = self.check_stds(t[7])
-        elselist = None,
-        condition_topolist = relations,
+                                                   elselist=None,
+                                                   condition_topolist=relations,
         t[0] = resultlist
         if self.debug:
@@ -1384,10 +1403,10 @@
         elsemaplist = self.check_stds(t[7])
         # Create conditional command map list.
-        elselist = elsemaplist,
+                                                   elselist=elsemaplist,
         t[0] = resultlist
@@ -1429,9 +1448,9 @@
         print(numthen + " " +numelse )
         resultlist = self.build_condition_cmd_list(ifmaplist, numthen,  numelse,
         t[0] = resultlist
@@ -1480,9 +1499,9 @@
         resultlist = self.build_condition_cmd_list(ifmaplist, theninput,  elseinput,
         t[0] = resultlist
@@ -1532,9 +1551,9 @@
         t[0] = resultlist
@@ -1563,9 +1582,9 @@
         resultlist = self.build_condition_cmd_list(ifmaplist, thenmaplist,  elsemaplist,
         t[0] = resultlist
@@ -1604,12 +1623,12 @@
             aggregate = t[2]
-        topolist = relations, compare_cmd = True,
-        compop = function, aggregate = aggregate,
-        convert = True)
+                                                   topolist=relations, compare_cmd=True,
+                                                   compop=function, aggregate=aggregate,
+                                                   convert=True)
         t[0] = resultlist
Modified: grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_algebra_mixed_stds.py
--- grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_algebra_mixed_stds.py	2016-07-21 13:03:39 UTC (rev 69015)
+++ grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_algebra_mixed_stds.py	2016-07-21 17:33:41 UTC (rev 69016)
@@ -31,26 +31,24 @@
         cls.runModule("r3.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
         tgis.open_new_stds(name="A", type="str3ds", temporaltype="absolute",
-                                         title="A", descr="A", semantic="field", overwrite=True)
+                           title="A", descr="A", semantic="field", overwrite=True)
         tgis.register_maps_in_space_time_dataset(type="raster3d", name="A", maps="a1,a2,a3,a4",
                                                  start="2001-01-01", increment="1 day", interval=True)
         cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b1 = 5")
         cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b2 = 6")
         tgis.open_new_stds(name="B", type="strds", temporaltype="absolute",
-                                         title="B", descr="B", semantic="field", overwrite=True)
+                           title="B", descr="B", semantic="field", overwrite=True)
         tgis.register_maps_in_space_time_dataset(type="raster", name="B", maps="b1,b2",
                                                  start="2001-01-01", increment="2 day", interval=True)
         cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=3,  output='c1')
         tgis.open_new_stds(name="C", type="stvds", temporaltype="absolute",
-                                         title="B", descr="C", semantic="field", overwrite=True)
+                           title="B", descr="C", semantic="field", overwrite=True)
         tgis.register_maps_in_space_time_dataset(type="vector", name="C", maps="c1",
                                                  start="2001-01-02", increment="2 day", interval=True)
@@ -59,15 +57,16 @@
     def tearDownClass(cls):
         """Remove the temporary region
-        cls.runModule("t.remove", flags="rf", type="str3ds",  inputs="A", quiet=True)
+        cls.runModule("t.remove", flags="rf", type="str3ds", inputs="A", quiet=True)
         cls.runModule("t.remove", flags="rf", type="strds", inputs="B", quiet=True)
         cls.runModule("t.remove", flags="rf", type="stvds", inputs="C", quiet=True)
         cls.del_temp_region()
     def test_temporal_select_operators1(self):
