[GRASS-SVN] r68688 - grass-addons/grass7/raster/r.in.srtm.region
svn_grass at osgeo.org
Tue Jun 14 13:14:45 PDT 2016
Author: neteler
Date: 2016-06-14 13:14:45 -0700 (Tue, 14 Jun 2016)
New Revision: 68688
grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html
r.in.srtm.region addon: example added; TODO: add r.import support
Modified: grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html
--- grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html 2016-06-14 20:02:47 UTC (rev 68687)
+++ grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html 2016-06-14 20:14:45 UTC (rev 68688)
@@ -17,6 +17,21 @@
or optionally uses a local folder with previously downloaded files if
the <b>local</b> option is given.
+<h2>NOTES</h2>
+This module only operates in LatLong locations.
+<!-- TODO: add r.import support -->
+<h2>EXAMPLE</h2>
+Import of SRTM V3 (1 arc seconds ~ 30m) covering the current region:
+<div class="code"><pre>
+# run in LatLong location
+r.in.srtm.region -1 output=srtmV3 memory=2000
+</pre></div>
<h2>SEE ALSO</h2>
<em>
