[GRASS-SVN] r67985 - grass/trunk/vector/v.net.distance
Tue Mar 1 15:25:46 PST 2016
Author: mmetz
Date: 2016-03-01 15:25:45 -0800 (Tue, 01 Mar 2016)
New Revision: 67985
   grass/trunk/vector/v.net.distance/main.c
   grass/trunk/vector/v.net.distance/v.net.distance.html
v.net.distance: fix path calculation, add new flag to produce single line paths
Modified: grass/trunk/vector/v.net.distance/main.c
--- grass/trunk/vector/v.net.distance/main.c	2016-03-01 23:21:49 UTC (rev 67984)
+++ grass/trunk/vector/v.net.distance/main.c	2016-03-01 23:25:45 UTC (rev 67985)
@@ -29,25 +29,26 @@
 int main(int argc, char *argv[])
     struct Map_info In, Out;
-    static struct line_pnts *Points;
+    static struct line_pnts *Points, *PPoints;
     struct line_cats *Cats, *TCats;
+    struct ilist *slist;
     struct GModule *module;	/* GRASS module for parsing arguments */
     struct Option *map_in, *map_out;
     struct Option *catf_opt, *fieldf_opt, *wheref_opt;
     struct Option *catt_opt, *fieldt_opt, *wheret_opt, *typet_opt;
     struct Option *afield_opt, *nfield_opt, *abcol, *afcol, *ncol, *atype_opt;
-    struct Flag *geo_f;
-    int with_z, geo;
+    struct Flag *geo_f, *segments_f;
+    int with_z, geo, segments;
     int atype, ttype;
     struct varray *varrayf, *varrayt;
     int flayer, tlayer;
     int afield, nfield;
     dglGraph_s *graph;
     struct ilist *nodest;
-    int i, nnodes, nlines;
+    int i, j, nnodes, nlines;
     int *dst, *nodes_to_features;
     int from_nr;			/* 'from' features not reachable */
-    dglInt32_t **prev;
+    dglInt32_t **nxt;
     struct line_cats **on_path;
     char buf[2000];
@@ -156,6 +157,17 @@
     geo_f->description =
 	_("Use geodesic calculation for longitude-latitude locations");
+    segments_f = G_define_flag();
+#if 0
+    /* use this to sync with v.net.path */
+    segments_f->key = 's';
+    segments_f->description = _("Write output as original input segments, "
+				"not each path as one line.");
+#else
+    segments_f->key = 'l';
+    segments_f->description = _("Write each output path as one line, "
+				"not as original input segments.");
+#endif
     /* options and flags parser */
     if (G_parser(argc, argv))
@@ -165,8 +177,10 @@
     ttype = Vect_option_to_types(typet_opt);
     Points = Vect_new_line_struct();
+    PPoints = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
     TCats = Vect_new_cats_struct();
+    slist = G_new_ilist();
     Vect_check_input_output_name(map_in->answer, map_out->answer,
 				 G_FATAL_EXIT);
@@ -192,16 +206,22 @@
     else
 	geo = 0;
+#if 0
+    segments = segments_f->answer;
+#else
+    segments = !segments_f->answer;
+#endif
     nnodes = Vect_get_num_nodes(&In);
     nlines = Vect_get_num_lines(&In);
     dst = (int *)G_calloc(nnodes + 1, sizeof(int));
-    prev = (dglInt32_t **) G_calloc(nnodes + 1, sizeof(dglInt32_t *));
+    nxt = (dglInt32_t **) G_calloc(nnodes + 1, sizeof(dglInt32_t *));
     nodes_to_features = (int *)G_calloc(nnodes + 1, sizeof(int));
     on_path =
 	(struct line_cats **)G_calloc(nlines + 1, sizeof(struct line_cats *));
-    if (!dst || !prev || !nodes_to_features || !on_path)
+    if (!dst || !nxt || !nodes_to_features || !on_path)
 	G_fatal_error(_("Out of memory"));
     for (i = 1; i <= nlines; i++)
@@ -235,12 +255,15 @@
 	G_fatal_error(_("No 'to' features"));
     if (0 != Vect_net_build_graph(&In, atype, afield, nfield, afcol->answer, abcol->answer,
-                                   ncol->answer, geo, 0))
+                                   ncol->answer, geo, 2))
         G_fatal_error(_("Unable to build graph for vector map <%s>"), Vect_get_full_name(&In));
     graph = Vect_net_get_graph(&In);
-    NetA_distance_from_points(graph, nodest, dst, prev);
+    G_message(_("Distances to 'to' features ..."));
+    NetA_distance_to_points(graph, nodest, dst, nxt);
     /* Create table */
     Fi = Vect_default_field_info(&Out, 1, NULL, GV_1TABLE);
     Vect_map_add_dblink(&Out, 1, NULL, Fi->table, GV_KEY_COLUMN, Fi->database,
