[GRASS-SVN] r69025 - grass/branches/releasebranch_7_2/lib/python/temporal
svn_grass at osgeo.org
Fri Jul 22 05:33:52 PDT 2016
Author: huhabla
Date: 2016-07-22 05:33:52 -0700 (Fri, 22 Jul 2016)
New Revision: 69025
grass/branches/releasebranch_7_2/lib/python/temporal/temporal_operator.py
temporal framework: Better error handling for temporal operators
Modified: grass/branches/releasebranch_7_2/lib/python/temporal/temporal_operator.py
--- grass/branches/releasebranch_7_2/lib/python/temporal/temporal_operator.py 2016-07-22 10:57:47 UTC (rev 69024)
+++ grass/branches/releasebranch_7_2/lib/python/temporal/temporal_operator.py 2016-07-22 12:33:52 UTC (rev 69025)
@@ -24,32 +24,32 @@
>>> p = TemporalOperatorParser()
>>> expression = "{&&, during}"
>>> p.parse(expression, optype = 'boolean')
- >>> print((p.relations, p.temporal, p.function,p.aggregate))
+ >>> print((p.relations, p.temporal, p.function, p.aggregate))
(['during'], 'l', '&&', '&')
>>> expression = "{||, equal | during}"
(['equal', 'during'], 'l', '||', '|')
>>> expression = "{||, equal | during, &}"
(['equal', 'during'], 'l', '||', '&')
>>> expression = "{&&, during, |}"
(['during'], 'l', '&&', '|')
>>> expression = "{&&, during, |, r}"
(['during'], 'r', '&&', '|')
>>> expression = "{&&, during, u}"
(['during'], 'u', '&&', '&')
>>> expression = "{:, during, r}"
@@ -101,6 +101,36 @@
>>> p.parse(expression, optype = 'overlay')
>>> print((p.relations, p.temporal, p.function))
(['overlaps', 'overlapped'], 'r', '^')
+ >>> p = TemporalOperatorParser()
+ >>> expression = "{&&, equal | during | contains | starts, &}"
+ >>> p.parse(expression, optype = 'boolean')
+ (['equal', 'during', 'contains', 'starts'], 'l', '&&', '&')
+ >>> expression = "{&&, equal | during | contains | starts, &&&&&}"
+ Traceback (most recent call last):
+ SyntaxError: Unexpected syntax error in expression "{&&, equal | during | contains | starts, &&&&&}" at position 42 near &
+ >>> expression = "{+, starting}"
+ >>> p.parse(expression)
+ SyntaxError: syntax error on line 1 position 4 near 'starting'
+ >>> expression = "{nope, start, |, l}"
+ SyntaxError: syntax error on line 1 position 1 near 'nope'
+ >>> expression = "{++, start, |, l}"
+ SyntaxError: Unexpected syntax error in expression "{++, start, |, l}" at position 2 near +
+ >>> expression = "{^, over, right}"
+ >>> p.parse(expression, optype='rter')
+ SyntaxError: Unknown optype rter, must be one of ['select', 'boolean', 'raster', 'hash', 'relation', 'overlay']
from __future__ import print_function
@@ -163,7 +193,7 @@
t_T_NOT_SELECT = r'!:'
t_COMMA = r','
t_LEFTREF = '^[l|left]'
- t_RIGHTREF ='^[r|right]'
+ t_RIGHTREF = '^[r|right]'
t_UNION = '^[u|union]'
t_DISJOINT = '^[d|disjoint]'
t_INTERSECT = '^[i|intersect]'
@@ -182,7 +212,7 @@
t_CRPAREN = r'\}'
# These are the things that should be ignored.
- t_ignore = ' \t'
+ t_ignore = ' \t\n'
# Track line numbers.
def t_newline(self, t):
@@ -191,8 +221,7 @@
def t_NAME(self, t):
r'[a-zA-Z_][a-zA-Z_0-9]*'
- self.temporal_symbol(t)
- return t
+ return self.temporal_symbol(t)
# Parse symbols
def temporal_symbol(self, t):
@@ -214,14 +243,14 @@
elif t.value == 'i' or t.value == 'intersect':
t.value = 'i'
t.type = 'INTERSECT'
- #else:
- # t.type = 'NAME'
+ else:
+ self.t_error(t)
return(t)
# Handle errors.
def t_error(self, t):
- raise SyntaxError("syntax error on line %d near '%s'" %
- (t.lineno, t.value))
+ raise SyntaxError("syntax error on line %d position %i near '%s'" %
+ (t.lineno, t.lexpos, t.value))
# Build the lexer
def build(self,**kwargs):
@@ -246,12 +275,14 @@
self.lexer = TemporalOperatorLexer()
self.lexer.build()
self.parser = yacc.yacc(module=self)
- self.relations = None # Temporal relations equals, contain, during, ...
- self.temporal = None # Temporal operation like intersect, left, right, ...
- self.function = None # Actual operation
- self.aggregate = None # Aggregation function
+ self.relations = None # Temporal relations (equals, contain, during, ...)
+ self.temporal = None # Temporal operation (intersect, left, right, ...)