         """Testing the temporal select operator. Including temporal relations. """
-        ta = tgis.TemporalAlgebraParser(run = True, debug = True)
-        ta.parse(expression="R = A {:,during} stvds(C)",  stdstype = 'str3ds', basename="r", overwrite=True)
+        ta = tgis.TemporalAlgebraParser(run=True, debug=True)
+        ta.parse(expression="R = A {:,during} stvds(C)",
+                 stdstype='str3ds', basename="r", overwrite=True)
         D = tgis.open_old_stds("R", type="str3ds")
         D.select()
@@ -80,10 +79,21 @@
         self.assertEqual( D.check_temporal_topology(),  True)
         self.assertEqual(D.get_granularity(),  u'1 day')
+        ta = tgis.TemporalAlgebraParser(run=True, debug=True, dry_run=True)
+        pc = ta.parse(expression="R = A {:,during} stvds(C)",
+        print(pc)
+        self.assertEqual(len(pc["register"]), 2)
+        self.assertEqual(pc["STDS"]["name"], "R")
+        self.assertEqual(pc["STDS"]["stdstype"], "str3ds")
     def test_temporal_select_operators2(self):
-        ta.parse(expression="R = A {:,equal|during} stvds(C)",  stdstype = 'str3ds', basename="r", overwrite=True)
+        ta.parse(expression="R = A {:,equal|during} stvds(C)",
         D.select()
@@ -96,11 +106,23 @@
+                                        dry_run=True)
+        pc = ta.parse(expression="R = A {:,equal|during} stvds(C)",
+        print(pc)
     def test_temporal_select_operators3(self):
             and negation operation. """
-        ta.parse(expression="R = A {!:,during} stvds(C)",  stdstype = 'str3ds', basename="r", overwrite=True)
+        ta.parse(expression="R = A {!:,during} stvds(C)",
         D.select()
@@ -116,13 +138,12 @@
     def test_temporal_select_operators4(self):
         """Testing the temporal select operator. Including temporal relations and
             temporal operators. """
         ta.parse(expression="V = C {:,contains} str3ds(A)",
-                       stdstype = 'stvds', basename="r", overwrite=True)
+                 stdstype='stvds', basename="r", overwrite=True)
         D = tgis.open_old_stds("V", type="stvds")
         D.select()
-        maplist = D.get_registered_maps_as_objects()
         self.assertEqual(D.metadata.get_number_of_maps(), 1)
         start, end = D.get_absolute_time()
         self.assertEqual(start, datetime.datetime(2001, 1, 2))
@@ -133,13 +154,12 @@
     def test_temporal_select_operators5(self):
         ta.parse(expression="R = A {:,during} strds(B)",
-                       stdstype = 'str3ds', basename="r", overwrite=True)
         D.select()
         self.assertEqual(D.metadata.get_number_of_maps(), 4)
         self.assertEqual(start, datetime.datetime(2001, 1, 1))
@@ -149,14 +169,12 @@
     def test_temporal_hash_operator1(self):
         """Testing the hash operator function in conditional statement. """
         ta.parse(expression="R = if(A {#,during} stvds(C) == 1, A)",
-                       basename="r", overwrite=True)
         D.select()
         self.assertEqual(D.metadata.get_number_of_maps(), 2)
         self.assertEqual(D.metadata.get_min_min(), 2)
         self.assertEqual(D.metadata.get_max_max(), 3)
@@ -168,39 +186,49 @@
     def test_temporal_hash_operator2(self):
         ta.parse(expression="R = if({during}, stvds(C) {#,contains} A == 2, A)",
         D.select()
         self.assertEqual(end, datetime.datetime(2001, 1, 4))
-        self.assertEqual( D.check_temporal_topology(),  True)
+        self.assertEqual(D.check_temporal_topology(),  True)
-    def test_different_stds_handling(self):
+    def test_different_stds_handling1(self):
         """Testing the handling of different stds types as output. """
         ta.parse(expression="R = if({during}, stvds(C) {#,contains} str3ds(A) == 2, str3ds(A))",
-                                                 stdstype = 'strds', basename="r", overwrite=True)
+                 stdstype='strds', basename="r", overwrite=True)
         D.select()
+    def test_different_stds_handling2(self):
+        """Testing the handling of different stds types as output. """
