[GRASS-SVN] r68637 - grass-addons/grass7/vector/v.class.mlR
svn_grass at osgeo.org
Wed Jun 8 07:26:50 PDT 2016
Author: mlennert
Date: 2016-06-08 07:26:50 -0700 (Wed, 08 Jun 2016)
New Revision: 68637
grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py
v.class.mlR: added layer handling for input vector maps
Modified: grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py
--- grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py 2016-06-08 09:31:15 UTC (rev 68636)
+++ grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py 2016-06-08 14:26:50 UTC (rev 68637)
@@ -33,6 +33,13 @@
#% required: no
#% guisection: Vector input
#%end
+#%option G_OPT_V_FIELD
+#% key: segments_layer
+#% label: Layer of the segments map where attributes are stored
+#% required: no
+#% answer: 1
+#% guisection: Vector input
+#%end
#%option G_OPT_V_INPUT
#% key: training_map
#% label: Vector map with training areas
@@ -40,6 +47,13 @@
#% required: no
#%end
+#% key: training_layer
+#% label: Layer of the training map where attributes are stored
+#% required: no
+#% answer: 1
+#%end
#%option G_OPT_F_INPUT
#% key: segments_file
#% label: File containing statistics of all segments
@@ -189,8 +203,11 @@
#%rules
#% required: segments_map,segments_file
+#% exclusive: segments_map,segments_file
#% required: training_map,training_file
+#% exclusive: training_map,training_file
#% requires: classified_map,raster_segments_map
+#% requires: -f,classification_results
#%end
import atexit
@@ -246,6 +263,7 @@
if options['segments_map']:
allfeatures = options['segments_map']
+ segments_layer = options['segments_layer']
allmap = True
else:
allfeatures = options['segments_file']
@@ -253,6 +271,7 @@
if options['training_map']:
training = options['training_map']
+ training_layer = options['training_layer']
trainmap = True
else:
training = options['training_file']
@@ -274,8 +293,6 @@
classification_results = None
if options['classification_results']:
classification_results = options['classification_results']
- if flags['f'] and not classification_results:
- gscript.fatal("A classification_results file is necessary for flag 'f'")
model_details = None
if options['model_details']:
@@ -306,6 +323,7 @@
gscript.run_command('v.db.select',
map_=allfeatures,
file_=feature_vars,
+ layer=segments_layer,
quiet=True,
overwrite=True)
else:
@@ -316,6 +334,7 @@
map_=training,
file_=training_vars,
+ layer=training_layer,
quiet=True,
overwrite=True)
else:
@@ -533,9 +552,10 @@
quiet=True)
columns = gscript.read_command('db.columns',
table=temptable).splitlines()[1:]
+ orig_cat = gscript.vector_db(allfeatures)[int(segments_layer)]['key']
gscript.run_command('v.db.join',
map_=allfeatures,
- column='cat',
+ column=orig_cat,
otable=temptable,
ocolumn='id',
subset_columns=columns,
