[GRASS-SVN] r68736 - grass-addons/grass7/raster/r.forestfrag
svn_grass at osgeo.org
Wed Jun 22 12:42:09 PDT 2016
Author: wenzeslaus
Date: 2016-06-22 12:42:09 -0700 (Wed, 22 Jun 2016)
New Revision: 68736
grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
r.forestfrag: import grass.script as gs to make it short, use underscore for messages, unquiet some computations
Modified: grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
--- grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py 2016-06-22 19:23:49 UTC (rev 68735)
+++ grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py 2016-06-22 19:42:09 UTC (rev 68736)
@@ -78,10 +78,10 @@
import atexit
import tempfile
import string
-import grass.script as grass
+import grass.script as gs
if not os.environ.has_key("GISBASE"):
- grass.message("You must be in GRASS GIS to run this program.")
+ gs.message(_("You must be in GRASS GIS to run this program."))
sys.exit(1)
# create set to store names of temporary maps to be deleted upon exit
@@ -91,14 +91,14 @@
def cleanup():
cleanrast = list(reversed(clean_rast))
for rast in cleanrast:
- grass.run_command("g.remove", flags="f", type="rast", name=rast, quiet=True)
+ gs.run_command("g.remove", flags="f", type="rast", name=rast, quiet=True)
# Functions
-def CheckLayer(envlay):
- ffile = grass.find_file(envlay, element = 'cell')
- if ffile['fullname'] == '':
- grass.fatal("The layer " + envlay + " does not exist.")
+def raster_exists(envlay):
+ ffile = gs.find_file(envlay, element = 'cell')
+ if not ffile['fullname']:
+ gs.fatal(_("Raster map <%s> not found") % envlay)
def tmpname(prefix):
tmpf = prefix + str(uuid.uuid4())
@@ -111,11 +111,11 @@
def main():
# Variables
ipl = options['input']
- CheckLayer(ipl)
+ raster_exists(ipl)
opl = options['output']
wz = int(options['window'])
if wz % 2 == 0:
- grass.fatal("Please provide an odd number for the moving window")
+ gs.fatal(_("Please provide an odd number for the moving window"))
flag_r = flags['r']
flag_t = flags['t']
flag_s = flags['s']
@@ -124,24 +124,24 @@
# set to current input map region (user option, default=current region)
if flag_r:
- grass.message("Setting region to input map...")
- grass.run_command('g.region', quiet=True, raster=ipl)
+ gs.message(_("Setting region to input map..."))
+ gs.run_command('g.region', quiet=True, raster=ipl)
# check if map values are limited to 1 and 0
- input_info = grass.raster_info(ipl)
+ input_info = gs.raster_info(ipl)
# we know what we are doing only when input is integer
if input_info['datatype'] != 'CELL':
- grass.fatal(_("The input raster map must have type CELL"
- " (integer)"))
+ gs.fatal(_("The input raster map must have type CELL"
+ " (integer)"))
# for integer, we just need to text min and max
if input_info['min'] != 0 or input_info['max'] != 1:
- grass.fatal(_("The input raster map must be a binary raster,"
- " i.e. it should contain only values 0 and 1"
- " (now the minimum is %d and maximum is %d)")
- % (input_info['min'], input_info['max']))
+ gs.fatal(_("The input raster map must be a binary raster,"
+ " i.e. it should contain only values 0 and 1"
+ " (now the minimum is %d and maximum is %d)")
+ % (input_info['min'], input_info['max']))
# computing pf values
- grass.info("Step 1: Computing Pf values...")
+ gs.info(_("Step 1: Computing Pf values..."))
# let forested pixels be x and number of all pixels in moving window
# be y, then pf=x/y"
@@ -150,13 +150,13 @@
# generate grid with pixel-value=number of pixels in moving window:
tmpA2 = tmpname('tmpA01_')
tmpC3 = tmpname('tmpA02_')
- grass.run_command("r.neighbors", quiet=True, input=ipl,
- output=[tmpA2, tmpC3], method=["sum", "count"], size=wz)
+ gs.run_command("r.neighbors", quiet=True, input=ipl,
+ output=[tmpA2, tmpC3], method=["sum", "count"], size=wz)
# create pf map
pf = tmpname('tmpA03_')
- grass.mapcalc("$pf = if(" + ipl + ">=0, float($tmpA2) / float($tmpC3))", pf=pf,
- tmpA2=tmpA2, tmpC3=tmpC3, quiet=True)
+ gs.mapcalc("$pf = if(" + ipl + ">=0, float($tmpA2) / float($tmpC3))", pf=pf,
+ tmpA2=tmpA2, tmpC3=tmpC3)
# computing pff values
@@ -165,12 +165,12 @@
## one forested pixel, and y of those pairs are forest-forest pairs, so pff equals
## y/x"
- grass.info("Step 2: Computing Pff values...")
+ gs.info(_("Step 2: Computing Pff values..."))
