[GRASS-SVN] r69032 - grass-addons/grass7/raster/r.exdet
svn_grass at osgeo.org
Sun Jul 24 06:23:55 PDT 2016
Author: pvanbosgeo
Date: 2016-07-24 06:23:55 -0700 (Sun, 24 Jul 2016)
New Revision: 69032
grass-addons/grass7/raster/r.exdet/r.exdet.html
grass-addons/grass7/raster/r.exdet/r.exdet.py
addon r.exdet: added computation of MIC for NT1and2, removed separate computation of MIC for NT1 and NT2. Furthermore some code cleanup
Modified: grass-addons/grass7/raster/r.exdet/r.exdet.html
--- grass-addons/grass7/raster/r.exdet/r.exdet.html 2016-07-23 22:44:05 UTC (rev 69031)
+++ grass-addons/grass7/raster/r.exdet/r.exdet.html 2016-07-24 13:23:55 UTC (rev 69032)
@@ -14,12 +14,10 @@
<p>The <em>r.exdet</em> function allows you to identify areas with
novel conditions, following methods developed by Mesgaran et al.
(2014) [1][2]. This includes areas where conditions fall outside the
-range of values observed in the reference / callibration data set
-(Type 1 novelty) or areas with novel combinations between the
-envirionmental variables (Type 2 novelty). It furthermore compute
-the most influential covariate (MIC; i.e., the most dissimilar
-variable) for areas where conditions of at least one of the variables
-fall outside the range of values observed in the reference data set.
+range of values observed in the reference / callibration data set (
+<i>NT1</i>: Type 1 novelty) or areas with novel combinations between
+the envirionmental variables (<i>NT2</i>: Type 2 novelty), which
+Mesgaran et al. call the multivariate combination novelty index.
<p>The type 1 (<em>NT1</em>) similarity is similar to how the
multi-environmental similarity messure (MESS) computes novel
@@ -41,26 +39,43 @@
combination), with values closer to zero being more similar. Values
larger than one are indicative of novel combinations.[1]
-<p>The function essentially compares the environmental conditions in
-one area (the reference set) with those of another area (the
-projected set). For the reference set, the function respects the
-region and the mask, if any. The projection data can be of the same
-region (e.g., when comparing current and future climates; see
-example 1 below), or another region (e.g., when comparing conditions
-in one country with those in another country; see example 2 below).
-In the second case, the projected data can be defined by raster
-layers covering a different region. One can also use a
+<p><em>r.exdet</em> can also compute the most influential covariate (
+<i>MIC</i> ). For areas with novel conditions, this is the variable
+that has the lowest <i>NT1</i> value. For areas with multivariate
+combination novelty, this is the variable that yields the largest
+percentage reduction in the Mahalanobis distance if dropped.
+<p>The function can be used to compare (1) conditions at two
+different times (e.g., current climate conditions and climate
+conditions in 2085). As input, the user needs to provide two
+different sets of environmental variables, each representing
+conditions at different times. The function can also be used to
+compare the conditions in two different areas. This can be done in
+three different ways:
+<ul>
+<li>The user can provide two different sets of environmental
+variables, each covering a different area.</li>
+<li>The user can provide a mask and a set of data layers describing
+the reference conditions. Conditions outside the area defined by the
+mask will then be compared with the conditions within the area defined
+by the mask.</li>
<a href="http://grass.osgeo.org/grass64/manuals/g.region.html">region</a>
-to define the projected area (see example 3 below).
+and a set of data layers describing the reference conditions.
+Conditions in the region defined by the user are compared to the
+conditions in the current computational region.</li>
+</ul>
+<p>Some of the options can be combined. For example, the use can set
+a mask, a set of layers describing current conditions (reference)
+and a set of layers providing future conditions (projection). In
+this case, the future conditions in the whole region are compared to
+the current conditions within the area defined by the MASK. (todo:
+provide some examples)
<h2>EXAMPLES</h2>
-<h3>Example 1</h3>
-todo
-<h3>Example 2</h3>
You can download a sample data set from <a href=
"http://www.climond.org/ExDet.aspx">http://www.climond.org/ExDet</a>.
