[GRASS-SVN] r67992 - grass/trunk/lib/vector/neta
svn_grass at osgeo.org
Thu Mar 3 13:20:01 PST 2016
Author: mmetz
Date: 2016-03-03 13:20:01 -0800 (Thu, 03 Mar 2016)
New Revision: 67992
grass/trunk/lib/vector/neta/path.c
netalib, path.c: consider node costs, update documentation
Modified: grass/trunk/lib/vector/neta/path.c
--- grass/trunk/lib/vector/neta/path.c 2016-03-03 21:12:15 UTC (rev 67991)
+++ grass/trunk/lib/vector/neta/path.c 2016-03-03 21:20:01 UTC (rev 67992)
@@ -11,6 +11,7 @@
(>=v2). Read the file COPYING that comes with GRASS for details.
\author Daniel Bundala (Google Summer of Code 2009)
+ \author Markus Metz
#include <stdio.h>
@@ -24,14 +25,14 @@
\brief Computes shortest paths to every node from nodes in "from".
- Array "dst" contains the length of the path or -1 if the node is not
+ Array "dst" contains the cost of the path or -1 if the node is not
reachable. Prev contains edges from predecessor along the shortest
path.
\param graph input graph
\param from list of 'from' positions
- \param dst list of 'to' positions
- \param[out] prev list of edges from predecessor along the shortest path
+ \param[out] dst array of costs to reach nodes
+ \param[out] prev array of edges from predecessor along the shortest path
\return 0 on success
\return -1 on failure
@@ -41,6 +42,8 @@
int i, nnodes;
dglHeap_s heap;
+ int have_node_costs;
+ dglInt32_t ncost;
nnodes = dglGet_NodeCount(graph);
dglEdgesetTraverser_s et;
@@ -51,6 +54,9 @@
prev[i] = NULL;
+ ncost = 0;
+ have_node_costs = dglGet_NodeAttrSize(graph);
dglHeapInit(&heap);
for (i = 0; i < from->n_values; i++) {
@@ -68,6 +74,8 @@
dglInt32_t v, dist;
dglHeapNode_s heap_node;
dglHeapData_u heap_data;
+ dglInt32_t *edge;
+ dglInt32_t *node;
if (!dglHeapExtractMin(&heap, &heap_node))
break;
@@ -76,11 +84,20 @@
if (dst[v] < dist)
continue;
- dglInt32_t *edge;
+ node = dglGetNode(graph, v);
+ if (have_node_costs && prev[v]) {
+ memcpy(&ncost, dglNodeGet_Attr(graph, node),
+ sizeof(ncost));
+ if (ncost > 0)
+ dist += ncost;
+ /* do not go through closed nodes */
+ if (ncost < 0)
+ continue;
dglEdgeset_T_Initialize(&et, graph,
- dglNodeGet_OutEdgeset(graph,
- dglGetNode(graph, v)));
+ dglNodeGet_OutEdgeset(graph, node));
for (edge = dglEdgeset_T_First(&et); edge;
edge = dglEdgeset_T_Next(&et)) {
@@ -107,14 +124,15 @@
\brief Computes shortest paths from every node to nodes in "to".
reachable. Nxt contains edges from successor along the shortest
- path.
+ path. This method does reverse search starting with "to" nodes and
+ going backward.
- \param from list of 'from' positions
- \param[out] nxt list of edges from successor along the shortest path
+ \param to list of 'to' positions
+ \param[out] nxt array of edges from successor along the shortest path
@@ -125,6 +143,8 @@
int i, nnodes;
dglHeap_s heap;
+ dglInt32_t ncost;
@@ -139,6 +159,9 @@
return -1;
+ ncost = 0;
dglHeapInit(&heap);
for (i = 0; i < to->n_values; i++) {
@@ -156,6 +179,8 @@
dglInt32_t v, dist;
+ dglInt32_t *edge;
+ dglInt32_t *node;
break;
@@ -164,11 +189,20 @@
if (dst[v] < dist)
continue;
- dglInt32_t *edge;
+ if (have_node_costs && nxt[v]) {
+ sizeof(ncost));
+ if (ncost > 0)
+ dist += ncost;
+ if (ncost < 0)
+ continue;
- dglNodeGet_InEdgeset(graph,
+ dglNodeGet_InEdgeset(graph, node));
@@ -193,16 +227,18 @@
- \brief Find a path (minimum number of edges) from 'from' to 'to' using only edges in 'edges'.
+ \brief Find a path (minimum number of edges) from 'from' to 'to'
+ using only edges flagged as valid in 'edges'. Edge costs are not
+ considered. Closed nodes are not traversed.
Precisely, edge with id I is used if edges[abs(i)] == 1. List
- stores the indices of lines on the path. Method return number of
- edges or -1 if no path exist.
+ stores the indices of lines on the path. The method returns the
+ number of edges or -1 if no path exists.
\param from 'from' position
\param to 'to' position
- \param edges list of available edges
+ \param edges array of edges indicating wether an edge should be used
\param[out] list list of edges
\return number of edges
@@ -215,6 +251,8 @@
char *vis;
int begin, end, cur, nnodes;
+ dglInt32_t ncost;
prev = (dglInt32_t **) G_calloc(nnodes + 1, sizeof(dglInt32_t *));
@@ -226,6 +264,9 @@
Vect_reset_list(list);
+ ncost = 0;
begin = 0;
end = 1;
vis[from] = 'y';
@@ -233,22 +274,32 @@
prev[from] = NULL;
while (begin != end) {
dglInt32_t vertex = queue[begin++];
+ dglInt32_t *edge, *node;
if (vertex == to)
break;
- dglInt32_t *edge, *node = dglGetNode(graph, vertex);
+ if (have_node_costs && prev[vertex]) {
+ memcpy(&ncost, dglNodeGet_Attr(graph, dglEdgeGet_Tail(graph, edge)),
+ sizeof(ncost));
+ if (ncost < 0)
+ continue;
+ node = dglGetNode(graph, vertex);
- dglInt32_t id = abs(dglEdgeGet_Id(graph, edge));
- dglInt32_t to =
+ dglInt32_t edge_id = abs(dglEdgeGet_Id(graph, edge));
+ dglInt32_t node_id =
dglNodeGet_Id(graph, dglEdgeGet_Tail(graph, edge));
- if (edges[id] && !vis[to]) {
- vis[to] = 'y';
- prev[to] = edge;
- queue[end++] = to;
+ if (edges[edge_id] && !vis[node_id]) {
+ vis[node_id] = 'y';
+ prev[node_id] = edge;
+ queue[end++] = node_id;
dglEdgeset_T_Release(&et);