+                                        dry_run=True)
+        pc = ta.parse(expression="R = if({during}, (stvds(C) {#,contains} str3ds(A)) == 2, str3ds(A))",
+        self.assertEqual(pc["STDS"]["stdstype"], "strds")
 if __name__ == '__main__':
     test()
Modified: grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_conditionals.py
--- grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_conditionals.py	2016-07-21 13:03:39 UTC (rev 69015)
+++ grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_conditionals.py	2016-07-21 17:33:41 UTC (rev 69016)
@@ -77,7 +77,7 @@
     def test_temporal_condition_1(self):
         """Testing the temporal select operator with equal relations. """
         ta.parse(expression='R = if(start_date(A) >= "2001-01-03", A)', basename="r", overwrite=True)
         D = tgis.open_old_stds("R", type="strds")
@@ -93,7 +93,7 @@
     def test_temporal_condition_2(self):
         ta.parse(expression='R = if(td(A) == 1, A)', basename="r", overwrite=True)
@@ -109,7 +109,7 @@
     def test_temporal_condition_3(self):
         ta.parse(expression='R = if(td(A) == 1 || start_date(A) >= "2001-01-03", A)', basename="r", overwrite=True)
@@ -125,7 +125,7 @@
     def test_temporal_condition_4(self):
@@ -141,7 +141,7 @@
     def test_temporal_condition_5(self):
         ta.parse(expression='R = if(start_day(A) <= 2, A)', basename="r", overwrite=True)
@@ -157,8 +157,9 @@
     def test_temporal_condition_6(self):
-        ta.parse(expression='R = if(td(A) == 1 {||,during} start_date(C) < "2001-01-02", A)', basename="r", overwrite=True)
+        ta.parse(expression='R = if(td(A) == 1 {||,during} start_date(C) < "2001-01-02", A)',
+                 basename="r", overwrite=True)
         D.select()
@@ -173,8 +174,9 @@
     def test_temporal_condition_7(self):
-        ta.parse(expression='R = if({over},start_date(C) == "2001-01-02" {&&,contains} td(A) == 1, B)', basename="r", overwrite=True)
+        ta.parse(expression='R = if({over},start_date(C) == "2001-01-02" {&&,contains} td(A) == 1, B)',
         D.select()
@@ -189,8 +191,9 @@
     def test_temporal_condition_8(self):
-        ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {||,over,|} td(E) == 2, B)', basename="r", overwrite=True)
+        ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {||,over,|} td(E) == 2, B)',
         D.select()
@@ -205,8 +208,9 @@
     def test_temporal_condition_9(self):
-        ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {&&,over,&} td(E) == 2, B)', basename="r", overwrite=True)
+        ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {&&,over,&} td(E) == 2, B)',
         D.select()
@@ -221,8 +225,9 @@
     def test_temporal_condition_10(self):
-        ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {||,over,|,r} td(E) == 2, E)', basename="r", overwrite=True)
+        ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {||,over,|,r} td(E) == 2, E)',
         D.select()
@@ -237,8 +242,9 @@
     def test_temporal_condition_11(self):
-        ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {&&,over,r} td(E) == 2, E)', basename="r", overwrite=True)
+        ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {&&,over,r} td(E) == 2, E)',
         D.select()
@@ -253,8 +259,9 @@
     def test_temporal_condition_12(self):
-        ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {&&,over,|,r} td(E) == 2, E)', basename="r", overwrite=True)
+        ta.parse(expression='R = if(start_date(B) <= "2001-01-01" {&&,over,|,r} td(E) == 2, E)',
         D.select()
@@ -269,8 +276,9 @@
     def test_temporal_conditional_13(self):
-        ta.parse(expression='R = if({equal|during},td(B) == 2 {&&,contains} td(A) == 1, A)', basename="r", overwrite=True)
+        ta.parse(expression='R = if({equal|during},td(B) == 2 {&&,contains} td(A) == 1, A)',
         D.select()
@@ -286,8 +294,9 @@
     def test_temporal_condition_else_1(self):
-        ta.parse(expression='R = if(start_date(A) <= "2001-01-03", A, D)', basename="r", overwrite=True)