The sample data contains 4 clipped Bioclim variable layers for
@@ -72,18 +87,21 @@
<div class="code"><pre>
g.region raster=AusBio13
-r.exdet -o reference=AusBio13 at example,AusBio14,AusBio5,AusBio6 projection=SaBio13,SaBio14,SaBio5,SaBio6 output=AusSa
+r.exdet -p reference=AusBio13 at example,AusBio14,AusBio5,AusBio6 projection=SaBio13,SaBio14,SaBio5,SaBio6 output=AusSa
</pre></div>
-<h3>Example 3</h3>
-todo
<h2>CITATION</h2>
-When using this tool, please use the citation to the original paper describing the method in your publications or other derived products.
+When using this tool, please cite the paper describing the method in your publications or other derived products.
<ul><li>Mesgaran, M.B., Cousens, R.D. and Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity & Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.</li></ul>
+<p>If you want, in addition, to cite this tool, you can use:
+<ul><li>van Breugel, P. (2016) r.exdet, a GRASS GIS addon for the
+quantification of novel uni- and multi-variate environments. URL:
+https://grass.osgeo.org/grass70/manuals/addons/r.exdet.html</li></ul>
<h2>REFERENCES</h2>
[1] Mesgaran, M.B., Cousens, R.D. and Webber, B.L. (2014) Here be dragons: a tool for quantifying novelty due to covariate range and correlation change when projecting species distribution models. Diversity & Distributions, 20: 1147-1159, DOI: 10.1111/ddi.12209.
Modified: grass-addons/grass7/raster/r.exdet/r.exdet.py
--- grass-addons/grass7/raster/r.exdet/r.exdet.py 2016-07-23 22:44:05 UTC (rev 69031)
+++ grass-addons/grass7/raster/r.exdet/r.exdet.py 2016-07-24 13:23:55 UTC (rev 69032)
@@ -74,23 +74,23 @@
#%end
#%flag
-#% key: o
-#% description: Most influential covariate (MIC) for NT1
+#% key: p
+#% description: Most influential covariates (MIC)
#% guisection: Output
#%end
-## Not implemented yet
-##%flag
-##% key: p
-##% description: Most influential covariate (MIC) for NT2
-##% guisection: Output
-##%end
#%flag
#% key: d
-#% description: Keep layer mahalanobis distance?
+#% label: Mahalanobis distance in projection domain?
+#% description: Keep layer mahalanobis distance in projection domain?
#%end
+#%flag
+#% key: e
+#% label: Mahalanobis distance in reference domain
+#% description: Keep layer mahalanobis distance in reference domain?
+#%end
# import libraries
import os
import sys
@@ -101,13 +101,16 @@
import tempfile
import uuid
import string
+from grass.pygrass.modules import Module
+from subprocess import PIPE
COLORS_EXDET = """\
0% 255:0:0
-0 255:200:200
-0.000001 200:255:200
-1.000001 200:200:255
-100% 0:0:255
+0 255:240:240
+0.000001 240:255:240
+1 0:128:0
+1.000001 255:221:160
+100% 219:65:0
# Functions
@@ -141,6 +144,18 @@
return tmpf
+def CoVar(maps):
+ """Compute the covariance matrix over reference layers"""
+ tmpcov = tempfile.mkstemp()[1]
+ text_file = open(tmpcov, "w")
+ text_file.write(gs.read_command("r.covar", quiet=True, map=maps))
+ text_file.close()
+ covar = np.loadtxt(tmpcov, skiprows=1)
+ os.remove(tmpcov)
+ VI = np.linalg.inv(covar)
+ return VI
def mahal(v, m, VI):
"""Compute the mahalanobis distance over reference layers"""
delta = v - m[:, None, None]
@@ -167,13 +182,17 @@
else:
PRO = REF
opn = [z.split('@')[0] for z in PRO]
- opn = [x.lower() for x in opn]
out = options['output']
region = options['region']
flag_d = flags['d']
- flag_o = flags['o']
- #TODO: flag_p = flags['p']
+ flag_e = flags['e']
+ flag_p = flags['p']
+ # get current region settings, to compare to new ones later
+ regbu1 = tmpname("region")
+ gs.parse_command("g.region", save=regbu1)
