[GRASS-SVN] r68675 - sandbox/bo/i.segment.gsoc2016/i.segment
svn_grass at osgeo.org
Sun Jun 12 20:28:34 PDT 2016
Author: hao2309
Date: 2016-06-12 20:28:34 -0700 (Sun, 12 Jun 2016)
New Revision: 68675
sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c
week 3 wrap up codes
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c 2016-06-12 20:59:18 UTC (rev 68674)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c 2016-06-13 03:28:34 UTC (rev 68675)
@@ -40,7 +40,7 @@
struct ngbr_stats Rin, Rout, Rwin;
double weight, sum_of_weights, diff2;
double min_val, max_val;
double ms_spatial_bandwidth = 3;
double ms_range_bandwidth = 0.1;
@@ -55,7 +55,7 @@
* initially, input and output are original band values */
/* set the pointers */
globals->bands_in = &globals->bands_seg;
- globals->bands_out = &globals->bands_seg2;
+ globals->bands_out = &globals->bands_seg;
/*window size in pixel number*/
window_size = ms_spatial_bandwidth*2+1;
@@ -151,7 +151,7 @@
/* check range bandwidth */
if ((globals->calculate_similarity)(&Rin, &Rwin, globals) <= pow((ms_range_bandwidth * globals->max_diff),2)){
- /* I think sum_of_weights should be place out of loop because only the same index band pixels will take part in the calculation(Rout.mean[n] += Rwin.mean[n]*weight) */
+ /* I tested sum_of_weights should be place out of loop because only the same index band pixels will take part in the calculation(Rout.mean[n] += Rwin.mean[n]*weight) */
sum_of_weights += weight;
int n = globals->nbands - 1;
do{
@@ -199,16 +199,3 @@
return TRUE;
-// /* test out put the result */
-// void print_matrix(struct globals *globals){
- // int i,j;
- // struct ngbr_stats R_prt;
- // R_prt.mean = G_malloc(globals->datasize);
- // for (i = globals->row_min; i < globals->row_max; i++){
- // for (j = globals->col_min; j < globals->col_max; j++) {
- // Segment_get(&globals->bands_seg, (void *)R_prt.mean,i, j);
- // G_message(_("\t%.2f"),R_prt.mean[0]);
\ No newline at end of file
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c 2016-06-12 20:59:18 UTC (rev 68674)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/open_files.c 2016-06-13 03:28:34 UTC (rev 68675)
@@ -131,6 +131,13 @@
scols, inlen, nseg) != 1)
G_fatal_error("Unable to create input temporary files");
+ /* add globals->bands_seg2 when using mean shift */
+ // if (globals->method == ORM_MS){
+ // if (Segment_open
+ // (&globals->bands_seg2, G_tempfile(), globals->nrows, globals->ncols, srows,
+ // scols, inlen, nseg) != 1)
+ // G_fatal_error("Unable to create bands_seg2 input files");
if (Segment_open
(&globals->rid_seg, G_tempfile(), globals->nrows, globals->ncols, srows,
scols, outlen, nseg * 2) != 1)
