[GRASS-SVN] r68660 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Thu Jun 9 18:48:56 PDT 2016
Author: wenzeslaus
Date: 2016-06-09 18:48:56 -0700 (Thu, 09 Jun 2016)
New Revision: 68660
grass/trunk/gui/wxpython/gui_core/ghelp.py
wxGUI: use TextCtrl in About, so that the text can be copied
It also gives white bg and breaks long lines.
Not applicable for Info, Contrib, C Extra
and Tr which are a table from widgets
(need more work to replace by HTML).
Applied to Copy, License, Cite, Authors.
Modified: grass/trunk/gui/wxpython/gui_core/ghelp.py
--- grass/trunk/gui/wxpython/gui_core/ghelp.py 2016-06-09 23:04:24 UTC (rev 68659)
+++ grass/trunk/gui/wxpython/gui_core/ghelp.py 2016-06-10 01:48:56 UTC (rev 68660)
@@ -249,9 +249,9 @@
# put text into a scrolling panel
copyrightwin = ScrolledPanel(self.aboutNotebook)
- copyrightwin.SetBackgroundColour('WHITE')
- copyrighttxt = wx.StaticText(
- copyrightwin, id=wx.ID_ANY, label=copytext)
+ copyrighttxt = wx.TextCtrl(
+ copyrightwin, id=wx.ID_ANY, value=copytext,
+ style=wx.TE_MULTILINE | wx.TE_READONLY)
copyrightwin.SetAutoLayout(True)
copyrightwin.sizer = wx.BoxSizer(wx.VERTICAL)
copyrightwin.sizer.Add(item=copyrighttxt, proportion=1,
@@ -273,8 +273,9 @@
license = _('%s file missing') % 'GPL.TXT'
licensewin = ScrolledPanel(self.aboutNotebook)
- licensewin.SetBackgroundColour('WHITE')
- licensetxt = wx.StaticText(licensewin, id=wx.ID_ANY, label=license)
+ licensetxt = wx.TextCtrl(
+ licensewin, id=wx.ID_ANY, value=license,
licensewin.SetAutoLayout(True)
licensewin.sizer = wx.BoxSizer(wx.VERTICAL)
licensewin.sizer.Add(item=licensetxt, proportion=1,
@@ -298,9 +299,9 @@
window = ScrolledPanel(self.aboutNotebook)
- window.SetBackgroundColour('WHITE')
- stat_text = wx.StaticText(
- window, id=wx.ID_ANY, label=text)
+ stat_text = wx.TextCtrl(
+ window, id=wx.ID_ANY, value=text,
window.SetAutoLayout(True)
window.sizer = wx.BoxSizer(wx.VERTICAL)
window.sizer.Add(item=stat_text, proportion=1,
@@ -322,8 +323,9 @@
else:
authors = _('%s file missing') % 'AUTHORS'
authorwin = ScrolledPanel(self.aboutNotebook)
- authorwin.SetBackgroundColour('WHITE')
- authortxt = wx.StaticText(authorwin, id=wx.ID_ANY, label=authors)
+ authortxt = wx.TextCtrl(
+ authorwin, id=wx.ID_ANY, value=authors,
authorwin.SetAutoLayout(True)
authorwin.SetupScrolling()
authorwin.sizer = wx.BoxSizer(wx.VERTICAL)
@@ -374,7 +376,6 @@
contribs = None
contribwin = ScrolledPanel(self.aboutNotebook)
- contribwin.SetBackgroundColour('WHITE')
contribwin.SetAutoLayout(True)
contribwin.SetupScrolling()
contribwin.sizer = wx.BoxSizer(wx.VERTICAL)