# Create copy of forest map and convert NULL to 0 (if any)
tmpC4 = tmpname('tmpA04_')
- grass.run_command("g.copy", raster=[ipl, tmpC4], quiet=True)
- grass.run_command("r.null", map=tmpC4, null=0, quiet=True)
+ gs.run_command("g.copy", raster=[ipl, tmpC4], quiet=True)
+ gs.run_command("r.null", map=tmpC4, null=0, quiet=True)
# calculate number of 'forest-forest' pairs
@@ -199,7 +199,7 @@
text_file.write("0")
text_file.close()
- grass.run_command("r.mapcalc", file=tmpfile2, quiet=True)
+ gs.run_command("r.mapcalc", file=tmpfile2)
os.close(fd2)
os.remove(tmpfile2)
@@ -227,39 +227,39 @@
text_file.close()
- grass.run_command("r.mapcalc", file=tmpfile3, quiet=True)
+ gs.run_command("r.mapcalc", file=tmpfile3)
os.close(fd3)
os.remove(tmpfile3)
# create pff map
pff = tmpname('tmpA07_')
- grass.mapcalc("$pff = if(" + ipl + " >= 0, float($tmpl4) / float($tmpl5))", tmpl4=tmpl4,
- tmpl5=tmpl5, pff=pff,quiet=True)
+ gs.mapcalc("$pff = if(" + ipl + " >= 0, float($tmpl4) / float($tmpl5))",
+ tmpl4=tmpl4, tmpl5=tmpl5, pff=pff, quiet=True)
# computing fragmentation index
- grass.info("Step 3: Computing fragmentation index...")
+ gs.info(_("Step 3: Computing fragmentation index..."))
pf2 = tmpname('tmpA08_')
- grass.mapcalc("$pf2 = $pf - $pff", pf2=pf2, pf=pf, pff=pff, quiet=True)
+ gs.mapcalc("$pf2 = $pf - $pff", pf2=pf2, pf=pf, pff=pff, quiet=True)
f1 = tmpname('tmpA09_') # patch
- grass.mapcalc("$f1 = if($pf<0.4,1,0)", f1=f1, pf=pf, quiet=True)
+ gs.mapcalc("$f1 = if($pf<0.4,1,0)", f1=f1, pf=pf, quiet=True)
f2 = tmpname('tmpA10_') # transitional
- grass.mapcalc("$f2 = if($pf>=0.4 && $pf<0.6,2,0)", pf=pf, f2=f2, quiet=True)
+ gs.mapcalc("$f2 = if($pf>=0.4 && $pf<0.6,2,0)", pf=pf, f2=f2, quiet=True)
f3 = tmpname('tmpA11_') # edge
- grass.mapcalc("$f3 = if($pf>=0.6 && $pf2<0,3,0)", pf=pf, pf2=pf2, f3=f3, quiet=True)
+ gs.mapcalc("$f3 = if($pf>=0.6 && $pf2<0,3,0)", pf=pf, pf2=pf2, f3=f3, quiet=True)
f4 = tmpname('tmpA12_') # perforate
- grass.mapcalc("$f4 = if($pf>0.6 && $pf<1 && $pf2>0,4,0)", pf=pf, pf2=pf2, f4=f4, quiet=True)
+ gs.mapcalc("$f4 = if($pf>0.6 && $pf<1 && $pf2>0,4,0)", pf=pf, pf2=pf2, f4=f4, quiet=True)
f5 = tmpname('tmpA13_') # interior
- grass.mapcalc("$f5 = if($pf==1,5,0)", pf=pf, pff=pff, f5=f5, quiet=True)
+ gs.mapcalc("$f5 = if($pf==1,5,0)", pf=pf, pff=pff, f5=f5, quiet=True)
f6 = tmpname('tmpA14_') # undetermined
- grass.mapcalc("$f6 = if($pf>0.6 && $pf<1 && $pf2==0,6,0)", pf=pf, pf2=pf2, pff=pff, f6=f6, quiet=True) # undetermined
+ gs.mapcalc("$f6 = if($pf>0.6 && $pf<1 && $pf2==0,6,0)", pf=pf, pf2=pf2, pff=pff, f6=f6, quiet=True) # undetermined
Index = tmpname('tmpA15_')
- grass.run_command("r.series", input=[f1,f2,f3,f4,f5,f6], output=Index,
+ gs.run_command("r.series", input=[f1,f2,f3,f4,f5,f6], output=Index,
method="sum", quiet=True)
indexfin2 = tmpname('tmpA16_')
- grass.mapcalc("$if2 = $ipl * $Index", if2=indexfin2, ipl=ipl,
- Index=Index, quiet=True)
+ gs.mapcalc("$if2 = $ipl * $Index",
+ if2=indexfin2, ipl=ipl, Index=Index)
#create categories
indexfin3 = tmpname('tmpA17_')
@@ -274,25 +274,25 @@
text_file.write("6 = 6 undetermined\n")
text_file.write("* = NULL\n")
text_file.close()
- grass.run_command("r.reclass", quiet=True, input=indexfin2, output=indexfin3,
- title="fragmentation index", rules=tmprul)
+ gs.run_command("r.reclass", quiet=True, input=indexfin2, output=indexfin3,
+ title="fragmentation index", rules=tmprul)
os.close(fd4)
os.remove(tmprul)
# Shrink the region
if flag_a:
regionoriginal = tmpname('tmpA18_')
- grass.run_command("g.region", save=regionoriginal, quiet=True, overwrite=True)
- reginfo = grass.parse_command("g.region", flags="gp")
+ gs.run_command("g.region", save=regionoriginal, quiet=True, overwrite=True)
+ reginfo = gs.parse_command("g.region", flags="gp")
NSCOR = SWn * float(reginfo['nsres'])
