[GRASS-SVN] r68600 - grass/trunk/raster/r.in.xyz
    svn_grass at osgeo.org
    Sat Jun  4 12:11:44 PDT 2016
Author: wenzeslaus
Date: 2016-06-04 12:11:44 -0700 (Sat, 04 Jun 2016)
New Revision: 68600
   grass/trunk/raster/r.in.xyz/main.c
r.in.xyz: unify keywords and method descriptions with r.in.lidar (r68596)
Modified: grass/trunk/raster/r.in.xyz/main.c
--- grass/trunk/raster/r.in.xyz/main.c	2016-06-04 19:10:14 UTC (rev 68599)
+++ grass/trunk/raster/r.in.xyz/main.c	2016-06-04 19:11:44 UTC (rev 68600)
@@ -157,8 +157,10 @@
     module = G_define_module();
     G_add_keyword(_("raster"));
     G_add_keyword(_("import"));
+    G_add_keyword(_("statistics"));
     G_add_keyword(_("conversion"));
     G_add_keyword(_("aggregation"));
+    G_add_keyword(_("binning"));
     G_add_keyword("ASCII");
     G_add_keyword(_("LIDAR"));
     module->description =
@@ -179,6 +181,33 @@
 	"n,min,max,range,sum,mean,stddev,variance,coeff_var,median,percentile,skewness,trimmean";
     method_opt->answer = "mean";
     method_opt->guisection = _("Statistic");
+    G_asprintf((char **)&(method_opt->descriptions),
+               "n;%s;"
+               "min;%s;"
+               "max;%s;"
+               "range;%s;"
+               "sum;%s;"
+               "mean;%s;"
+               "stddev;%s;"
+               "variance;%s;"
+               "coeff_var;%s;"
+               "median;%s;"
+               "percentile;%s;"
+               "skewness;%s;"
+               "trimmean;%s",
+               _("Number of points in cell"),
+               _("Minimum value of point values in cell"),
+               _("Maximum value of point values in cell"),
+               _("Range of point values in cell"),
+               _("Sum of point values in cell"),
+               _("Mean (average) value of point values in cell"),
+               _("Standard deviation of point values in cell"),
+               _("Variance of point values in cell"),
+               _("Coefficient of variance of point values in cell"),
+               _("Median value of point values in cell"),
+               _("pth (nth) percentile of point values in cell"),
+               _("Skewness of point values in cell"),
+               _("Trimmed mean of point values in cell"));
     type_opt = G_define_option();
     type_opt->key = "type";
