[GRASS-SVN] r68713 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Sun Jun 19 21:48:35 PDT 2016
Author: annakrat
Date: 2016-06-19 21:48:35 -0700 (Sun, 19 Jun 2016)
New Revision: 68713
grass/trunk/gui/wxpython/gui_core/preferences.py
wxGUI: draw example text in font dialog with the selected font
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2016-06-19 01:21:23 UTC (rev 68712)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2016-06-20 04:48:35 UTC (rev 68713)
@@ -41,7 +41,7 @@
import wx.lib.scrolledpanel as SP
from grass.pydispatch.signal import Signal
-from grass.script import core as grass
+import grass.script as grass
from grass.exceptions import OpenError
from core import globalvar
@@ -2055,6 +2055,7 @@
wx.Dialog.__init__(self, parent, id, title, style=style)
panel = wx.Panel(parent=self, id=wx.ID_ANY)
+ self.tmp_file = grass.tempfile(False) + '.png'
self.fontlist = self.GetFonts()
@@ -2086,6 +2087,10 @@
gridSizer.Add(item=self.fontlb,
flag=wx.EXPAND, pos=(1, 0))
+ self.renderfont = wx.StaticBitmap(panel, bitmap=wx.EmptyBitmapRGBA(100, 50, 255, 255, 255))
+ gridSizer.Add(item=self.renderfont,
+ flag=wx.EXPAND, pos=(2, 0))
if self.type == 'font':
if "GRASS_FONT" in os.environ:
self.font = os.environ["GRASS_FONT"]
@@ -2099,12 +2104,12 @@
label=_("Character encoding:"))
gridSizer.Add(item=label,
flag=wx.ALIGN_CENTER_VERTICAL,
- pos=(2, 0))
+ pos=(3, 0))
self.textentry = wx.TextCtrl(parent=panel, id=wx.ID_ANY,
value=self.encoding)
gridSizer.Add(item=self.textentry,
- flag=wx.EXPAND, pos=(3, 0))
+ flag=wx.EXPAND, pos=(4, 0))
self.textentry.Bind(wx.EVT_TEXT, self.OnEncoding)
@@ -2158,6 +2163,10 @@
panel.SetAutoLayout(True)
panel.SetSizer(border)
border.Fit(self)
+ row, col = gridSizer.GetItemPosition(self.renderfont)
+ self.renderfont.SetSize(gridSizer.GetCellSize(row, col))
+ if self.font:
+ self.RenderText(self.font, _("Example"), size=self.renderfont.GetSize())
self.Layout()
@@ -2166,6 +2175,7 @@
def EvtListBox(self, event):
self.font = event.GetString()
+ self.RenderText(self.font, "Example", size=self.renderfont.GetSize())
event.Skip()
def EvtListBoxDClick(self, event):
@@ -2204,7 +2214,26 @@
return fontlist
+ def RenderText(self, font, text, size):
+ """Renders an example text with the selected font and resets the bitmap widget"""
+ env = os.environ.copy()
+ driver = UserSettings.Get(group='display', key='driver', subkey='type')
+ if driver == 'png':
+ env['GRASS_RENDER_IMMEDIATE'] = 'png'
+ else:
+ env['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+ env['GRASS_RENDER_WIDTH'] = str(size[0])
+ env['GRASS_RENDER_HEIGHT'] = str(size[1])
+ env['GRASS_RENDER_FILE'] = self.tmp_file
+ ret = RunCommand('d.text', text=text, font=font, align='cc', at='50,50',
+ size=80, color='black', env=env)
+ if ret == 0:
+ self.renderfont.SetBitmap(wx.Bitmap(self.tmp_file))
+ else:
+ self.renderfont.SetBitmap(wx.EmptyBitmapRGBA(size[0], size[1]))
+ grass.try_remove(self.tmp_file)
class MapsetAccess(wx.Dialog):
"""Controls setting options and displaying/hiding map overlay
decorations
