[GRASS-SVN] r68741 - grass-addons/grass7/raster/r.forestfrag
    svn_grass at osgeo.org
    Wed Jun 22 17:16:33 PDT 2016
Author: wenzeslaus
Date: 2016-06-22 17:16:33 -0700 (Wed, 22 Jun 2016)
New Revision: 68741
   grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
r.forestfrag: use size option instead of window option
This follows r.neighbors, r.texture, and r.param.scale.
Use some extra code to keep backwards compatibility with
the old name window for some time (the addon is old).
Modified: grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
--- grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py	2016-06-22 21:05:27 UTC (rev 68740)
+++ grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py	2016-06-23 00:16:33 UTC (rev 68741)
@@ -42,12 +42,12 @@
 #%end
 #%option
-#% key: window
+#% key: size
 #% type: integer
 #% description: Moving window size (odd number)
 #% key_desc: number
-#% answer: 3
-#% required: yes
+#% options: 3-
+#% required: no
 #%end
 #%option G_OPT_R_OUTPUT
@@ -84,6 +84,13 @@
 #% description: Trim the output map to avoid border effects
 #%end
+#%option
+#% key: window
+#% type: integer
+#% label: This option is deprecated, use the option size instead
+#% options: 3-
+#% required: no
+#%end
 # import libraries
 import os
@@ -123,9 +130,21 @@
     ipl = options['input']
     raster_exists(ipl)
     opl = options['output']
-    wz  = int(options['window'])
+    # size option backwards compatibility with window
+    if not options['size'] and not options['window']:
+        gs.fatal(_("Required parameter <%s> not set") % 'size')
+    if options['size']:
+        wz  = int(options['size'])
+    if options['window']:
+        gs.warning(_("The window option is deprecated, use the option"
+                     " size instead"))
+        wz  = int(options['window'])
+    if options['size'] and options['size'] != '3' and options['window']:
+        gs.warning(_("When the obsolete window option is used, the"
+                     " new size option is ignored"))
     if wz % 2 == 0:
-        gs.fatal(_("Please provide an odd number for the moving window"))
+        gs.fatal(_("Please provide an odd number for the moving"
+                   " window size, not %d") % wz)
     # user wants pf or pff
     user_pf = options['pf']
     user_pff = options['pff']