+ # Check if region, projected layers or mask is given
if region:
ffile = gs.find_file(region, element="region")
if not ffile:
@@ -196,13 +215,7 @@
text_file.close()
# Create covariance table
- tmpcov = tempfile.mkstemp()[1]
- text_file = open(tmpcov, "w")
- text_file.write(gs.read_command("r.covar", quiet=True, map=REF))
- text_file.close()
- covar = np.loadtxt(tmpcov, skiprows=1)
- VI = np.linalg.inv(covar)
- os.remove(tmpcov)
+ VI = CoVar(maps=REF)
# Import reference data & compute univar stats per reference layer
s = len(REF)
@@ -229,6 +242,14 @@
# Compute mahalanobis over full set of reference layers
mahal_ref = mahal(v=dat_ref, m=stat_mean, VI=VI)
mahal_ref_max = max(mahal_ref[np.isfinite(mahal_ref)])
+ if flag_e:
+ mahalref = "{}_mahalref".format(out)
+ mahal_ref.write(mapname=mahalref)
+ gs.info(_("Mahalanobis distance map saved: {}").format(mahalref))
+ gs.run_command("r.support", map=mahalref,
+ title="Mahalanobis distance map", units="unitless",
+ description="Mahalanobis distance map in reference "
+ "domain", loadhistory=tmphist)
del mahal_ref
# Remove mask and set new region based on user-defined region or
@@ -258,74 +279,124 @@
# Compute mahalanobis distance
mahal_pro = mahal(v=dat_pro, m=stat_mean, VI=VI)
if flag_d:
- mapname = "{}_mahalanobis".format(out)
- mahal_pro.write(mapname=mapname)
- gs.info(_("Mahalanobis distance map saved: {}").format(mapname))
- gs.run_command("r.support", map=mapname,
- title="Mahalanobis distance map", units="unitless",
- description="Mahalanobis distance map",
- loadhistory=tmphist)
+ mahalpro = "{}_mahalpro".format(out)
+ mahal_pro.write(mapname=mahalpro)
+ gs.info(_("Mahalanobis distance map saved: {}").format(mahalpro))
+ gs.run_command("r.support", map=mahalpro,
+ title="Mahalanobis distance map projection domain",
+ units="unitless", loadhistory=tmphist, description=
+ "Mahalanobis distance map in projection domain "
+ "estimated using covariance of refence data")
- # Compute NT2
- nt2map = garray.array()
- nt2map[...] = mahal_pro / mahal_ref_max
- nt2 = "{}_NT2".format(out)
- nt2map.write(mapname=nt2)
- gs.run_command("r.support", map=nt2, units="unitless",
- title="Type 2 similarity",
- description="Type 2 similarity (NT2)",
# Compute NT1
tmplay = tmpname(out)
mnames = [None] * len(REF)
for i in xrange(len(REF)):
tmpout = tmpname("exdet")
- gs.mapcalc("$Dij = min(($prolay - $refmin), ($refmax - $prolay),"
- "0) / ($refmax - $refmin)", Dij=tmpout, prolay=PRO[i],
- refmin=stat_min[i], refmax=stat_max[i], quiet=True)
+ # TODO: computations below sometimes result in very small negative
+ # numbers, which are not 'real', but rather due to some differences
+ # in handling digits in grass and python, hence second mapcalc
+ # statement. Need to figure out how to handle this better.
+ gs.mapcalc("eval("
+ "tmp = min(($prolay - $refmin), ($refmax - $prolay),0) / "
+ "($refmax - $refmin))\n"
+ "$Dij = if(tmp > -0.000000001, 0, tmp)",
+ Dij=tmpout, prolay=PRO[i], refmin=stat_min[i],
+ refmax=stat_max[i], quiet=True)
mnames[i] = tmpout
+ gs.run_command("r.series", quiet=True, input=mnames, output=tmplay,
+ method="sum")
+ # Compute most influential covariate (MIC) metric for NT1
+ if flag_p:
+ tmpla1 = tmpname(out)
+ gs.run_command("r.series", quiet=True, output=tmpla1, input=mnames,
+ method="min_raster")
+ # Compute NT2
+ tmpla2 = tmpname(out)
+ nt2map = garray.array()
+ nt2map[...] = mahal_pro / mahal_ref_max
+ nt2map.write(mapname=tmpla2)
+ # Compute most influential covariate (MIC) metric for NT2
+ if flag_p:
+ tmpla3 = tmpname(out)
+ laylist = []
+ layer = garray.array()
