[GRASS-SVN] r68721 - grass-addons/grass7/raster/r.forestfrag/testsuite
Tue Jun 21 19:22:42 PDT 2016
Author: wenzeslaus
Date: 2016-06-21 19:22:42 -0700 (Tue, 21 Jun 2016)
New Revision: 68721
Added:
   grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_trivial.py
r.forestfrag: small test based on an example in the original paper
Added: grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_trivial.py
--- grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_trivial.py	                        (rev 0)
+++ grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_trivial.py	2016-06-22 02:22:42 UTC (rev 68721)
@@ -0,0 +1,163 @@
+#!/usr/bin/env python
+# MODULE:        r_forestfrag_trivial
+# AUTHOR:        Vaclav Petras
+# PURPOSE:       Test using example from the Riitters et al. 2000 paper
+# COPYRIGHT:     (C) 2016 by Vaclav Petras and the GRASS Development Team
+#                This program is free software under the GNU General Public
+#                License (>=v2). Read the file COPYING that comes with GRASS
+#                for details.
+# This test led to discovery of #3067 (r68717) which was an r.mapcalc
+# row indexing bug.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+FOREST_RIITTERS = """\
+north: 10
+south: 8
+east: 20
+west: 18
+rows: 3
+cols: 3
+1 0 1
+1 1 0
+1 1 0
+FRAG_RIITTERS = """\
+north: 10
+south: 8
+east: 20
+west: 18
+rows: 3
+cols: 3
+null: N
+N N N
+N 4 N
+N N N
+PF_RIITTERS = """\
+north: 10
+south: 8
+east: 20
+west: 18
+rows: 3
+cols: 3
+null: N
+N N N
+N 0.67 N
+N N N
+PFF_RIITTERS = """\
+north: 10
+south: 8
+east: 20
+west: 18
+rows: 3
+cols: 3
+null: N
+N N N
+N 0.45 N
+N N N
+class TestForestFragTrivial(TestCase):
+    # TODO: replace by unified handing of maps
+    to_remove = []
+    forest = 'rff_test_forest_trivial'
+    forest_frag = 'rff_test_forest_frag_trivial'
+    forest_frag_ref = 'rff_test_forest_frag_trivial_ref'
+    def setUp(self):
+        self.use_temp_region()
+    def tearDown(self):
+        self.del_temp_region()
+        if 0 and self.to_remove:
+            self.runModule('g.remove', flags='f', type='raster',
+                           name=','.join(self.to_remove), verbose=True)
+    def forest_frag_general(self, forest, window, reference):
+        self.runModule('r.in.ascii', input='-', stdin_=forest,
+                       output=self.forest)
+        self.to_remove.append(self.forest)
+        self.runModule('g.region', raster=self.forest)
+        self.assertRasterMinMax(self.forest,
+                                refmin=0, refmax=1)
+        self.runModule('r.in.ascii', input='-', stdin_=reference,
+                       output=self.forest_frag_ref)
+        self.to_remove.append(self.forest_frag_ref)
+        pf_ref = self.forest_frag_ref + '_pf'
+        self.runModule('r.in.ascii', input='-', stdin_=PF_RIITTERS,
+                       output=pf_ref)
+        self.to_remove.append(pf_ref)
+        pff_ref = self.forest_frag_ref + '_pff'
+        self.runModule('r.in.ascii', input='-', stdin_=PFF_RIITTERS,
+                       output=pff_ref)
+        self.to_remove.append(pff_ref)
+        # just check if the reference is all right
+        theoretical_min = 0
+        theoretical_max = 6
+        self.assertRasterMinMax(self.forest_frag_ref,
+                                refmin=theoretical_min,
+                                refmax=theoretical_max)
+        ref_univar = dict(null_cells=8)
+        self.assertRasterFitsUnivar(raster=self.forest_frag_ref,
+                                    reference=ref_univar, precision=0)
+        # actually run the module
+        self.assertModule('r.forestfrag', input=self.forest,
+                          output=self.forest_frag, window=window,
+                          flags='t')
+        self.assertRasterExists(self.forest_frag)
+        self.to_remove.append(self.forest_frag)
+        pf = self.forest_frag + '_pf'
+        self.assertRasterExists(pf)
+        self.to_remove.append(pf)
+        pff = self.forest_frag + '_pff'
+        self.assertRasterExists(pff)
+        self.to_remove.append(pff)
+        # check the basic properties
+        self.assertRasterMinMax(self.forest_frag,
+        ref_univar = dict(null_cells=0)
+        self.assertRasterFitsUnivar(raster=self.forest_frag,
+        self.runModule('g.region', zoom=pff_ref)
+        # check cell by cell
+        self.assertRastersNoDifference(actual=pf,
+                                       reference=pf_ref,
+                                       precision=0.01)
+        self.assertRastersNoDifference(actual=pff,
+                                       reference=pff_ref,
+                                       precision=0.01)
+        self.assertRastersNoDifference(actual=self.forest_frag,
+                                       reference=self.forest_frag_ref,
+                                       precision=0)  # it's CELL type
+    def test_riitters(self):
+        self.forest_frag_general(FOREST_RIITTERS, 3, FRAG_RIITTERS)
+if __name__ == '__main__':
+    test()