+ self.function = None # Actual operation (+, -, /, *, ... )
+ self.aggregate = None # Aggregation function (|, &)
- def parse(self, expression, optype='relation'):
+ self.optype_list = ["select", "boolean", "raster", "hash", "relation", "overlay"]
+ def parse(self, expression, optype='relation'):
"""Parse the expression and fill the object variables
:param expression:
@@ -259,30 +290,38 @@
- select { :, during, r}
- boolean {&&, contains, |}
- raster { *, equal, |}
- - vector { |, starts, &}
+ - overlay { |, starts, &}
- hash { #, during, l}
- relation {during}
:return:
self.optype = optype
+ if optype not in self.optype_list:
+ raise SyntaxError("Unknown optype %s, must be one of %s"%(self.optype, str(self.optype_list)))
+ self.expression = expression
self.parser.parse(expression)
# Error rule for syntax errors.
def p_error(self, t):
- raise SyntaxError("Unexpected syntax error")
+ raise SyntaxError("Unexpected syntax error in expression"
+ " \"%s\" at position %i near %s"%(self.expression,
+ t.lexpos,
+ t.value))
# Get the tokens from the lexer class
tokens = TemporalOperatorLexer.tokens
def p_relation_operator(self, t):
+ # {during}
+ # {during | equal | starts}
operator : CLPAREN relation CRPAREN
| CLPAREN relationlist CRPAREN
# Check for correct type.
if not self.optype == 'relation':
- raise SyntaxError("invalid syntax")
+ raise SyntaxError("Wrong optype \"%s\" must be \"relation\""%self.optype)
else:
# Set three operator components.
if isinstance(t[2], list):
@@ -295,6 +334,8 @@
t[0] = t[2]
def p_relation_bool_operator(self, t):
+ # {||, during}
+ # {&&, during | equal | starts}
operator : CLPAREN OR OR COMMA relation CRPAREN
| CLPAREN AND AND COMMA relation CRPAREN
@@ -302,7 +343,7 @@
| CLPAREN AND AND COMMA relationlist CRPAREN
if not self.optype == 'boolean':
+ raise SyntaxError("Wrong optype \"%s\" must be \"boolean\""%self.optype)
else:
if isinstance(t[5], list):
@@ -316,6 +357,8 @@
t[0] = t[2]
def p_relation_bool_combi_operator(self, t):
+ # {||, during, &}
+ # {&&, during | equal | starts, |}
operator : CLPAREN OR OR COMMA relation COMMA OR CRPAREN
| CLPAREN OR OR COMMA relation COMMA AND CRPAREN
@@ -327,7 +370,7 @@
| CLPAREN AND AND COMMA relationlist COMMA AND CRPAREN
else:
@@ -341,6 +384,8 @@
t[0] = t[2]
def p_relation_bool_combi_operator2(self, t):
+ # {||, during, left}
+ # {&&, during | equal | starts, union}
operator : CLPAREN OR OR COMMA relation COMMA temporal CRPAREN
| CLPAREN AND AND COMMA relation COMMA temporal CRPAREN
@@ -348,7 +393,7 @@
| CLPAREN AND AND COMMA relationlist COMMA temporal CRPAREN
else:
@@ -362,6 +407,8 @@
t[0] = t[2]
def p_relation_bool_combi_operator3(self, t):
+ # {||, during, |, left}
+ # {&&, during | equal | starts, &, union}
operator : CLPAREN OR OR COMMA relation COMMA OR COMMA temporal CRPAREN
| CLPAREN OR OR COMMA relation COMMA AND COMMA temporal CRPAREN
@@ -373,7 +420,7 @@
| CLPAREN AND AND COMMA relationlist COMMA AND COMMA temporal CRPAREN
else:
@@ -387,6 +434,10 @@
t[0] = t[2]
def p_select_relation_operator(self, t):
+ # { :, during}
+ # {!:, during | equal | starts}
+ # { :, during | equal | starts, l}
operator : CLPAREN select CRPAREN
| CLPAREN select COMMA relation CRPAREN
@@ -395,7 +446,7 @@
| CLPAREN select COMMA relationlist COMMA temporal CRPAREN
if not self.optype == 'select':
+ raise SyntaxError("Wrong optype \"%s\" must be \"select\""%self.optype)
else:
if len(t) == 4:
@@ -419,6 +470,10 @@
t[0] = t[2]
def p_hash_relation_operator(self, t):
+ # {#, during}
+ # {#, during | equal | starts}
+ # {#, during | equal | starts, l}
operator : CLPAREN HASH CRPAREN
| CLPAREN HASH COMMA relation CRPAREN
@@ -427,7 +482,7 @@
| CLPAREN HASH COMMA relationlist COMMA temporal CRPAREN
if not self.optype == 'hash':
+ raise SyntaxError("Wrong optype \"%s\" must be \"hash\""%self.optype)
else:
if len(t) == 4:
@@ -451,7 +506,10 @@
t[0] = t[2]
def p_raster_relation_operator(self, t):
- # The expression should always return a list of maps.
+ # {-, during}
+ # {*, during | equal | starts}
+ # {/, during | equal | starts, l}
operator : CLPAREN arithmetic CRPAREN
| CLPAREN arithmetic COMMA relation CRPAREN
@@ -460,7 +518,7 @@
| CLPAREN arithmetic COMMA relationlist COMMA temporal CRPAREN
if not self.optype == 'raster':
+ raise SyntaxError("Wrong optype \"%s\" must be \"raster\""%self.optype)
else:
if len(t) == 4:
@@ -484,7 +542,10 @@
t[0] = t[2]
def p_overlay_relation_operator(self, t):
+ # {-, during}
+ # {~, during | equal | starts}
+ # {^, during | equal | starts, l}
operator : CLPAREN overlay CRPAREN
| CLPAREN overlay COMMA relation CRPAREN
@@ -493,7 +554,7 @@
| CLPAREN overlay COMMA relationlist COMMA temporal CRPAREN
if not self.optype == 'overlay':
+ raise SyntaxError("Wrong optype \"%s\" must be \"overlay\""%self.optype)
else:
if len(t) == 4:
@@ -534,7 +595,7 @@
t[0] = t[1]
def p_over(self, t):
- # The list of relations.
+ # The the over keyword
relation : OVER
