[GRASS-SVN] r67988 - in grass-addons/grass7/raster/r.futures: r.futures.calib r.futures.pga
svn_grass at osgeo.org
Wed Mar 2 12:00:48 PST 2016
Author: annakrat
Date: 2016-03-02 12:00:48 -0800 (Wed, 02 Mar 2016)
New Revision: 67988
grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py
grass-addons/grass7/raster/r.futures/r.futures.pga/main.c
r.futures: make parameter incentive table not required; fix writing of the calibration file
Modified: grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py
--- grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py 2016-03-02 16:26:18 UTC (rev 67987)
+++ grass-addons/grass7/raster/r.futures/r.futures.calib/r.futures.calib.py 2016-03-02 20:00:48 UTC (rev 67988)
@@ -440,8 +440,8 @@
gcore.message(_("Analyzing original patches..."))
diff_development(dev_start, dev_end, options['subregions'], orig_patch_diff)
patch_analysis(orig_patch_diff, threshold, tmp_patch_vect, tmp_patch_vect2, temp_file.name)
+ write_patches_file(tmp_patch_vect, cell_size, patches_file)
if only_file:
- write_patches_file(tmp_patch_vect, cell_size, patches_file)
return
area, perimeter = np.loadtxt(fname=temp_file.name, unpack=True)
@@ -500,6 +500,7 @@
str(data['input_compactness_mean']), str(data['input_compactness_range']),
str(data['compactness_distance'])]))
f.write('\n')
+ f.flush()
proc_count = 0
proc_list = []
queue_list = []
Modified: grass-addons/grass7/raster/r.futures/r.futures.pga/main.c
--- grass-addons/grass7/raster/r.futures/r.futures.pga/main.c 2016-03-02 16:26:18 UTC (rev 67987)
+++ grass-addons/grass7/raster/r.futures/r.futures.pga/main.c 2016-03-02 20:00:48 UTC (rev 67988)
@@ -871,9 +871,11 @@
probAdd = getDevProbability(pThis, pParams);
/* replace with value from lookup table */
- lookupPos =
- (int)(probAdd * (pParams->nProbLookup - 1));
- probAdd = pParams->adProbLookup[lookupPos];
+ if (pParams->adProbLookup) {
+ lookupPos =
+ (int)(probAdd * (pParams->nProbLookup - 1));
+ probAdd = pParams->adProbLookup[lookupPos];
probAdd *= consWeight;
pNeighbours->aCandidates[pNeighbours->nCandidates].
probAdd = probAdd;
@@ -1602,7 +1604,7 @@
opt.probLookupFile = G_define_standard_option(G_OPT_F_INPUT);
opt.probLookupFile->key = "incentive_table";
- opt.probLookupFile->required = YES;
+ opt.probLookupFile->required = NO;
opt.probLookupFile->label =
_("File containing incentive lookup table (infill vs. sprawl)");
opt.probLookupFile->description =
@@ -1709,53 +1711,58 @@
FILE *fp;
char inBuff[N_MAXREADINLEN];
char *pPtr;
+ if (opt.probLookupFile->answer) {
+ G_verbose_message("Reading probability lookup ...");
+ sParams.probLookupFile = opt.probLookupFile->answer;
- G_verbose_message("Reading probability lookup ...");
- sParams.probLookupFile = opt.probLookupFile->answer;
- fp = fopen(sParams.probLookupFile, "r");
- if (fp) {
- parsedOK = 0;
- if (fgets(inBuff, N_MAXREADINLEN, fp)) {
- if (inBuff[0] == ',') {
- sParams.nProbLookup = atoi(inBuff + 1);
- if (sParams.nProbLookup > 0) {
- sParams.adProbLookup =
- (double *) G_malloc(sizeof(double) *
- sParams.nProbLookup);
- if (sParams.adProbLookup) {
- parsedOK = 1;
- i = 0;
- while (parsedOK && i < sParams.nProbLookup) {
- parsedOK = 0;
- if (pPtr = strchr(inBuff, ',')) {
- parsedOK = 1;
- sParams.adProbLookup[i] =
- atof(pPtr + 1);
- G_debug(3,
- "probability lookup table: i=%d, i/(n-1)=%f, result=%f",
- i,
- i * 1.0 /
- (sParams.nProbLookup - 1),
- sParams.adProbLookup[i]);
+ fp = fopen(sParams.probLookupFile, "r");
+ if (fp) {
+ parsedOK = 0;
+ if (fgets(inBuff, N_MAXREADINLEN, fp)) {
+ if (inBuff[0] == ',') {
+ sParams.nProbLookup = atoi(inBuff + 1);
+ if (sParams.nProbLookup > 0) {
+ sParams.adProbLookup =
+ (double *) G_malloc(sizeof(double) *
+ sParams.nProbLookup);
+ if (sParams.adProbLookup) {
+ parsedOK = 1;
+ i = 0;
+ while (parsedOK && i < sParams.nProbLookup) {
+ parsedOK = 0;
+ if (pPtr = strchr(inBuff, ',')) {
+ parsedOK = 1;
+ sParams.adProbLookup[i] =
+ atof(pPtr + 1);
+ G_debug(3,
+ "probability lookup table: i=%d, i/(n-1)=%f, result=%f",
+ i,
+ i * 1.0 /
+ (sParams.nProbLookup - 1),
+ sParams.adProbLookup[i]);
+ i++;
- i++;
+ if (!parsedOK) {
+ G_fatal_error("Error parsing probability lookup file '%s'",
+ sParams.probLookupFile);
+ fclose(fp);
- if (!parsedOK) {
- G_fatal_error("Error parsing probability lookup file '%s'",
+ else {
+ G_fatal_error("Error opening probability lookup file '%s'",
- fclose(fp);
else {
- G_fatal_error("Error opening probability lookup file '%s'",
- sParams.probLookupFile);
+ sParams.nProbLookup = 0;
+ sParams.adProbLookup = NULL;
sParams.patchMean = atof(opt.patchMean->answer);
@@ -1906,15 +1913,16 @@
G_debug(5, "logit value %f", val);
/* lookup table of probabilities is applied before consWeight */
- lookupPos = (int)(pLandscape->asUndevs[id]
- [pLandscape->num_undevSites[id]].
- logitVal * (pParams->nProbLookup - 1));
- if (lookupPos >= pParams->nProbLookup || lookupPos < 0)
- G_fatal_error("lookup position (%d) out of range [0, %d]",
- lookupPos, pParams->nProbLookup - 1);
- pLandscape->asUndevs[id][pLandscape->num_undevSites[id]].
- logitVal = pParams->adProbLookup[lookupPos];
+ lookupPos = (int)(pLandscape->asUndevs[id]
+ [pLandscape->num_undevSites[id]].
+ logitVal * (pParams->nProbLookup - 1));
+ if (lookupPos >= pParams->nProbLookup || lookupPos < 0)
+ G_fatal_error("lookup position (%d) out of range [0, %d]",
+ lookupPos, pParams->nProbLookup - 1);
+ pLandscape->asUndevs[id][pLandscape->num_undevSites[id]].
+ logitVal = pParams->adProbLookup[lookupPos];
// discount by a conservation factor
pLandscape->asUndevs[id][pLandscape->num_undevSites[id]].logitVal *= consWeight;
/* need to store this to put correct elements near top of list */
