[GRASS-SVN] r68762 - sandbox/bo/i.segment.gsoc2016/i.segment
svn_grass at osgeo.org
Fri Jun 24 13:42:24 PDT 2016
Author: hao2309
Date: 2016-06-24 13:42:24 -0700 (Fri, 24 Jun 2016)
New Revision: 68762
sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c
change L46 of write_output.c
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c 2016-06-24 15:56:04 UTC (rev 68761)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/mean_shift.c 2016-06-24 20:42:24 UTC (rev 68762)
@@ -146,8 +146,8 @@
if (new_val = 0 || old_val == new_val){
if (old_val ==0){
class_val+=1;
@@ -162,131 +162,8 @@
return TRUE;
-// /* /* int clustering(struct globals *globals){
- // int row, col, n;
- // int seg_id, class_val;
- // struct ngbr_stats Rin, Rleft, Rabove;
- // CELL left_new_val, above_new_val, Rtemp;
- // double min_val, max_val, old_val, new_val;
- // double cluster_threshold, cluster_threshold2;
- // * Part 2 cluster similar values *
- // * Refer clump.c to cluster super-pixels *
- // Rleft.mean = G_malloc(globals->datasize);
- // Rin.mean = G_malloc(globals->datasize);
- // Rabove.mean = G_malloc(globals->datasize);
- // G_message(_("Pass 1 of 2 for clustering"));
- // G_percent_reset();
- // class_val=0;
- // cluster_threshold = 0.05;
- // cluster_threshold2= pow(cluster_threshold ,2);
- // for (row = globals->row_min; row < globals->row_max; row++) {
- // G_percent(row - globals->row_min,
- // globals->row_max - globals->row_min, 4);
- // for (col = globals->col_min; col < globals->col_max; col++) {
- // if (!(FLAG_GET(globals->candidate_flag, row, col)))
- // continue;
- // old_val=new_val=0;
- // /* get the current pixel value */
- // Segment_get(&globals->bands_seg2, (void *)Rin.mean, row, col);
- // /* get left pixel value */
- // if (col == globals->col_min && row == globals->row_min){
- // class_val+=1;
- // seg_id=class_val;
- // else if (row == globals->row_min){
- // /* compare with left value and set if same cluster */
- // Segment_get(&globals->bands_seg2, (void *)Rleft.mean, row, col-1);
- // if ((globals->calculate_similarity)(&Rin, &Rleft, globals) <= cluster_threshold2){
- // G_debug(1, "row: %d, col: %d, left_similarity is: %f",row,col,(globals->calculate_similarity)(&Rin, &Rleft, globals));
- // Segment_get(&globals->rid_seg, (void *)&left_new_val, row, col-1);
- // seg_id = left_new_val;
- // /* end compare left */
- // else{
- // class_val+=1;
- // else if(col == globals->col_min){
- // /* compare with above value and set if same cluster */
- // Segment_get(&globals->bands_seg2, (void *)Rabove.mean, row-1, col);
- // if ((globals->calculate_similarity)(&Rin, &Rabove, globals) <= cluster_threshold2){
- // G_debug(1, "row: %d, col: %d, above_similarity is: %f",row,col,(globals->calculate_similarity)(&Rin, &Rabove, globals));
- // Segment_get(&globals->rid_seg, (void *)&above_new_val, row-1, col);
- // seg_id = above_new_val;
- // /* end compare above */
- // else{
- // class_val+=1;
- // else{
- // /* compare with left value then above value */
- // old_val =seg_id = left_new_val;
- // if((globals->calculate_similarity)(&Rin, &Rabove, globals) <= cluster_threshold2){
- // if (old_val == 0){
- // old_val = above_new_val;
- // else{
- // new_val = above_new_val;
- // if (old_val != new_val){
- // /* conflict! preserve NEW clump ID and change OLD clump ID.
- // * Must go back to the left in the current row and to the right
- // * in the previous row to change all the clump values as well.
- // for(n = globals->col_min+1; n< col; n++){
- // Segment_get(&globals->rid_seg, (void *)&Rtemp, row, n);
- // if (Rtemp==old_val){
- // Segment_put(&globals->rid_seg, &new_val, row, n);
- /* right of previous row from col + 1 to ncols */
- // for(n = col+1; n< globals->col_max; n++){
- // Segment_get(&globals->rid_seg, (void *)&Rtemp, row-1, n);
- // Segment_put(&globals->rid_seg, &new_val, row-1, n);
- // if (new_val ==0 && old_val ==0){
- // class_val+=1;
- // seg_id = class_val;
- // Segment_put(&globals->rid_seg, &seg_id, row, col);
- // G_debug(1, "row: %d, col: %d, Rin is: %f",row,col,Rin.mean[0]);
- // G_debug(1, "row: %d, col: %d, seg_id is: %d",row,col,seg_id);
- // G_debug(1, "row: %d, col: %d, cluster_threshold * globals->max_diff is: %f",row,col,pow((cluster_threshold * globals->max_diff),2));
- // return TRUE;
int mean_shift(struct globals *globals)
int row, col, t, n1, n2;
Modified: sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c
--- sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c 2016-06-24 15:56:04 UTC (rev 68761)
+++ sandbox/bo/i.segment.gsoc2016/i.segment/write_output.c 2016-06-24 20:42:24 UTC (rev 68762)
@@ -43,8 +43,8 @@
G_debug(1, "preparing shifted value output raster");
/* open output raster map */
for (n=0;n<globals->nbands; n++){
- G_asprintf(&shifted_out_name, "%s_%s", Ref.file[n].name, globals->ms_suffix);
- // G_asprintf(&shifted_out_name, "%s_%d", globals->ms_suffix, n);
+ G_asprintf(&shifted_out_name, "%s%s", Ref.file[n].name, globals->ms_suffix);
seg2_fd[n] = Rast_open_new(shifted_out_name, DCELL_TYPE);
G_debug(1, "start data transfer from seg2 file to raster");
