[GRASS-SVN] r68771 - in grass/trunk/scripts: v.db.addcolumn v.db.addtable
Sun Jun 26 07:37:10 PDT 2016
Author: neteler
Date: 2016-06-26 07:37:10 -0700 (Sun, 26 Jun 2016)
New Revision: 68771
   grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
   grass/trunk/scripts/v.db.addtable/v.db.addtable.py
v.db.addcolumn, v.db.addtable: better use msg
Modified: grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
--- grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py	2016-06-26 14:02:08 UTC (rev 68770)
+++ grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py	2016-06-26 14:37:10 UTC (rev 68771)
@@ -34,7 +34,7 @@
 #% key: columns
 #% type: string
 #% label: Name and type of the new column(s) ('name type [,name type, ...]')
-#% description: Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: 'label varchar(250), type integer'
+#% description: Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: 'label varchar(250), value integer'
 #% required: yes
 #% multiple: yes
 #% key_desc: name type
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2016-06-26 14:02:08 UTC (rev 68770)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2016-06-26 14:37:10 UTC (rev 68771)
@@ -45,7 +45,7 @@
 #% key: columns
 #% type: string
 #% required: no
 #% multiple: yes
