[GRASS-SVN] r68620 - grass/trunk/mswindows/osgeo4w
svn_grass at osgeo.org
Mon Jun 6 03:12:58 PDT 2016
Author: martinl
Date: 2016-06-06 03:12:58 -0700 (Mon, 06 Jun 2016)
New Revision: 68620
Added:
grass/trunk/mswindows/osgeo4w/mysql_config
wingrass: add mysql_config (see #3047)
Added: grass/trunk/mswindows/osgeo4w/mysql_config
--- grass/trunk/mswindows/osgeo4w/mysql_config (rev 0)
+++ grass/trunk/mswindows/osgeo4w/mysql_config 2016-06-06 10:12:58 UTC (rev 68620)
@@ -0,0 +1,216 @@
+#!/bin/sh
+# Copyright (c) 2000, 2016, Oracle and/or its affiliates. All rights reserved.
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; version 2 of the License.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+# This script reports various configuration settings that may be needed
+# when using the MySQL client library.
+which ()
+ IFS="${IFS= }"; save_ifs="$IFS"; IFS=':'
+ for file
+ do
+ for dir in $PATH
+ do
+ if test -f $dir/$file
+ then
+ echo "$dir/$file"
+ continue 2
+ fi
+ done
+ echo "which: no $file in ($PATH)"
+ exit 1
+ done
+ IFS="$save_ifs"
+# If we can find the given directory relatively to where mysql_config is
+# we should use this instead of the incompiled one.
+# This is to ensure that this script also works with the binary MySQL
+# version
+fix_path ()
+ var=$1
+ shift
+ for filename
+ do
+ path=$basedir/$filename
+ if [ -d "$path" ] ;
+ then
+ eval "$var"=$path
+ return
+ fi
+ done
+get_full_path ()
+ file=$1
+ # if the file is a symlink, try to resolve it
+ if [ -h $file ];
+ then
+ file=`ls -l $file | awk '{ print $NF }'`
+ fi
+ case $file in
+ /*) echo "$file";;
+ */*) tmp=`pwd`/$file; echo $tmp | sed -e 's;/\./;/;' ;;
+ *) which $file ;;
+ esac
+me=`get_full_path $0`
+# Script might have been renamed but assume mysql_<something>config<something>
+basedir=`echo $me | sed -e 's;/bin/mysql_.*config.*;;'`
+ldata='/var/lib/mysql'
+execdir='/usr/sbin'
+bindir='/usr/bin'
+# If installed, search for the compiled in directory first (might be "lib64")
+pkglibdir='/usr/lib/x86_64-linux-gnu'
+pkglibdir_rel=`echo $pkglibdir | sed -e "s;^$basedir/;;"`
+fix_path pkglibdir $pkglibdir_rel lib/x86_64-linux-gnu/mysql lib/x86_64-linux-gnu
+plugindir='/usr/lib/mysql/plugin'
+plugindir_rel=`echo $plugindir | sed -e "s;^$basedir/;;"`
+fix_path plugindir $plugindir_rel lib/x86_64-linux-gnu/mysql/plugin lib/x86_64-linux-gnu/plugin
+pkgincludedir='/usr/include/mysql'
+if [ -f "$basedir/include/mysql/mysql.h" ]; then
+ pkgincludedir="$basedir/include/mysql"
+elif [ -f "$basedir/include/mysql.h" ]; then
+ pkgincludedir="$basedir/include"
+fi
+version='5.6.30'
+socket='/var/run/mysqld/mysqld.sock'
+ldflags=''
+if [ 0 -eq 0 ]; then
+ port=0
+else
+ port=3306
+fi
+# Create options
+# We intentionally add a space to the beginning and end of lib strings, simplifies replace later
+libs=" $ldflags -L$pkglibdir -lmysqlclient -lpthread -lz -lm -ldl "
+libs="$libs "
+libs="$libs "
+libs_r=" $ldflags -L$pkglibdir -lmysqlclient -lpthread -lz -lm -ldl "
+libs_r="$libs_r "
+embedded_libs=" $ldflags -L$pkglibdir -lmysqld -lpthread -lz -lm -lwrap -lcrypt -ldl -laio "
+embedded_libs="$embedded_libs "
+cflags="-I$pkgincludedir -g -O2 -Wformat -O3 -g -fabi-version=2 -fno-omit-frame-pointer -fno-strict-aliasing -DDBUG_OFF " #note: end space!
