[GRASS-SVN] r68752 - in grass-addons/grass7: hadoop/hd hadoop/hd/hd.db.connect hadoop/hd/hd.esri2vector hadoop/hd/hd.hdfs.in.fs hadoop/hd/hd.hdfs.in.vector hadoop/hd/hd.hdfs.info hadoop/hd/hd.hdfs.out.vector hadoop/hd/hd.hive.csv.table hadoop/hd/hd.hive.execute hadoop/hd/hd.hive.info hadoop/hd/hd.hive.json.table hadoop/hd/hd.hive.load hadoop/hd/hd.hive.select hadoop/hd/hdfsgrass hadoop/hd/hdfswrapper raster/r.colors.matplotlib raster/r.forestfrag/testsuite vector/v.explode vector/v.what.spoly
Thu Jun 23 15:03:32 PDT 2016
Author: neteler
Date: 2016-06-23 15:03:32 -0700 (Thu, 23 Jun 2016)
New Revision: 68752
   grass-addons/grass7/hadoop/hd/Makefile
   grass-addons/grass7/hadoop/hd/dependency.py
   grass-addons/grass7/hadoop/hd/hd.db.connect/Makefile
   grass-addons/grass7/hadoop/hd/hd.db.connect/hd.db.connect.html
   grass-addons/grass7/hadoop/hd/hd.db.connect/hd.db.connect.py
   grass-addons/grass7/hadoop/hd/hd.esri2vector/Makefile
   grass-addons/grass7/hadoop/hd/hd.esri2vector/hd.esri2vector.html
   grass-addons/grass7/hadoop/hd/hd.esri2vector/hd.esri2vector.py
   grass-addons/grass7/hadoop/hd/hd.hdfs.in.fs/Makefile
   grass-addons/grass7/hadoop/hd/hd.hdfs.in.fs/hd.hdfs.in.fs.html
   grass-addons/grass7/hadoop/hd/hd.hdfs.in.fs/hd.hdfs.in.fs.py
   grass-addons/grass7/hadoop/hd/hd.hdfs.in.vector/Makefile
   grass-addons/grass7/hadoop/hd/hd.hdfs.in.vector/hd.hdfs.in.vector.html
   grass-addons/grass7/hadoop/hd/hd.hdfs.in.vector/hd.hdfs.in.vector.py
   grass-addons/grass7/hadoop/hd/hd.hdfs.info/Makefile
   grass-addons/grass7/hadoop/hd/hd.hdfs.info/hd.hdfs.info.html
   grass-addons/grass7/hadoop/hd/hd.hdfs.info/hd.hdfs.info.py
   grass-addons/grass7/hadoop/hd/hd.hdfs.out.vector/Makefile
   grass-addons/grass7/hadoop/hd/hd.hdfs.out.vector/hd.hdfs.out.vector.html
   grass-addons/grass7/hadoop/hd/hd.hdfs.out.vector/hd.hdfs.out.vector.py
   grass-addons/grass7/hadoop/hd/hd.hive.csv.table/Makefile
   grass-addons/grass7/hadoop/hd/hd.hive.csv.table/hd.hive.csv.table.html
   grass-addons/grass7/hadoop/hd/hd.hive.csv.table/hd.hive.csv.table.py
   grass-addons/grass7/hadoop/hd/hd.hive.execute/Makefile
   grass-addons/grass7/hadoop/hd/hd.hive.execute/hd.hive.execute.html
   grass-addons/grass7/hadoop/hd/hd.hive.execute/hd.hive.execute.py
   grass-addons/grass7/hadoop/hd/hd.hive.info/Makefile
   grass-addons/grass7/hadoop/hd/hd.hive.info/hd.hive.info.html
   grass-addons/grass7/hadoop/hd/hd.hive.info/hd.hive.info.py
   grass-addons/grass7/hadoop/hd/hd.hive.json.table/Makefile
   grass-addons/grass7/hadoop/hd/hd.hive.json.table/hd.hive.json.table.html
   grass-addons/grass7/hadoop/hd/hd.hive.json.table/hd.hive.json.table.py
   grass-addons/grass7/hadoop/hd/hd.hive.load/Makefile
   grass-addons/grass7/hadoop/hd/hd.hive.load/hd.hive.load.html
   grass-addons/grass7/hadoop/hd/hd.hive.load/hd.hive.load.py
   grass-addons/grass7/hadoop/hd/hd.hive.select/Makefile
   grass-addons/grass7/hadoop/hd/hd.hive.select/hd.hive.select.html
   grass-addons/grass7/hadoop/hd/hd.hive.select/hd.hive.select.py
   grass-addons/grass7/hadoop/hd/hdfsgrass/Makefile
   grass-addons/grass7/hadoop/hd/hdfsgrass/__init__.py
   grass-addons/grass7/hadoop/hd/hdfsgrass/grass_map.py
   grass-addons/grass7/hadoop/hd/hdfsgrass/hdfs_grass_lib.py
   grass-addons/grass7/hadoop/hd/hdfsgrass/hdfs_grass_util.py
   grass-addons/grass7/hadoop/hd/hdfswrapper/Makefile
   grass-addons/grass7/hadoop/hd/hdfswrapper/__init__.py
   grass-addons/grass7/hadoop/hd/hdfswrapper/base_hook.py
   grass-addons/grass7/hadoop/hd/hdfswrapper/connections.py
   grass-addons/grass7/hadoop/hd/hdfswrapper/hdfs_hook.py
   grass-addons/grass7/hadoop/hd/hdfswrapper/hive_hook.py
   grass-addons/grass7/hadoop/hd/hdfswrapper/hive_table.py
   grass-addons/grass7/hadoop/hd/hdfswrapper/security_utils.py
   grass-addons/grass7/hadoop/hd/hdfswrapper/settings.py
   grass-addons/grass7/hadoop/hd/hdfswrapper/utils.py
   grass-addons/grass7/hadoop/hd/hdfswrapper/webhdfs_hook.py
   grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm.png
   grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm_edit.png
   grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm_properties.png
   grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_ncspm.py
   grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_trivial.py
   grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_xy.py
   grass-addons/grass7/vector/v.explode/Makefile
   grass-addons/grass7/vector/v.explode/v.explode.html
   grass-addons/grass7/vector/v.explode/v.explode.py
   grass-addons/grass7/vector/v.what.spoly/Makefile
   grass-addons/grass7/vector/v.what.spoly/v.what.spoly.html
   grass-addons/grass7/vector/v.what.spoly/v.what.spoly.py
svn propset