+ for i, map in enumerate(opn):
+ gs.use_temp_region()
+ gs.run_command("g.region", quiet=True, region=regbu1)
+ REFtmp = [x for num, x in enumerate(REF) if not num == i]
+ stattmp = np.delete(stat_mean, i, axis=0)
+ VItmp = CoVar(maps=REFtmp)
+ gs.del_temp_region()
+ dat_protmp = np.delete(dat_pro, i, axis=0)
+ ymap = mahal(v=dat_protmp, m=stattmp, VI=VItmp)
+ # in Mesgaran et al, the MIC2 is the max icp, but that is the
+ # same as the minimum mahalanobis distance (ymap)
+ # icp = (mahal_pro - ymap) / mahal_pro * 100
+ layer[:, :] = ymap
+ tmpmahal = tmpname(out)
+ layer.write(tmpmahal)
+ laylist.append(tmpmahal)
+ gs.run_command("r.series", quiet=True, output=tmpla3,
+ input=laylist, method="min_raster", overwrite=True)
+ # Compute nt1, nt2, and nt1and2 novelty maps
nt1 = "{}_NT1".format(out)
- gs.run_command("r.series", quiet=True, input=mnames, output=nt1,
- method="sum")
+ nt2 = "{}_NT2".format(out)
+ nt12 = "{}_NT1NT2".format(out)
+ expr = ";".join([
+ "$nt12 = if($tmplay < 0, $tmplay, $tmpla2)",
+ "$nt2 = if($tmplay >= 0, $tmpla2, null())",
+ "$nt1 = if($tmplay < 0, $tmplay, null())"])
+ gs.mapcalc(expr, nt12=nt12, nt1=nt1, nt2=nt2, tmplay=tmplay,
+ tmpla2=tmpla2, quiet=True)
+ # Write metadata nt1, nt2, nt1and2 maps
gs.run_command("r.support", map=nt1, units="unitless",
title="Type 1 similarity",
description="Type 1 similarity (NT1)",
- # Compute exdet novelty map
- novelty = "{}_NT1NT2".format(out)
- gs.mapcalc("$final = if($nt1<0,$nt1,$nt2)", final=novelty,
- nt1=nt1, nt2=nt2, quiet=True, overwrite=True)
- gs.run_command("r.support", map=novelty, units="unitless",
+ gs.run_command("r.support", map=nt2, units="unitless",
+ title="Type 2 similarity",
+ description="Type 2 similarity (NT2)",
+ loadhistory=tmphist)
+ gs.run_command("r.support", map=nt12, units="unitless",
title="Type 1 + 2 novelty / similarity",
description="Type 1 + 2 similarity (NT1)",
- # Color table
- gs.write_command("r.colors", map=novelty, rules='-', stdin=COLORS_EXDET,
- quiet=True)
+ # Compute MIC maps
+ if flag_p:
+ mic12 = "{}_MICNT1and2".format(out)
+ expr = "$mic12 = if($tmplay < 0, $tmpla1, " \
+ "if($tmpla2>1, $tmpla3, -1))"
+ gs.mapcalc(expr, tmplay=tmplay, tmpla1=tmpla1, tmpla2=tmpla2,
+ tmpla3=tmpla3, mic12=mic12, quiet=True)
- # Compute most influential covariate (MIC) metric for NT1
- # TODO: compute MIC for NT2 as well (see email exchange with authors
- # exdet program about deviating results)
- if flag_o:
- mod = "{}_MICNT1".format(out)
- gs.run_command("r.series", quiet=True, output=mod, input=mnames,
- method="min_raster")
+ # Write category labels to MIC maps
tmpcat = tempfile.mkstemp()
text_file = open(tmpcat[1], "w")
+ text_file.write("-1:None\n")
for cats in xrange(len(opn)):
text_file.write("{}:{}\n".format(cats, opn[cats]))
text_file.close()
- gs.run_command("r.category", quiet=True, map=mod, rules=tmpcat[1],
+ gs.run_command("r.category", quiet=True, map=mic12, rules=tmpcat[1],
separator=":")
os.remove(tmpcat[1])
- gs.run_command("r.support", map=mod, units="unitless",
- title="MIC for NT1",
- description="Most influential covariate for NT1",
+ CATV = Module('r.category', map=mic12, stdout_=PIPE).outputs.stdout
+ Module('r.category', map=mic12, rules="-", stdin_=CATV, quiet=True)
+ gs.run_command("r.support", map=mic12, units="unitless",
+ title="Most influential covariate",
+ description="Most influential covariate (MIC) for NT1"
+ "and NT2", loadhistory=tmphist)
+ # Write color table
+ gs.write_command("r.colors", map=nt12, rules='-', stdin=COLORS_EXDET,
+ quiet=True)
# Finalize
gs.info(_("Done...."))
