[GRASS-SVN] r68623 - grass-addons/grass7/vector/v.class.mlR
Mon Jun 6 08:04:38 PDT 2016
Author: mlennert
Date: 2016-06-06 08:04:38 -0700 (Mon, 06 Jun 2016)
New Revision: 68623
   grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html
   grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py
v.class.mlR: handle case of only one single classifier
Modified: grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html
--- grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html	2016-06-06 13:56:40 UTC (rev 68622)
+++ grass-addons/grass7/vector/v.class.mlR/v.class.mlR.html	2016-06-06 15:04:38 UTC (rev 68623)
@@ -47,7 +47,9 @@
 <p>In the output (as attribute columns or text file) each weighting schemes
 result is provided accompanied by a value that can be considered as an
 estimation of the probability of the classification after weighted vote,
-based on equation (2) in Moreno et al (2006), page 709.
+based on equation (2) in Moreno et al (2006), page 709. At this stage, this
+estimation does not, however, take into account the probabilities determined
+individually by each classifier.
 <p>Optional output of the module include detailed information about the
 different classifier models and their cross-validation results
@@ -78,9 +80,10 @@
 	<li>Add automagic installation of missing R packages.</li>
 	<li>Add option to manually define grid of tuning parameters</li>
 	<li>Check for existing file created by R as no overwrite check is
-	    done in R</li>
+		done in R</li>
+	<li>Use class probabilities determined by individual classifiers
+		to calculate overall class probabilities</li>
 </ul>
 <h2>EXAMPLE</h2>
Modified: grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py
--- grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py	2016-06-06 13:56:40 UTC (rev 68622)
+++ grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py	2016-06-06 15:04:38 UTC (rev 68623)
@@ -328,12 +328,24 @@
             r_file.write("models.cv$%s <- %sModel.cv" % (classifier, classifier))
             r_file.write("\n")
+    r_file.write("if (length(models.cv)>1) {")
+    r_file.write("\n")
     r_file.write("resamps.cv <- resamples(models.cv)")
     r_file.write("\n")
     r_file.write("accuracy_means <- as.vector(apply(resamps.cv$values[seq(2,length(resamps.cv$values), by=2)], 2, mean))")
     r_file.write("\n")
     r_file.write("kappa_means <- as.vector(apply(resamps.cv$values[seq(3,length(resamps.cv$values), by=2)], 2, mean))")
     r_file.write("\n")
+    r_file.write("} else {")
+    r_file.write("resamps.cv <- models.cv[[1]]$resample")
+    r_file.write("accuracy_means <- mean(resamps.cv$Accuracy)")
+    r_file.write("kappa_means <- mean(resamps.cv$Kappa)")
+    r_file.write("}")
     r_file.write("predicted <- data.frame(predict(models.cv, features))")
     r_file.write("\n")
     if flags['i']:
@@ -360,8 +372,9 @@
         r_file.write("\n")
         r_file.write("resultsdf$%s_%s <- vote$V1" % (output_classcol, weighting_mode))
         r_file.write("\n")
-        r_file.write("resultsdf$%s_%s <- vote$V2" % (output_probcol, weighting_mode))
-        r_file.write("\n")
+        if len(classifiers) > 1:
+            r_file.write("resultsdf$%s_%s <- vote$V2" % (output_probcol, weighting_mode))
     if allmap and not flags['f']:
         model_output = '.gscript_tmp_model_output_%d.csv' % os.getpid()
@@ -384,13 +397,11 @@
         r_file.write("write.csv(resultsdf, '%s', row.names=FALSE, quote=FALSE)" % classification_results)
         r_file.write("\n")
     if accuracy_file:
-        r_file.write("df_means <- data.frame(method=names(resamps.cv$methods),accuracy=accuracy_means, kappa=kappa_means)")
+        r_file.write("df_means <- data.frame(method=names(model.cv),accuracy=accuracy_means, kappa=kappa_means)")
         r_file.write("\n")
         r_file.write("write.csv(df_means, '%s', row.names=FALSE, quote=FALSE)" % accuracy_file)
         r_file.write("\n")
     if model_details:
-        r_file.write("conf.mat.cv <- lapply(models.cv, function(x) confusionMatrix(x))")
         r_file.write("sink('%s')" % model_details)
         r_file.write("\n")
         r_file.write("cat('BEST TUNING VALUES\n')")
@@ -413,6 +424,8 @@
         r_file.write("\n")
         r_file.write("cat('******************************\n\n')")
         r_file.write("\n")
+        r_file.write("conf.mat.cv <- lapply(models.cv, function(x) confusionMatrix(x))")
         r_file.write("print(conf.mat.cv)")
         r_file.write("\n")
         r_file.write("cat('\nDETAILED CV RESULTS\n')")
@@ -424,7 +437,7 @@
         r_file.write("sink()")
         r_file.write("\n")
-    if bw_plot_file:
+    if bw_plot_file and len(classifiers) > 1:
         r_file.write("png('%s.png')" % bw_plot_file)
         r_file.write("\n")
         r_file.write("print(bwplot(resamps.cv))")
@@ -451,11 +464,15 @@
         f = open(model_output_desc, 'w')
         header_string = '"Integer"'
         if flags['i']:
-            for model in classifiers:
+            for classifier in classifiers:
                 header_string += ',"Integer"'
-        for weighting_mode in weighting_modes:
+            for weighting_mode in weighting_modes:
+                header_string += ',"Integer"'
+                header_string += ',"Real"'
+        else:
-            header_string += ',"Real"'
         f.write(header_string)
         f.close()
