[GRASS-SVN] r68803 - grass/branches/releasebranch_7_2/lib/init
svn_grass at osgeo.org
Thu Jun 30 00:45:49 PDT 2016
Author: neteler
Date: 2016-06-30 00:45:49 -0700 (Thu, 30 Jun 2016)
New Revision: 68803
grass/branches/releasebranch_7_2/lib/init/grass.py
grass.py init: advise user about manual, --help and -c; shorten messages (trunk, r68795 + r68797 + r68802)
Modified: grass/branches/releasebranch_7_2/lib/init/grass.py
--- grass/branches/releasebranch_7_2/lib/init/grass.py 2016-06-30 07:44:24 UTC (rev 68802)
+++ grass/branches/releasebranch_7_2/lib/init/grass.py 2016-06-30 07:45:49 UTC (rev 68803)
@@ -975,7 +975,11 @@
" report this error to the GRASS developers.\n"
"On systems with package manager, make sure you have the right"
" GUI package, probably named grass-gui, installed.\n"
- "To run GRASS GIS in text mode use the -text flag."))
+ "To run GRASS GIS in text mode use the -text flag.\n"
+ "Use '--help' for further options\n"
+ " {cmd_name} --help\n"
+ "See also: https://grass.osgeo.org/{cmd_name}/manuals/helptext.html").format(
+ cmd_name=cmd_name))
elif ret == 5: # defined in gui/wxpython/gis_set.py
# User wants to exit from GRASS
message(_("Exit was requested in GUI.\nGRASS GIS will not start. Bye."))
@@ -1824,12 +1828,20 @@
if not os.access(gisrc, os.F_OK):
if grass_gui == 'text' and not params.mapset:
fatal(_("Unable to start GRASS GIS. You have the choice to:\n"
- " - Launch the GRASS GIS interface with"
- " the '-gui' switch (`{cmd_name} -gui`)\n"
- " - Launch GRASS GIS directly with path to "
- "the location/mapset as an argument"
- " (`{cmd_name} /path/to/location/mapset`)\n"
- " - Create manually the GISRC file ({gisrcrc})").format(
+ " - Launch the graphical user interface with"
+ " the '-gui' switch\n"
+ " {cmd_name} -gui\n"
+ " - Launch with path to "
+ "the location/mapset as an argument\n"
+ " {cmd_name} /path/to/location/mapset`\n"
+ " - Create a location with '-c' and launch in its"
+ " PERMANENT mapset\n"
+ " {cmd_name} -c EPSG:number /path/to/location\n"
+ " {cmd_name} -c geofile /path/to/location\n"
+ " - Create manually the GISRC file ({gisrcrc})\n"
+ " - Use '--help' for further options\n"
cmd_name=cmd_name, gisrcrc=gisrcrc))
create_initial_gisrc(gisrc)
else:
