[GRASS-SVN] r68678 - sandbox/bo/i.segment.gsoc2016/i.segment
Mon Jun 13 12:41:39 PDT 2016
Author: hao2309
Date: 2016-06-13 12:41:39 -0700 (Mon, 13 Jun 2016)
New Revision: 68678
Removed:
   sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift_2016_05_30_yb.c
move stand-alone codes to sub folder
Deleted: sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift_2016_05_30_yb.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift_2016_05_30_yb.c	2016-06-13 19:32:07 UTC (rev 68677)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift_2016_05_30_yb.c	2016-06-13 19:41:39 UTC (rev 68678)
@@ -1,224 +0,0 @@
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <math.h>
-#define FILEPATH "testing/test_map.ascii"
-/* =============input parameters=============== */
-//input spatial bandwidth = moving window radius
-#define RADIUS 2
-//input range bandwidth in normalized difference
-#define RANGEWIDTH 0.1
-//EPSILON to control when iterations should stop
-#define EPSILON 0.01
-//max number of iterations
-#define MAXITER 20
-//Threhold to cluster image
-#define CLUSTER_BANDWIDTH 0.5
-// row number:
-#define ROWNUM 8
-//column number:
-#define COLNUM 8
-void read_matrix(float **data_matrix){
-	//open the matrix file
-	FILE *data_file;
-	int i,j,m;
-	if ((data_file = fopen(FILEPATH, "r"))==NULL){
-		printf("ERROR: can not open file");
-		exit(0);
-	//loading the head information
-	char head[8][100];
-	for(i=0;i<8;i++){
-		fgets(head[i], 100, data_file);
-		printf (head[i]);
-	//loading the image matrix
-	for (i=0;i<ROWNUM;i++){
-		for (j=0;j<COLNUM;j++){
-			if(!fscanf(data_file,"%f",&data_matrix[i][j]))
-				break;
-	fclose(data_file);
-//print out the matrix
-void print_matrix(float **mtr, int mtr_rows, int mtr_cols){
-	int i,j;
-	for (i=0;i<mtr_rows;i++)
-		for (j=0;j<mtr_cols;j++)
-			printf("\t%.2f", mtr[i][j]);
-		printf("\n");
-//copy matrix
-void copy_matrix(float **newmtr, float **srcmtr)
-  int i,j;
-		  newmtr[i][j] = srcmtr[i][j];
-//simplified cluster bandwidth method to clump image
-void clump_matrix(float **mtr){
-	//the value of class
-  	int class_value = 0;
-	//how many pixels clumped
-	int px_count = 0;
-	//remember the first stop location
-	int first_stop_row = 0;
-	int first_stop_col = 0;
-	int pixel_indicator_matrix[ROWNUM][COLNUM] = {{0}};//the indicator matrix to mark if the pixel has been clumped
-	//start iterations
-	while(px_count<ROWNUM*COLNUM){
-		class_value+=1;// change class value
-		int first_change = 0;//mark if the pixel is the first non-clump pixel
-		//go through all rows
-		float first_stop_value = mtr[first_stop_row][first_stop_col];//based pixel to be compared with other pixels
-		for (int i=0;i<ROWNUM;i++){
-			//go through all cols
-			for (int j=0;j<COLNUM;j++){
-				//condition: use cluster-bandwidth threhold to cluster the image
-				if (fabs(mtr[i][j]-first_stop_value) <= CLUSTER_BANDWIDTH && pixel_indicator_matrix[i][j]==0){
-						pixel_indicator_matrix[i][j] = 1;//mark pixel in indicator matrix 0 as non-clump, 1 as clump
-						mtr[i][j] = class_value;// assign the cluster value
-						px_count+=1;
-				//mark the first non-clumped pixel
-				else if(first_change == 0 && pixel_indicator_matrix[i][j]==0){
-					first_change =1;// mark the first time non-clump
-					first_stop_row = i;//record the pixel location of first time non-clump
-					first_stop_col = j;
-			}//end of cols
-		}//end of rows
-	}//end iteration
-int main(){
-	float **in_matrix;//initialte input matrix
-	float **temp_matrix;//initialte last iteration matrix
-	float **out_matrix;//initialte output matrix