+        ta.parse(expression='R = if(start_date(A) <= "2001-01-03", A, D)',
         D.select()
@@ -302,8 +311,9 @@
     def test_temporal_condition_else_2(self):
-        ta.parse(expression='R = if(td(D) == 1 && start_date(A) >= "2001-01-04", A, D)', basename="r", overwrite=True)
+        ta.parse(expression='R = if(td(D) == 1 && start_date(A) >= "2001-01-04", A, D)',
         D.select()
@@ -318,13 +328,14 @@
     def test_temporal_condition_else_3(self):
-        ta.parse(expression='R = if({during},td(B) == 2 {&&,contains} start_date(D) >= "2001-01-04", A, D)', basename="r", overwrite=True)
+        ta.parse(expression='R = if({during},td(B) == 2 {&&,contains} start_date(D) >= "2001-01-04", A, D)',
         D.select()
-        self.assertEqual(D.metadata.get_min_min(), 8)
+        self.assertEqual(D.metadata.get_min_min(), 8)
         self.assertEqual(D.metadata.get_max_max(), 9)
         self.assertEqual(start, datetime.datetime(2001, 1, 3))
@@ -334,8 +345,9 @@
     def test_temporal_condition_else_4(self):
-        ta.parse(expression='R = if({equal|over},start_date(B) <= "2001-01-01" {&&,over,|,r} td(E) == 2, E, B)', basename="r", overwrite=True)
+        ta.parse(expression='R = if({equal|over},start_date(B) <= "2001-01-01" {&&,over,|,r} td(E) == 2, E, B)',
         D.select()
Modified: grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
--- grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py	2016-07-21 13:03:39 UTC (rev 69015)
+++ grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py	2016-07-21 17:33:41 UTC (rev 69016)
@@ -70,7 +70,7 @@
     def test_temporal_extent1(self):
         """Testing the temporal extent operators. """
-        ta = tgis.TemporalRasterAlgebraParser(run = True, debug = True)
+        ta = tgis.TemporalRasterAlgebraParser(run=True, debug=True)
         ta.parse(expression="R = A {:,during,r} C",   basename="r", overwrite=True)
@@ -84,12 +84,22 @@
         self.assertEqual( D.check_temporal_topology(),  False)
         self.assertEqual(D.get_granularity(),  u'2 days')
+        ta = tgis.TemporalRasterAlgebraParser(run=True, debug=True, dry_run=True)
+        pc = ta.parse(expression="R = A {:,during,r} C", basename="r", overwrite=True)
+        self.assertEqual(len(pc["processes"]), 2)
+        self.assertEqual(pc["processes"][0]["name"], "r.mapcalc")
+        self.assertEqual(pc["processes"][1]["name"], "r.mapcalc")
     def test_temporal_conditional_time_dimension_bug(self):
-        """Testing the conditional time dimension bug, that uses the time
-            dimension of the conditional statement instead the time dimension
+        """Testing the conditional time dimension bug, that uses the time
+            dimension of the conditional statement instead the time dimension
             of the then/else statement."""
-        tra = tgis.TemporalRasterAlgebraParser(run = True, debug = True)
+        tra = tgis.TemporalRasterAlgebraParser(run=True, debug=True)
         tra.parse(expression="R = if({contains}, B == 5,  A - 1,  A + 1)", basename="r", overwrite=True)
@@ -105,7 +115,7 @@
     def test_simple_arith_hash_1(self):
         """Simple arithmetic test including the hash operator"""
         tra.parse(expression='R = A + (A {#, equal,l} A)', basename="r", overwrite=True)
@@ -120,7 +130,7 @@
     def test_simple_arith_td_1(self):
         """Simple arithmetic test"""
         tra.parse(expression='R = A + td(A)', basename="r", overwrite=True)
@@ -134,7 +144,7 @@
     def test_simple_arith_td_2(self):
         tra.parse(expression='R = A / td(A)', basename="r", overwrite=True)
@@ -148,7 +158,7 @@
     def test_simple_arith_td_3(self):
         tra.parse(expression='R = A {+,equal} td(A)', basename="r", overwrite=True)
@@ -163,7 +173,7 @@
     def test_simple_arith_td_4(self):
         tra.parse(expression='R = A {/, equal} td(A)', basename="r", overwrite=True)
@@ -178,7 +188,7 @@
     def test_simple_arith_if_1(self):
         """Simple arithmetic test with if condition"""
