[GRASS-SVN] r68750 - grass-addons/grass7/raster/r.forestfrag
Thu Jun 23 10:42:24 PDT 2016
Author: wenzeslaus
Date: 2016-06-23 10:42:24 -0700 (Thu, 23 Jun 2016)
New Revision: 68750
   grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
r.forestfrag: simplify pff (pairs) expressions
Expression is generated by a function. Indexing more straightforward.
Using binary (here same as logical) operators instead of
plus and if (or), and multiplication (and).
Using mapcalc function interface which passes everything
on stdin to avoid need for a tmp file.
There is a very small performance gain for large window sizes.
Modified: grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py
--- grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py	2016-06-23 15:53:34 UTC (rev 68749)
+++ grass-addons/grass7/raster/r.forestfrag/r.forestfrag.py	2016-06-23 17:42:24 UTC (rev 68750)
@@ -145,6 +145,21 @@
     clean_rast.append(tmpf)
     return tmpf
+def pairs_expression(map_name, max_index, combine_op, aggregate_op="+"):
+    s = max_index  # just for shorter
+    base_expr = "({m}[{a},{b}] {o} {m}[{c},{d}])"
+    expr = []
+    for j in range(-s, s + 1):
+        for i in range(-s, s):
+            expr.append(base_expr.format(
+                m=map_name, o=combine_op, a=i, b=j, c=i + 1, d=j))
+    for i in range(-s, s + 1):
+        for j in range(-s, s):
+                m=map_name, o=combine_op, a=i, b=j, c=i, d=j + 1))
+    return aggregate_op.join(expr)
 # Main
 def main():
@@ -238,73 +253,22 @@
     gs.run_command("g.copy", raster=[ipl, tmpC4], quiet=True)
     gs.run_command("r.null", map=tmpC4, null=0, quiet=True)
-    # calculate number of 'forest-forest' pairs
-    # Compute matrix dimensions
-    SWn= int((wz - 1) / 2)
-    # Write mapcalc expression to tmpf - rows
-    fd2, tmpfile2 = tempfile.mkstemp()
-    tmpl4 = tmpname('tmpA05_')
-    text_file = open(tmpfile2, "w")
-    text_file.write(tmpl4 + " = ")
-    # Write mapcalc expression to tmpf (rows and columns)
-    rsub=range(SWn, -SWn-1, -1)
-    csub=range(-SWn, SWn, 1)
-    for k in rsub:
-      for l in csub:
-        text_file.write("{tmpC4}[{a},{b}]*{tmpC4}[{c},{d}] + ".format(
-                        tmpC4=tmpC4, a=k, b=l, c=k, d=l + 1))
-    rsub=range(-SWn, SWn+1, 1)
-    csub=range(SWn, -SWn, -1)
-    for k in rsub:
-      for l in csub:
-                          tmpC4=tmpC4, a=l, b=k, c=l - 1, d=k))
-    text_file.write("0")
-    text_file.close()
-    gs.run_command("r.mapcalc", file=tmpfile2)
-    os.close(fd2)
-    os.remove(tmpfile2)
-    # number of 'forest patches
-    fd3, tmpfile3 = tempfile.mkstemp()
-    tmpl5 = tmpname('tmpA06_')
-    text_file = open(tmpfile3, "w")
-    text_file.write(tmpl5 + " = ")
-    # Write mapcalc expression to tmpf - rows and columns
-    for k in rsub:
-      for l in csub:
-        text_file.write("if(({tmpC4}[{a},{b}]+{tmpC4}[{c},{d}])>0,1) + ".format(
-    for k in rsub:
-      for l in csub:
-    text_file.close()
-    gs.run_command("r.mapcalc", file=tmpfile3)
-    os.close(fd3)
-    os.remove(tmpfile3)
+    # window dimensions
+    max_index = int((wz - 1) / 2)
+    # number of 'forest-forest' pairs
+    expr1 = pairs_expression(map_name=tmpC4, max_index=max_index,
+                             combine_op='&')
+    # number of 'nonforest-forest' pairs
+    expr2 = pairs_expression(map_name=tmpC4, max_index=max_index,
+                             combine_op='|')
     # create pff map
     if user_pff:
         pff = user_pff
     else:
         pff = tmpname('tmpA07_')
+    # potentially this can be split and parallelized
     gs.mapcalc("$pff = if($ipl >= 0, float($tmpl4) / float($tmpl5))",
-               ipl=ipl, tmpl4=tmpl4, tmpl5=tmpl5, pff=pff,
-               quiet=True)
+               ipl=ipl, tmpl4=expr1, tmpl5=expr2, pff=pff)
     # computing fragmentation index
     # (a b) name, condition