Property changes on: grass-addons/grass7/hadoop/hd/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Property changes on: grass-addons/grass7/hadoop/hd/dependency.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.db.connect/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.db.connect/hd.db.connect.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.db.connect/hd.db.connect.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.esri2vector/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.esri2vector/hd.esri2vector.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.esri2vector/hd.esri2vector.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.in.fs/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.in.fs/hd.hdfs.in.fs.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.in.fs/hd.hdfs.in.fs.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.in.vector/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.in.vector/hd.hdfs.in.vector.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.in.vector/hd.hdfs.in.vector.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.info/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.info/hd.hdfs.info.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.info/hd.hdfs.info.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.out.vector/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.out.vector/hd.hdfs.out.vector.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hdfs.out.vector/hd.hdfs.out.vector.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.csv.table/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.csv.table/hd.hive.csv.table.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.csv.table/hd.hive.csv.table.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.execute/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.execute/hd.hive.execute.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.execute/hd.hive.execute.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.info/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.info/hd.hive.info.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.info/hd.hive.info.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.json.table/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.json.table/hd.hive.json.table.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.json.table/hd.hive.json.table.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.load/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.load/hd.hive.load.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.load/hd.hive.load.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.select/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.select/hd.hive.select.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hd.hive.select/hd.hive.select.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfsgrass/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfsgrass/__init__.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfsgrass/grass_map.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfsgrass/hdfs_grass_lib.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfsgrass/hdfs_grass_util.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfswrapper/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfswrapper/__init__.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfswrapper/base_hook.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfswrapper/connections.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfswrapper/hdfs_hook.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfswrapper/hive_hook.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfswrapper/hive_table.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfswrapper/security_utils.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfswrapper/settings.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfswrapper/utils.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/hadoop/hd/hdfswrapper/webhdfs_hook.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm.png
Modified: svn:mime-type
   - application/octet-stream
   + image/png
Property changes on: grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm_edit.png
   + image/png
Property changes on: grass-addons/grass7/raster/r.colors.matplotlib/r_colors_matplotlib_viscm_properties.png
   + image/png
Property changes on: grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_ncspm.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_trivial.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/raster/r.forestfrag/testsuite/r_forestfrag_xy.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/vector/v.explode/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/vector/v.explode/v.explode.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/vector/v.explode/v.explode.py
   + text/x-python
   + native
Property changes on: grass-addons/grass7/vector/v.what.spoly/Makefile
   + text/x-makefile
   + native
Property changes on: grass-addons/grass7/vector/v.what.spoly/v.what.spoly.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Property changes on: grass-addons/grass7/vector/v.what.spoly/v.what.spoly.py
   + text/x-python
   + native