         tra.parse(expression='R = if({equal}, start_date(A) >= "2001-01-02", A + A)', basename="r", overwrite=True)
@@ -192,7 +202,7 @@
     def test_simple_arith_if_2(self):
         tra.parse(expression='R = if({equal}, A#A == 1, A - A)', basename="r", overwrite=True)
@@ -206,7 +216,7 @@
     def test_complex_arith_if_1(self):
         """Complex arithmetic test with if condition"""
         tra.parse(expression='R = if(start_date(A) < "2001-01-03" && A#A == 1, A{+, starts,l}C, A{+, finishes,l}C)', \
@@ -221,7 +231,7 @@
     def test_simple_arith_1(self):
         tra.parse(expression="R = A {*, equal} A {+, equal} A", basename="r", overwrite=True)
@@ -235,7 +245,7 @@
     def test_simple_arith_2(self):
         """Simple arithmetic test that creates an empty strds"""
         tra.parse(expression="R = A {*, during} A {+, during} A", basename="r", overwrite=True)
         D.select()
@@ -243,7 +253,7 @@
     def test_simple_arith_3(self):
         tra.parse(expression="R = A / A + A*A/A", basename="r", overwrite=True)
@@ -254,10 +264,10 @@
         self.assertEqual(end, datetime.datetime(2001, 1, 5))
     def test_temporal_intersection_1(self):
         """Simple temporal intersection test"""
         tra.parse(expression="R = A {+,equal,i} B", basename="r", overwrite=True)
         D.select()
@@ -265,7 +275,7 @@
     def test_temporal_intersection_2(self):
         tra.parse(expression="R = A {+,during,i} B", basename="r", overwrite=True)
@@ -279,7 +289,7 @@
     def test_temporal_intersection_3(self):
         tra.parse(expression="R = A {+,starts,i} B", basename="r", overwrite=True)
@@ -293,7 +303,7 @@
     def test_temporal_intersection_4(self):
         tra.parse(expression="R = A {+,finishes,intersect} B", basename="r", overwrite=True)
@@ -307,7 +317,7 @@
     def test_temporal_intersection_5(self):
         tra.parse(expression="R = A {+,starts|finishes,i} B", basename="r", overwrite=True)
@@ -321,7 +331,7 @@
     def test_temporal_intersection_6(self):
         tra.parse(expression="R = B {+,overlaps,u} C", basename="r", overwrite=True)
@@ -335,7 +345,7 @@
     def test_temporal_intersection_7(self):
         tra.parse(expression="R = B {+,overlapped,u} C", basename="r", overwrite=True)
@@ -349,7 +359,7 @@
     def test_temporal_intersection_8(self):
         tra.parse(expression='R = A {+,during,l} buff_t(C, "1 day") ',
@@ -364,7 +374,7 @@
     def test_temporal_neighbors_1(self):
         """Simple temporal neighborhood computation test"""
         tra.parse(expression='R = A[-1] + A[1]',
@@ -379,7 +389,7 @@
     def test_temporal_neighbors_2(self):
         tra.parse(expression='R = A[0,0,-1] + A[0,0,1]',
@@ -394,15 +404,15 @@
     def test_tmap_function1(self):
         """Testing the tmap function. """
         tra.parse(expression='R = tmap(singletmap)', basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_min_min(), 99)
-        self.assertEqual(D.metadata.get_max_max(), 99)
+        self.assertEqual(D.metadata.get_min_min(), 99)
+        self.assertEqual(D.metadata.get_max_max(), 99)
@@ -411,15 +421,15 @@
     def test_tmap_function2(self):
         tra.parse(expression='R = tmap(singletmap) + 1', basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_min_min(), 100)
-        self.assertEqual(D.metadata.get_max_max(), 100)
+        self.assertEqual(D.metadata.get_min_min(), 100)
+        self.assertEqual(D.metadata.get_max_max(), 100)
@@ -428,15 +438,15 @@
     def test_map_function1(self):
         """Testing the map function. """
         tra.parse(expression='R = map(singlemap) + A', basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_min_min(), 101)
-        self.assertEqual(D.metadata.get_max_max(), 104)
+        self.assertEqual(D.metadata.get_min_min(), 101)
+        self.assertEqual(D.metadata.get_max_max(), 104)
@@ -445,15 +455,15 @@
     def test_map_function2(self):
         tra.parse(expression='R =  A * map(singlemap)', basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_max_max(), 400)
+        self.assertEqual(D.metadata.get_max_max(), 400)
@@ -462,14 +472,14 @@
