[GRASS-SVN] r68708 - grass/trunk/raster/r.mapcalc/testsuite
Fri Jun 17 12:52:07 PDT 2016
Author: wenzeslaus
Date: 2016-06-17 12:52:07 -0700 (Fri, 17 Jun 2016)
New Revision: 68708
Added:
   grass/trunk/raster/r.mapcalc/testsuite/test_row_above_below_bug.py
r.mapcalc: test for row order reading problem (see #3067)
Added: grass/trunk/raster/r.mapcalc/testsuite/test_row_above_below_bug.py
--- grass/trunk/raster/r.mapcalc/testsuite/test_row_above_below_bug.py	                        (rev 0)
+++ grass/trunk/raster/r.mapcalc/testsuite/test_row_above_below_bug.py	2016-06-17 19:52:07 UTC (rev 68708)
@@ -0,0 +1,95 @@
+#!/usr/bin/env python
+# MODULE:        test_row_above_below_bug.py
+# AUTHOR:        Vaclav Petras
+# PURPOSE:       Show bug reported in #3067
+# COPYRIGHT:     (C) 2016 by Vaclav Petras and the GRASS Development Team
+#                This program is free software under the GNU General Public
+#                License (>=v2). Read the file COPYING that comes with GRASS
+#                for details.
+# #3067
+# r.mapcalc gives wrong result when neighborhood modifier takes a cell
+# above first
+# https://trac.osgeo.org/grass/ticket/3067
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+INPUT = """\
+north: 10
+south: 8
+east: 20
+west: 18
+rows: 3
+cols: 3
+1 0 1
+1 1 0
+1 1 0
+OUTPUT = """\
+north: 10
+south: 8
+east: 20
+west: 18
+rows: 3
+cols: 3
+null: *
+2 1 1
+class TestRowAboveAndBelowBug(TestCase):
+    # TODO: replace by unified handing of maps
+    to_remove = []
+    input = 'r_mapcalc_test_input'
+    output = 'r_mapcalc_test_output'
+    output_ref = 'r_mapcalc_test_output_ref'
+    def setUp(self):
+        self.use_temp_region()
+        self.runModule('r.in.ascii', input='-', stdin_=INPUT,
+                       output=self.input)
+        self.to_remove.append(self.input)
+        self.runModule('g.region', raster=self.input)
+        self.runModule('r.in.ascii', input='-', stdin_=OUTPUT,
+                       output=self.output_ref)
+        self.to_remove.append(self.output_ref)
+    def tearDown(self):
+        self.del_temp_region()
+        if 0 and self.to_remove:
+            self.runModule('g.remove', flags='f', type='raster',
+                           name=','.join(self.to_remove), verbose=True)
+    def r_mapcalc_with_test(self, expression):
+        """Expects just RHS and inputs as ``{m}`` for format function"""
+        expression = expression.format(m=self.input)
+        expression = "{} = {}".format(self.output, expression)
+        self.assertModule('r.mapcalc', expression=expression)
+        self.assertRasterExists(self.output)
+        self.to_remove.append(self.output)
+        ref_univar = dict(null_cells=6, cells=9)
+        self.assertRasterFitsUnivar(raster=self.output,
+                                    reference=ref_univar, precision=0)
+        self.assertRastersNoDifference(actual=self.output,
+                                       reference=self.output_ref,
+                                       precision=0)  # it's CELL type
+    def test_below_above(self):
+        self.r_mapcalc_with_test("{m}[1,0] + {m}[-1,0]")
+    def test_above_below(self):
+        self.r_mapcalc_with_test("{m}[-1,0] + {m}[1,0]")
+if __name__ == '__main__':
+    test()
Property changes on: grass/trunk/raster/r.mapcalc/testsuite/test_row_above_below_bug.py
___________________________________________________________________
Added: svn:mime-type
   + text/x-python
Added: svn:eol-style
   + native