EWCOR = SWn * float(reginfo['ewres'])
- n=float(reginfo['n'])-NSCOR,
- s=float(reginfo['s'])+NSCOR,
- e=float(reginfo['e'])-EWCOR,
- w=float(reginfo['w'])+EWCOR,
- quiet=True)
- grass.mapcalc("$opl = $if3", opl=opl, if3=indexfin3, quiet=True)
+ n=float(reginfo['n'])-NSCOR,
+ s=float(reginfo['s'])+NSCOR,
+ e=float(reginfo['e'])-EWCOR,
+ w=float(reginfo['w'])+EWCOR,
+ quiet=True)
+ gs.mapcalc("$opl = $if3", opl=opl, if3=indexfin3, quiet=True)
#create color codes
fd5, tmpcol = tempfile.mkstemp()
@@ -305,27 +305,27 @@
text_file.write("5 26:152:80\n")
text_file.write("6 145:207:96\n")
text_file.close()
- grass.run_command("r.colors", quiet=True, map=opl, rules=tmpcol)
+ gs.run_command("r.colors", quiet=True, map=opl, rules=tmpcol)
os.close(fd5)
os.remove(tmpcol)
# Write metadata for main layer
- grass.run_command("r.support", map=opl,
- title="Forest fragmentation",
- source1="Based on %s" % ipl,
- source2="", # to remove what r.recode creates
- description="Forest fragmentation index (6 classes)")
- grass.raster_history(opl)
+ gs.run_command("r.support", map=opl,
+ title="Forest fragmentation",
+ source1="Based on %s" % ipl,
+ source2="", # to remove what r.recode creates
+ description="Forest fragmentation index (6 classes)")
+ gs.raster_history(opl)
# Write metadata for intermediate layers
if flag_t:
# pf layer
- grass.run_command("r.support", map=pf,
- title="Proportion forested",
- units="Proportion",
- description="Proportion of pixels in the moving window that is forested")
- grass.raster_history(pf)
+ gs.run_command("r.support", map=pf,
+ title="Proportion forested",
+ units="Proportion",
+ description="Proportion of pixels in the moving window that is forested")
+ gs.raster_history(pf)
# pff layer
fd8, tmphist = tempfile.mkstemp()
@@ -335,36 +335,36 @@
text_file.write("It thus (roughly) estimates the conditional probability that, given a\n")
text_file.write("pixel of forest, its neighbor is also forest.")
text_file.close()
- grass.run_command("r.support", map=pff,
- title="Conditional probability neighboring cell is forest",
- description="Probability neighbor of forest cell is forest",
- loadhistory=tmphist)
- grass.raster_history(pff)
+ gs.run_command("r.support", map=pff,
+ title="Conditional probability neighboring cell is forest",
+ description="Probability neighbor of forest cell is forest",
+ loadhistory=tmphist)
+ gs.raster_history(pff)
# Report fragmentation index and names of layers created
if flag_s:
- grass.run_command("r.report", map=opl, units=["h","p"],
- flags="n", page_width=50, quiet=True)
- grass.info("\n")
- grass.info("The following layers were created\n")
- grass.info("The fragmentation index: " + opl +"\n")
+ gs.run_command("r.report", map=opl, units=["h", "p"],
+ flags="n", page_width=50, quiet=True)
+ gs.info("\n")
+ gs.info(_("The following layers were created\n"))
+ gs.info(_("The fragmentation index: " + opl +"\n"))
if flag_t:
- grass.run_command("g.rename", quiet=True, raster=[pf,opl + "_pf"])
- grass.run_command("g.rename", quiet=True, raster=[pff,opl + "_pff"])
- grass.info("The proportion forested (pf): " + opl + "_pf\n")
- grass.info("The proportion forested pixel pairs: " + opl + "_pff\n")
+ gs.run_command("g.rename", quiet=True, raster=[pf,opl + "_pf"])
+ gs.run_command("g.rename", quiet=True, raster=[pff,opl + "_pff"])
+ gs.info(_("The proportion forested (pf): " + opl + "_pf\n"))
+ gs.info(_("The proportion forested pixel pairs: " + opl + "_pff\n"))
clean_rast.remove(pf)
clean_rast.remove(pff)
# Clean up
if flag_a:
- grass.run_command("g.region", region=regionoriginal, quiet=True, overwrite=True)
+ gs.run_command("g.region", region=regionoriginal, quiet=True, overwrite=True)
if __name__ == "__main__":
- options, flags = grass.parser()
+ options, flags = gs.parser()
atexit.register(cleanup)
sys.exit(main())