     def test_temporal_select(self):
         """Testing the temporal select operator. """
         tra.parse(expression="R = A : A", basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_min_min(), 1)
-        self.assertEqual(D.metadata.get_max_max(), 4)
+        self.assertEqual(D.metadata.get_min_min(), 1)
+        self.assertEqual(D.metadata.get_max_max(), 4)
@@ -478,14 +488,14 @@
         tra.parse(expression="R = A : D", basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_min_min(), 3)
+        self.assertEqual(D.metadata.get_min_min(), 3)
@@ -494,14 +504,14 @@
         D.select()
@@ -510,14 +520,14 @@
         tra.parse(expression="R = A {!:,during} C", basename="r", overwrite=True)
         D.select()
@@ -525,16 +535,16 @@
-        """Testing the temporal select operator. Including temporal relations and
+        """Testing the temporal select operator. Including temporal relations and
             different temporal operators (lr|+&)"""
         tra.parse(expression="R = A {:,during,d} B", basename="r", overwrite=True)
         D.select()
@@ -542,9 +552,9 @@
         tra.parse(expression="R = A {:,equal|during,r} C", basename="r", overwrite=True)
@@ -565,14 +575,14 @@
         """Testing the temporal hash operator in the raster algebra. """
         tra.parse(expression="R = if(A # D == 1, A)", basename="r", overwrite=True)
         D.select()
@@ -581,14 +591,14 @@
         tra.parse(expression="R = A # D", basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_max_max(), 1)
+        self.assertEqual(D.metadata.get_max_max(), 1)
@@ -597,14 +607,14 @@
     def test_temporal_hash_operator3(self):
         tra.parse(expression="R = C {#,contains} A", basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_min_min(), 2)
-        self.assertEqual(D.metadata.get_max_max(), 2)
+        self.assertEqual(D.metadata.get_min_min(), 2)
+        self.assertEqual(D.metadata.get_max_max(), 2)
@@ -613,30 +623,30 @@
     def test_temporal_hash_operator4(self):
         tra.parse(expression="R = if({contains},A # D == 1, C {#,contains} A)", basename="r", overwrite=True)
         D.select()
     def test_raster_arithmetic_relation_1(self):
         """Arithmetic test with temporal intersection"""
         tra.parse(expression="R = B {+,contains,l} A ", basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_max_max(), 13)
+        self.assertEqual(D.metadata.get_max_max(), 13)
@@ -645,14 +655,14 @@
     def test_raster_arithmetic_relation_2(self):
         tra.parse(expression="R = B {*,contains,l} A ", basename="r", overwrite=True)
         D.select()
-        self.assertEqual(D.metadata.get_min_min(), 10)
-        self.assertEqual(D.metadata.get_max_max(), 72)
+        self.assertEqual(D.metadata.get_min_min(), 10)
+        self.assertEqual(D.metadata.get_max_max(), 72)
@@ -661,45 +671,45 @@
     def test_raster_arithmetic_relation_3(self):
         D.select()
     def test_raster_arithmetic_relation_4(self):
         tra.parse(expression="R = B {+,contains,r} A ", basename="r", overwrite=True)
         D.select()
         self.assertEqual(D.metadata.get_number_of_maps(),4)
     def test_raster_arithmetic_relation_5(self):
         """Complex arithmetic test with temporal intersection"""
         tra.parse(expression="R = tmap(singletmap) {+,equal| precedes| follows,l} A + map(singlemap)", basename="r", overwrite=True)
         D.select()
         self.assertEqual(D.metadata.get_number_of_maps(),1)
-        self.assertEqual(D.metadata.get_min_min(), 208)
+        self.assertEqual(D.metadata.get_min_min(), 208)
         self.assertEqual(D.metadata.get_max_max(), 208)
Modified: grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py
--- grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py	2016-07-21 13:03:39 UTC (rev 69015)
+++ grass/branches/releasebranch_7_2/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py	2016-07-21 17:33:41 UTC (rev 69016)
@@ -37,6 +37,7 @@
         cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d2 = 11")
         cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="d3 = 12")
         cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="singletmap = 99")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="nullmap = null()")
         tgis.open_new_stds(name="A", type="strds", temporaltype="absolute",
@@ -61,6 +62,8 @@
                                                  start="2001-05-01", increment="5 days", interval=True)
         tgis.register_maps_in_space_time_dataset(type="raster", name=None,  maps="singletmap",
                                                 start="2001-03-01", end="2001-04-01")
+        tgis.register_maps_in_space_time_dataset(type="raster", name=None,  maps="nullmap",
+                                                start="2001-01-01", end="2001-07-01")
     def tearDown(self):
         return
@@ -95,13 +98,87 @@
         self.assertEqual(D.get_granularity(),  u'1 month')
+        tra = tgis.TemporalRasterAlgebraParser(run=True, debug=True, dry_run=True)
+        tra.setup_common_granularity(expression=expr,  lexer = tgis.TemporalRasterAlgebraLexer())
+        pc = tra.parse(expression=expr, basename="r", overwrite=True)
+        self.assertEqual(len(pc["register"]), 6)
+        self.assertEqual(len(pc["processes"]), 6)
+        self.assertEqual(pc["processes"][5]["name"], "r.mapcalc")
     def test_2(self):
         """Simple arithmetik test"""
+        expr = "R = A + B + C"
+        ret = tra.setup_common_granularity(expression=expr,  lexer = tgis.TemporalRasterAlgebraLexer())
+        self.assertEqual(ret, True)
+        tra.parse(expression=expr, basename="r", overwrite=True)
+        D = tgis.open_old_stds("R", type="strds")
+        self.assertEqual(D.metadata.get_number_of_maps(), 6)
+        self.assertEqual(D.metadata.get_min_min(), 17) # 1 + 7 + 9
+        self.assertEqual(D.metadata.get_max_max(), 23) # 6 + 8 + 9
+        start, end = D.get_absolute_time()
+        self.assertEqual(start, datetime.datetime(2001, 1, 1))
+        self.assertEqual(end, datetime.datetime(2001, 7, 1))
+        self.assertEqual( D.check_temporal_topology(),  True)
+        self.assertEqual(D.get_granularity(),  u'1 month')
+    def test_3(self):
+        """Simple arithmetik test with null map"""
+        tra = tgis.TemporalRasterAlgebraParser(run = True, debug = True)
+        expr = "R = A + B + C + tmap(nullmap)"
+                                           lexer=tgis.TemporalRasterAlgebraLexer())
+        self.assertEqual(D.metadata.get_number_of_maps(), 0)
+        self.assertEqual(D.metadata.get_min_min(), None)
+        self.assertEqual(D.metadata.get_max_max(), None)
+        self.assertEqual(start, None)
+        self.assertEqual(end, None)
+        self.assertEqual( D.check_temporal_topology(),  False)
+        self.assertEqual(D.get_granularity(),  None)
+        print(pc)
+        self.assertEqual(len(pc["register"]), 0)
+        self.assertEqual(len(pc["processes"]), 0)
+    def test_4(self):
+        """Simple arithmetik test"""
         expr = "R = if(D == 11,  A - 1, A + 1)"
@@ -149,7 +226,7 @@
         expr = 'R = A + td(A:D)'
@@ -169,7 +246,7 @@
         expr = 'R = if(start_date(A) >= "2001-02-01", A + A)'
@@ -187,7 +264,7 @@
         expr = 'R = if(A#A == 1, A - A)'
@@ -205,7 +282,7 @@
         expr = 'R = if(start_date(A) < "2001-03-01" && A#A == 1, A+C, A-C)'
@@ -223,7 +300,7 @@
         expr ='R = (A[0,0,-1] : D) + (A[0,0,1] : D)'
@@ -234,14 +311,14 @@
         self.assertEqual(end, datetime.datetime(2001, 5, 6))
     def test_map(self):
         """Test STDS + single map without timestamp"""
         expr = "R = A + map(singletmap)"
@@ -252,20 +329,20 @@
     def test_tmap_map(self):
         """Test STDS + single map with and without timestamp"""
         expr = "R = tmap(singletmap) + A + map(singletmap)"
-        self.assertEqual(D.metadata.get_min_min(), 201)
+        self.assertEqual(D.metadata.get_min_min(), 201)
         self.assertEqual(D.metadata.get_max_max(), 201)
         self.assertEqual(start, datetime.datetime(2001, 3, 1))
