[GRASS-SVN] r68670 - grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical
svn_grass at osgeo.org
Sat Jun 11 13:35:06 PDT 2016
Author: Giulia
Date: 2016-06-11 13:35:06 -0700 (Sat, 11 Jun 2016)
New Revision: 68670
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
r.green: modify colebrook-white formula
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py 2016-06-11 16:45:24 UTC (rev 68669)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.technical/r.green.hydro.technical.py 2016-06-11 20:35:06 UTC (rev 68670)
@@ -269,13 +269,50 @@
def losses_Colebrooke(discharge, length, diameter, epsilon=0.015):
+ """ Return the Darcy-Weisbach losses with f computed with
+ the Colebrook-White formula
+ Parameters
+ discharge: float [m³/s]
+ Design discharge
+ length: float [m]
+ Design length of the pipe/derivation
+ diameter: float [m]
+ Design diameter for the derivation pipe
+ epsilon: [mm]
+ Roughness
+ Example
+ >>> Q, d, l = 1., 2., 1000.
+ >>> hc = losses_Colebrooke(discharge=Q, length=l, diameter=d)
+ >>> hc == 0.032861244804694816 * 1000.0
def coeff_f(x, *args):
- q, l, d, e = args
- return x + 2 * log10((e * 0.001) / (3.71 * d) +
- (x * 2.51 * 0.000001 * pi * d ** 2) / (4 * q * l))
+ Solve the Colebrook-White formula and return 1/radq(f)
+ Parameters
+ Design discharge
+ epsilon: [mm]
+ Roughness
+ # TODO epsilon coefficient from GUI
+ q, d, e = args
+ first_log_arg = (e * 0.001) / (3.71 * d) # epsilon [mm]
+ rho_water = 1000. # kg/m2
+ mu_water = 0.001 # Pa
+ vel = discharge / (pi * d**2./4.)
+ re_number = rho_water * vel * d / mu_water
+ return x + 2 * log10(first_log_arg + 2.51*x/re_number)
- out = fsolve(coeff_f, 0, args=(discharge, length, diameter, epsilon))
+ out = fsolve(coeff_f, 0, args=(discharge, diameter, epsilon))
f = 1 / out**2
h_colebrooke = (
(f[0] * 8 * length * discharge ** 2) /
