[GRASS-SVN] r68809 - grass/trunk/lib/init
svn_grass at osgeo.org
Thu Jun 30 04:05:51 PDT 2016
Author: neteler
Date: 2016-06-30 04:05:51 -0700 (Thu, 30 Jun 2016)
New Revision: 68809
grass/trunk/lib/init/helptext.html
helptext.html: improved section about text-based location creation
Modified: grass/trunk/lib/init/helptext.html
--- grass/trunk/lib/init/helptext.html 2016-06-30 09:48:28 UTC (rev 68808)
+++ grass/trunk/lib/init/helptext.html 2016-06-30 11:05:51 UTC (rev 68809)
@@ -160,16 +160,22 @@
<h2>5. Text-based startup and location creation</h2>
-GRASS GIS can be run entirely without using the graphical user interface. For a first time startup, the following steps have to be followed:
+GRASS GIS can be run entirely without using the graphical user interface.
+For a first time startup, the following steps have to be followed:
<ol>
- <li> Create a GRASS database as explained above.</li>
- <li>Create a new location, including it's default PERMANENT mapset, without entering the new location:</li>
- <ul>
- <li>Using an EPSG code: <tt>grass70 -e -c EPSG:32630 /home/myuser/GRASSDATA/mylocation</tt></li>
- <li>Using a georeferenced file: <tt>grass70 -e -c MyGeoReferenceFile.tif /home/myuser/GRASSDATA/mylocation</tt></li>
- </ul>
- <li>Create new mapset within the new location and launch GRASS GIS within that mapset: <br><tt>grass70 -c /home/myuser/GRASSDATA/mylocation/mymapset </tt>
+<li> Create a GRASS GIS database as explained above.</li>
+<li> Create a new location, including it's default PERMANENT mapset,
+ without entering the new location:</li>
+<ul>
+ <li>Using an EPSG code:<br>
+ <tt>grass73 -e -c EPSG:32630 /home/user/grassdata/mylocation</tt></li>
+ <li>Using a georeferenced raster or vector file:<br>
+ <tt>grass73 -e -c MyGeoReferenceFile.tif /home/user/grassdata/mylocation</tt></li>
+</ul>
+<li> Create new mapset within the new location and launch GRASS GIS within
+ that mapset: <br>
+ <tt>grass73 -c /home/user/grassdata/mylocation/mymapset</tt>
</ol>
@@ -187,4 +193,7 @@
</em>
<p>
+ <a href="http://epsg.io/">List of EPSG codes</a> (Database of worldwide coordinate systems)
+<p>
<i>Last changed: $Date$</i>