+cxxflags="-I$pkgincludedir -g -O2 -Wformat -O3 -g -fabi-version=2 -fno-omit-frame-pointer -fno-strict-aliasing -DDBUG_OFF " #note: end space!
+include="-I$pkgincludedir"
+# Remove some options that a client doesn't have to care about
+for remove in DDBUG_OFF DSAFE_MUTEX DFORCE_INIT_OF_VARS \
+ DEXTRA_DEBUG DHAVE_purify O 'O[0-9]' 'xO[0-9]' 'W[-A-Za-z]*' \
+ 'mtune=[-A-Za-z0-9]*' 'mcpu=[-A-Za-z0-9]*' 'march=[-A-Za-z0-9]*' \
+ unroll2 ip mp restrict
+do
+ # The first option we might strip will always have a space before it because
+ # we set -I$pkgincludedir as the first option
+ cflags=`echo "$cflags"|sed -e "s/ -$remove */ /g"`
+ cxxflags=`echo "$cxxflags"|sed -e "s/ -$remove */ /g"`
+done
+cflags=`echo "$cflags"|sed -e 's/ *\$//'`
+cxxflags=`echo "$cxxflags"|sed -e 's/ *\$//'`
+# Same for --libs(_r)
+for remove in lmtmalloc static-libcxa i-static static-intel
+do
+ # We know the strings starts with a space
+ libs=`echo "$libs"|sed -e "s/ -$remove */ /g"`
+ libs_r=`echo "$libs_r"|sed -e "s/ -$remove */ /g"`
+ embedded_libs=`echo "$embedded_libs"|sed -e "s/ -$remove */ /g"`
+done
+# Strip trailing and ending space if any, and '+' (FIXME why?)
+libs=`echo "$libs" | sed -e 's; \+; ;g' | sed -e 's;^ *;;' | sed -e 's; *\$;;'`
+libs_r=`echo "$libs_r" | sed -e 's; \+; ;g' | sed -e 's;^ *;;' | sed -e 's; *\$;;'`
+embedded_libs=`echo "$embedded_libs" | sed -e 's; \+; ;g' | sed -e 's;^ *;;' | sed -e 's; *\$;;'`
+usage () {
+ cat <<EOF
+Usage: $0 [OPTIONS]
+Options:
+ --cflags [$cflags]
+ --cxxflags [$cxxflags]
+ --include [$include]
+ --libs [$libs]
+ --libs_r [$libs_r]
+ --plugindir [$plugindir]
+ --socket [$socket]
+ --port [$port]
+ --version [$version]
+ --libmysqld-libs [$embedded_libs]
+ --variable=VAR VAR is one of:
+ pkgincludedir [$pkgincludedir]
+ pkglibdir [$pkglibdir]
+ plugindir [$plugindir]
+EOF
+ exit 1
+if test $# -le 0; then usage; fi
+while test $# -gt 0; do
+ case $1 in
+ --cflags) echo "$cflags" ;;
+ --cxxflags)echo "$cxxflags";;
+ --include) echo "$include" ;;
+ --libs) echo "$libs" ;;
+ --libs_r) echo "$libs_r" ;;
+ --plugindir) echo "$plugindir" ;;
+ --socket) echo "$socket" ;;
+ --port) echo "$port" ;;
+ --version) echo "$version" ;;
+ --embedded-libs | --embedded | --libmysqld-libs) echo "$embedded_libs" ;;
+ --variable=*)
+ var=`echo "$1" | sed 's,^[^=]*=,,'`
+ case "$var" in
+ pkgincludedir) echo "$pkgincludedir" ;;
+ pkglibdir) echo "$pkglibdir" ;;
+ plugindir) echo "$plugindir" ;;
+ *) usage ;;
+ esac
+ *) usage ;;
+ esac
+ shift
+done
+#echo "ldata: '"$ldata"'"
+#echo "execdir: '"$execdir"'"
+#echo "bindir: '"$bindir"'"
+#echo "pkglibdir: '"$pkglibdir"'"
+#echo "pkgincludedir: '"$pkgincludedir"'"
+#echo "version: '"$version"'"
+#echo "socket: '"$socket"'"
+#echo "port: '"$port"'"
+#echo "ldflags: '"$ldflags"'"
+#echo "client_libs: '"$client_libs"'"
+exit 0
Property changes on: grass/trunk/mswindows/osgeo4w/mysql_config
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
+ text/x-sh
Added: svn:eol-style
+ native
