[GRASS-SVN] r68558 - in grass/trunk: general/g.message lib/init
svn_grass at osgeo.org
Wed Jun 1 08:39:05 PDT 2016
Author: wenzeslaus
Date: 2016-06-01 08:39:05 -0700 (Wed, 01 Jun 2016)
New Revision: 68558
grass/trunk/general/g.message/g.message.html
grass/trunk/lib/init/grass.py
replace Python shell by more appropriate terms (see also r67852)
Modified: grass/trunk/general/g.message/g.message.html
--- grass/trunk/general/g.message/g.message.html 2016-06-01 15:26:28 UTC (rev 68557)
+++ grass/trunk/general/g.message/g.message.html 2016-06-01 15:39:05 UTC (rev 68558)
@@ -62,7 +62,7 @@
</ul>
<p>
-Note: The Python shell in the <em>wxGUI</em> can be used for entering the
+Note: The Python tab in the <em>wxGUI</em> can be used for entering the
following sample code:
<p>
Modified: grass/trunk/lib/init/grass.py
--- grass/trunk/lib/init/grass.py 2016-06-01 15:26:28 UTC (rev 68557)
+++ grass/trunk/lib/init/grass.py 2016-06-01 15:39:05 UTC (rev 68558)
@@ -357,7 +357,7 @@
addon_path_var=_("set additional path(s) to local GRASS modules or user scripts"),
addon_base_var=_("set additional GISBASE for locally installed GRASS Addons"),
batch_var=_("shell script to be processed as batch job"),
- python_var=_("set python shell name to override 'python'"),
+ python_var=_("set Python interpreter name to override 'python'"),
exec_=_("execute GRASS module or script"),
exec_detail=_("provided executable will be executed in GRASS session"),
executable=_("GRASS module, script or any other executable"),
