[GRASS-SVN] r68703 - sandbox/bo/i.segment.gsoc2016/i.segment
    svn_grass at osgeo.org
    Thu Jun 16 21:12:15 PDT 2016
Author: hao2309
Date: 2016-06-16 21:12:15 -0700 (Thu, 16 Jun 2016)
New Revision: 68703
   sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
   sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c
add cluster, not finished
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-06-17 02:24:44 UTC (rev 68702)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c	2016-06-17 04:12:15 UTC (rev 68703)
@@ -33,15 +33,15 @@
 int mean_shift(struct globals *globals)
-    int row, col, current_window_row, current_window_col, t;
+    int row, col, t;
     int n_changes, window_size;
-	int window_row_north, window_row_south, window_col_west,window_col_east;
+	int window_row_north, window_row_south, window_col_west,window_col_east, current_window_row, current_window_col;
     double alpha2, cluster_threshold;
     struct ngbr_stats Rin, Rout, Rwin;
-	struct ngbr_stats Rleft, Rabove, Rright;
+	struct ngbr_stats Rleft, Rabove;
     double weight, sum_of_weights, diff2;
-	double min_val, max_val, old_val, new_val;
-	double *prev_cluster, *cur_cluster, *temp_cluster;
+	int seg_id, new_val;
+	double min_val, max_val;
 	/* G_fatal_error(_("Mean shift is not yet implemented"));
     return FALSE; */
@@ -51,13 +51,13 @@
     Rout.mean = G_malloc(globals->datasize);
 	Rleft.mean = G_malloc(globals->datasize);
 	Rabove.mean = G_malloc(globals->datasize);
-	Rright.mean = G_malloc(globals->datasize);
     /* TODO: need another segment structure holding output
      * initially, input and output are original band values */
 	/* set the pointers */
 	globals->bands_in = &globals->bands_seg2;
 	globals->bands_out = &globals->bands_seg;
+	// globals->bands_id = &globals->rid_seg;
 	/* bands_seg hold the input value actually, but in and out are change each time before the iteration starts */
 	/*window size in pixel number*/
@@ -156,8 +156,6 @@
 					/* get the current moving window pixel value */
 					Segment_get(globals->bands_in, (void *)Rwin.mean,current_window_row, current_window_col);
-					// G_message(_("row: %d, col: %d, Rin.mean is: %f"),row,col,Rin.mean[0]);
-					// G_message(_("row: %d, col: %d, Rwin is: %f"),row,col,Rwin.mean[0]);
 					/* check range bandwidth */
 					if ((globals->calculate_similarity)(&Rin, &Rwin, globals) <= pow((globals->ms_range_bandwidth * globals->max_diff),2)){
@@ -178,7 +176,7 @@
 			Rout.mean[n1] /=sum_of_weights;
 		} while(n1--);
-		G_message(_("row: %d, col: %d, Rout.mean is: %f"),row,col,Rout.mean[0]);
+		G_debug(1, "row: %d, col: %d, Rout.mean is: %f",row,col,Rout.mean[0]);
 		/* write the output to bands_out*/
 		Segment_put(globals->bands_out, (void *)Rout.mean, row, col);
@@ -211,47 +209,44 @@
 	G_message(_("Pass 1 of 2 for clustering"));
 	G_percent_reset();
+	new_val = 0;
 	for (row = globals->row_min; row < globals->row_max; row++) {
 	    G_percent(row - globals->row_min,
 	              globals->row_max - globals->row_min, 4);
 	    for (col = globals->col_min; col < globals->col_max; col++) {
 		if (!(FLAG_GET(globals->candidate_flag, row, col)))
 		    continue;
-		/* try to connect current pixel to a existing cluster */
-		old_val = new_val = 0;
 		/* get the current pixel value */
-		Segment_get(globals->bands_out, (void *)Rin.mean, row, col);
+		Segment_get(&globals->bands_seg2, (void *)Rin.mean, row, col);
 		/* get left pixel value */
-		if (col-1 < globals->col_min){
-			col = globals->col_min +1;
+		if (col > globals->col_min){
+			Segment_get(&globals->bands_seg2, (void *)Rleft.mean, row, col-1);
+			/* compare with left value and set if same cluster */
+			if ((globals->calculate_similarity)(&Rin, &Rleft, globals) <= pow((cluster_threshold * globals->max_diff),2)){
+			seg_id = new_val;
-		Segment_get(globals->bands_out, (void *)Rleft.mean, row, col-1);
-		/* compare with left value and set if same cluster */
-		if ((globals->calculate_similarity)(&Rin, &Rleft, globals) <= pow((cluster_threshold * globals->max_diff),2)){
-			old_val = Rin.mean[0] = Rleft.mean[0];
-		/* check diag */
-		/* compare with above value and set if same cluster */
-		else{
+			else if(row > globals->row_min){
 			/* get above pixel value */
-			if (row-1 < globals->row_min){
-				row = globals->row_min+1;
+				Segment_get(&globals->bands_seg2, (void *)Rabove.mean, row-1, col);
+				if ((globals->calculate_similarity)(&Rin, &Rabove, globals) <= pow((cluster_threshold * globals->max_diff),2)){
+				seg_id = new_val;
-			Segment_get(globals->bands_out, (void *)Rabove.mean, row-1, col);
-			if ((globals->calculate_similarity)(&Rin, &Rabove, globals) <= pow((cluster_threshold * globals->max_diff),2)){
-				temp_cluster = prev_cluster + col;
-				// cur_cluster =
+				else{
+					new_val+=1;
+					seg_id = new_val;
+		G_debug(1, "row: %d, col: %d, seg_id is: %d",row,col,seg_id);
+		/* compare with above value and set if same cluster */
+		// segment_put(&globals->rid_seg, &seg_id, row,col);
     *         Part 3 identify connected components         *
     *    Merge small super-pixel to bigger super-pixels    *
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c	2016-06-17 02:24:44 UTC (rev 68702)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c	2016-06-17 04:12:15 UTC (rev 68703)
@@ -61,8 +61,8 @@
 	if (globals->method == ORM_MS){
 	int seg2_fd;
 	DCELL *outbuf2, seg2;
-	outbuf2 = Rast_allocate_c_buf();
+	outbuf2 = Rast_allocate_d_buf();
     G_debug(1, "preparing shifted value output raster");
     /* open output raster map */
     seg2_fd = Rast_open_new(globals->ms_bands_out, DCELL_TYPE);
@@ -75,13 +75,11 @@
 	G_percent(row, globals->nrows, 9);
-	Rast_set_c_null_value(outbuf2, globals->ncols);
+	Rast_set_d_null_value(outbuf2, globals->ncols);
 	for (col = 0; col < globals->ncols; col++) {
 	    if (!(FLAG_GET(globals->null_flag, row, col))) {
 		Segment_get(&globals->bands_seg2, (void *) &seg2, row, col);
-			G_message(_("Row %d, Col %d, is: %f"),row,col,seg2);
 		    outbuf2[col] = seg2;