@@ -303,11 +326,15 @@
 	    cost = dst[node] / (double)In.dgraph.cost_multip;
 	    vertex = dglGetNode(graph, node);
 	    vertex_id = node;
-	    while (prev[vertex_id] != NULL) {
-		Vect_cat_set(on_path
-			     [abs(dglEdgeGet_Id(graph, prev[vertex_id]))], 1,
-			     cat);
-		vertex = dglEdgeGet_Head(graph, prev[vertex_id]);
+	    slist->n_values = 0;
+	    while (nxt[vertex_id] != NULL) {
+		if (segments)
+		    Vect_cat_set(on_path
+				 [abs(dglEdgeGet_Id(graph, nxt[vertex_id]))], 1,
+				 cat);
+		else
+		    G_ilist_add(slist, dglEdgeGet_Id(graph, nxt[vertex_id]));
+		vertex = dglEdgeGet_Tail(graph, nxt[vertex_id]);
 		vertex_id = dglNodeGet_Id(graph, vertex);
 	    G_debug(3, "read line %d, vertex id %d", nodes_to_features[vertex_id], (int)vertex_id);
@@ -318,22 +345,41 @@
 	    Vect_write_line(&Out, type, Points, Cats);
 	    sprintf(buf, "insert into %s values (%d, %d, %f)", Fi->table, cat,
 		    tcat, cost);
 	    db_set_string(&sql, buf);
 	    G_debug(3, "%s", db_get_string(&sql));
 	    if (db_execute_immediate(driver, &sql) != DB_OK) {
 		G_fatal_error(_("Cannot insert new record: %s"),
+	    if (!segments) {
+		Vect_reset_line(PPoints);
+		for (j = 0; j < slist->n_values; j++) {
+		    Vect_read_line(&In, Points, NULL, abs(slist->value[j]));
+		    if (slist->value[j] > 0)
+			Vect_append_points(PPoints, Points,
+					   GV_FORWARD);
+		    else
+					   GV_BACKWARD);
+		    PPoints->n_points--;
+		PPoints->n_points++;
+		Vect_write_line(&Out, GV_LINE, PPoints, Cats);
-    for (i = 1; i <= nlines; i++)
-	if (on_path[i]->n_cats > 0) {
-	    int type = Vect_read_line(&In, Points, NULL, i);
+    if (segments) {
+	for (i = 1; i <= nlines; i++) {
+	    if (on_path[i]->n_cats > 0) {
+		int type = Vect_read_line(&In, Points, NULL, i);
-	    Vect_write_line(&Out, type, Points, on_path[i]);
+		Vect_write_line(&Out, type, Points, on_path[i]);
     db_commit_transaction(driver);
     db_close_database_shutdown_driver(driver);
@@ -348,7 +394,7 @@
     G_free(on_path);
     G_free(nodes_to_features);
     G_free(dst);
-    G_free(prev);
+    G_free(nxt);
     if (from_nr)
 	G_warning(n_("%d 'from' feature was not reachable",
Modified: grass/trunk/vector/v.net.distance/v.net.distance.html
--- grass/trunk/vector/v.net.distance/v.net.distance.html	2016-03-01 23:21:49 UTC (rev 67984)
+++ grass/trunk/vector/v.net.distance/v.net.distance.html	2016-03-01 23:25:45 UTC (rev 67985)
@@ -13,15 +13,18 @@
 specifically, the table has three columns: <em>cat</em>, <em>tcat</em>
 and <em>dist</em> storing category of each <em>from</em>
 feature, category of the nearest <em>to</em> feature and the
-distance between them respectively. Furthemore, <b>output</b> map
+distance between them respectively.
+<p>
+Furthemore, <b>output</b> map
 contains the shorest path between each <em>cat</em>, <em>tcat</em>
 pair. Each path consist of several lines. If a line is on the
-shorest path from a point then the category of this point is
+shortest path from a point then the category of this point is
 assigned to the line. Note that every line may contain more than one
 category value since a single line may be on the shortest path for
 more than one <em>from</em> feature. And so the shortest paths can
 be easily obtained by querying lines with corresponding category
-number.
+number. Alternatively, unique paths can be created with the <em>-l</em>
+flag where each path will be a separate single line in the output.
 <br>
 The costs of arcs in forward and backward direction are specified by
 <b>arc_column</b> and <b>arc_backward_column</b> columns respectively. If
@@ -62,7 +65,7 @@
 v.category in=streets_net2 op=report
 # shortest paths from schools (points in layer 2) to nearest hospitals (points in layer 3)
-v.net.distance in=streets_net2 out=schools_to_hospitals flayer=2 turn_layer=3
+v.net.distance in=streets_net2 out=schools_to_hospitals flayer=2 to_layer=3
 </pre></div>
 <h3>Distance between point source of pollution and sample points along streams</h3>
