[GRASS-SVN] r68711 - grass/trunk/display/d.text
svn_grass at osgeo.org
Sat Jun 18 13:16:42 PDT 2016
Author: annakrat
Date: 2016-06-18 13:16:42 -0700 (Sat, 18 Jun 2016)
New Revision: 68711
grass/trunk/display/d.text/main.c
d.text: reorganize options in gui, author Adam Laza
Modified: grass/trunk/display/d.text/main.c
--- grass/trunk/display/d.text/main.c 2016-06-18 20:13:34 UTC (rev 68710)
+++ grass/trunk/display/d.text/main.c 2016-06-18 20:16:42 UTC (rev 68711)
@@ -145,15 +145,12 @@
opt.text->type = TYPE_STRING;
opt.text->required = NO;
opt.text->description = _("Text to display");
+ opt.text->guisection = _("Input");
- opt.size = G_define_option();
- opt.size->key = "size";
- opt.size->type = TYPE_DOUBLE;
- opt.size->required = NO;
- opt.size->answer = "5";
- opt.size->options = "0-100";
- opt.size->description =
- _("Height of letters in percentage of available frame height");
+ opt.input = G_define_standard_option(G_OPT_F_INPUT);
+ opt.input->required = NO;
+ opt.input->description = _("Input file");
+ opt.input->guisection = _("Input");
opt.fgcolor = G_define_option();
opt.fgcolor->key = "color";
@@ -163,6 +160,7 @@
opt.fgcolor->description =
_("Text color, either a standard GRASS color or R:G:B triplet");
opt.fgcolor->gisprompt = "old_color,color,color";
+ opt.fgcolor->guisection = _("Text");
opt.bgcolor = G_define_option();
opt.bgcolor->key = "bgcolor";
@@ -171,15 +169,25 @@
opt.bgcolor->description =
_("Text background color, either a standard GRASS color or R:G:B triplet");
opt.bgcolor->gisprompt = "old_color,color,color";
+ opt.bgcolor->guisection = _("Text");
- opt.line = G_define_option();
- opt.line->key = "line";
- opt.line->required = NO;
- opt.line->type = TYPE_INTEGER;
- opt.line->options = "1-1000";
- opt.line->description =
- _("The screen line number on which text will begin to be drawn");
+ opt.rotation = G_define_option();
+ opt.rotation->key = "rotation";
+ opt.rotation->type = TYPE_DOUBLE;
+ opt.rotation->required = NO;
+ opt.rotation->answer = "0";
+ opt.rotation->description =
+ _("Rotation angle in degrees (counter-clockwise)");
+ opt.rotation->guisection = _("Text");
+ opt.linespacing = G_define_option();
+ opt.linespacing->key = "linespacing";
+ opt.linespacing->type = TYPE_DOUBLE;
+ opt.linespacing->required = NO;
+ opt.linespacing->answer = "1.25";
+ opt.linespacing->description = _("Line spacing");
+ opt.linespacing->guisection = _("Text");
opt.at = G_define_option();
opt.at->key = "at";
opt.at->key_desc = "x,y";
@@ -187,7 +195,17 @@
opt.at->required = NO;
opt.at->description =
_("Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)");
+ opt.at->guisection = _("Position");
+ opt.line = G_define_option();
+ opt.line->key = "line";
+ opt.line->required = NO;
+ opt.line->type = TYPE_INTEGER;
+ opt.line->options = "1-1000";
+ opt.line->description =
+ _("The screen line number on which text will begin to be drawn");
+ opt.line->guisection = _("Position");
opt.align = G_define_option();
opt.align->key = "align";
opt.align->type = TYPE_STRING;
@@ -195,33 +213,31 @@
opt.align->answer = "ll";
opt.align->options = "ll,lc,lr,cl,cc,cr,ul,uc,ur";
opt.align->description = _("Text alignment");
+ opt.align->guisection = _("Position");
- opt.rotation = G_define_option();
- opt.rotation->key = "rotation";
- opt.rotation->type = TYPE_DOUBLE;
- opt.rotation->required = NO;
- opt.rotation->answer = "0";
- opt.rotation->description =
- _("Rotation angle in degrees (counter-clockwise)");
- opt.linespacing = G_define_option();
- opt.linespacing->key = "linespacing";
- opt.linespacing->type = TYPE_DOUBLE;
- opt.linespacing->required = NO;
- opt.linespacing->answer = "1.25";
- opt.linespacing->description = _("Line spacing");
opt.font = G_define_option();
opt.font->key = "font";
opt.font->type = TYPE_STRING;
opt.font->required = NO;
opt.font->description = _("Font name");
+ opt.font->guisection = _("Font settings");
+ opt.size = G_define_option();
+ opt.size->key = "size";
+ opt.size->type = TYPE_DOUBLE;
+ opt.size->required = NO;
+ opt.size->answer = "5";
+ opt.size->options = "0-100";
+ opt.size->description =
+ _("Height of letters in percentage of available frame height");
+ opt.size->guisection = _("Font settings");
opt.path = G_define_standard_option(G_OPT_F_INPUT);
opt.path->key = "path";
opt.path->required = NO;
opt.path->description = _("Path to font file");
opt.path->gisprompt = "old,font,file";
+ opt.path->guisection = _("Font settings");
opt.charset = G_define_option();
opt.charset->key = "charset";
@@ -229,30 +245,32 @@
opt.charset->required = NO;
opt.charset->description =
_("Text encoding (only applicable to TrueType fonts)");
+ opt.charset->guisection = _("Font settings");
- opt.input = G_define_standard_option(G_OPT_F_INPUT);
- opt.input->required = NO;
- opt.input->description = _("Input file");
flag.p = G_define_flag();
flag.p->key = 'p';
flag.p->description = _("Screen position in pixels ([0,0] is top left)");
+ flag.p->guisection = _("Position");
flag.g = G_define_flag();
flag.g->key = 'g';
flag.g->description = _("Screen position in geographic coordinates");
+ flag.g->guisection = _("Position");
flag.b = G_define_flag();
flag.b->key = 'b';
flag.b->description = _("Use bold text");
+ flag.b->guisection = _("Text");
flag.r = G_define_flag();
flag.r->key = 'r';
flag.r->description = _("Use radians instead of degrees for rotation");
+ flag.r->guisection = _("Text");
flag.s = G_define_flag();
flag.s->key = 's';
flag.s->description = _("Font size is height in pixels");
+ flag.s->guisection = _("Font settings");
/* check command line */