-	//window size in pixel number
-	int window_size = RADIUS*2+1;
-	// iter counter
-	int iter = 0;
-	// number of changed pixel > epsilon
-	/* ================assign mem to matrix==================== */
-	int n_changes = 1;
-	in_matrix =  malloc(sizeof(*in_matrix) *ROWNUM);
-	temp_matrix=  malloc(sizeof(*in_matrix) *ROWNUM);
-	out_matrix=  malloc(sizeof(*in_matrix) *ROWNUM);
-	for (int i=0;i<8;i++){
-		in_matrix[i] =  malloc(sizeof(*in_matrix[i]) * COLNUM);
-		temp_matrix[i]=  malloc(sizeof(*in_matrix) *ROWNUM);
-		out_matrix[i]=  malloc(sizeof(*in_matrix) *ROWNUM);
-	//end assign mem
-	printf ("The head file info of the image is: \n");
-	read_matrix(in_matrix);//read head info and data
-	copy_matrix(out_matrix, in_matrix);//copy input raster to output raster
-	while (iter<MAXITER && n_changes>0){
-		//initialte the in raster, outraster and last iteration raster.
-		iter += 1;
-		//make output raster of last iteration input raster of this iteration
-		copy_matrix(temp_matrix, in_matrix);
-		copy_matrix(in_matrix, out_matrix);
-		copy_matrix(out_matrix, temp_matrix);
-		for (int current_row=0;current_row<ROWNUM;current_row++){
-			//# go through all columns
-			for (int current_col=0;current_col<COLNUM;current_col++){
-				//create moving window, resize in the image edge
-				int window_row_north = current_row - RADIUS;//left bound of the window
-				int window_row_south = window_row_north + window_size;//right bound of the window
-				//clip window in the edge
-				if (window_row_north<0){
-					window_row_north = 0;
-				if (window_row_south>ROWNUM){
-					window_row_south = ROWNUM;
-				int window_col_west = current_col - RADIUS;//upper bound of the window
-				int window_col_east = window_col_west + window_size;//lower bound of the window
-				if (window_col_west<0){
-					window_col_west = 0;
-				if (window_col_east>ROWNUM){
-					window_col_east = ROWNUM;
-				float sum_of_weights = 0;
-				float new_raster_value = 0;
-				//start of the moving window
-				for (int current_window_row = window_row_north;current_window_row<window_row_south;current_window_row++){
-					for (int current_window_col = window_col_west;current_window_col<window_col_east;current_window_col++){
-						//check spatial distance (bandwidth)
-						float weight = 1;
-						if (sqrt(pow((current_window_row - current_row),2)+pow((current_window_col - current_col),2))<=RADIUS){
-							//check range bandwidth
-							if (fabs((in_matrix[current_window_row][current_window_col]-in_matrix[current_row][current_col])/in_matrix[current_row][current_col])<=RANGEWIDTH){
-								weight *=1;
-								sum_of_weights += weight;
-								new_raster_value += in_matrix[current_window_row][current_window_col]*weight;
-				}//end of moving window
-				new_raster_value /= sum_of_weights;
-				out_matrix[current_row][current_col] = new_raster_value;
-				//condition: if the pixel converged(less than epsilon)
-				if (fabs(new_raster_value - temp_matrix[current_row][current_col])>EPSILON){
-					n_changes++;
-			}//end of all all columns
-		}//end of all rows
-	}//end of iteration
-	printf ("The image after mean filtering is: \n");
-	print_matrix(out_matrix,ROWNUM,COLNUM);
-/* 	=================clustering image ============================ */
-	printf ("The image after clustering is: \n");
-	clump_matrix(out_matrix);
-	//===================free matrix=============================
-		free(in_matrix[i]);
-		free(temp_matrix[i]);
-		free(out_matrix[i]);
-	free(in_matrix);
-	free(temp_matrix);
-	free(out_matrix);
-	printf ("Program finished running\n");
-	return 0;
