[GRASS-SVN] r68005 - grass/trunk/vector/v.net.components
svn_grass at osgeo.org
Sat Mar 5 14:25:33 PST 2016
Author: mmetz
Date: 2016-03-05 14:25:33 -0800 (Sat, 05 Mar 2016)
New Revision: 68005
grass/trunk/vector/v.net.components/main.c
grass/trunk/vector/v.net.components/v.net.components.html
v.net.components: various bug fixes
Modified: grass/trunk/vector/v.net.components/main.c
--- grass/trunk/vector/v.net.components/main.c 2016-03-05 10:15:36 UTC (rev 68004)
+++ grass/trunk/vector/v.net.components/main.c 2016-03-05 22:25:33 UTC (rev 68005)
@@ -4,6 +4,7 @@
* MODULE: v.net.components
* AUTHOR(S): Daniel Bundala
+ * Markus Metz
* PURPOSE: Computes strongly and weakly connected components
@@ -54,7 +55,7 @@
int with_z;
int afield, nfield, mask_type;
dglGraph_s *graph;
- int *component, nnodes, type, i, nlines, components, j, max_cat;
+ int *component, nnodes, type, i, nlines, components, max_cat;
char buf[2000], *covered;
char *desc;
@@ -158,7 +159,7 @@
nfield = Vect_get_field_number(&In, nfield_opt->answer);
if (0 != Vect_net_build_graph(&In, mask_type, afield, nfield, afcol->answer,
- abcol->answer, ncol->answer, 0, 0))
+ abcol->answer, ncol->answer, 0, 2))
G_fatal_error(_("Unable to build graph for vector map <%s>"), Vect_get_full_name(&In));
graph = Vect_net_get_graph(&In);
@@ -198,21 +199,30 @@
db_begin_transaction(driver);
- if (method_opt->answer[0] == 'w')
+ if (method_opt->answer[0] == 'w') {
+ G_message(_("Computing weakly connected components..."));
components = NetA_weakly_connected_components(graph, component);
- else
+ else {
+ G_message(_("Computing strongly connected components..."));
components = NetA_strongly_connected_components(graph, component);
G_debug(3, "Components: %d", components);
+ G_message(_("Writing output..."));
Vect_copy_head_data(&In, &Out);
Vect_hist_copy(&In, &Out);
Vect_hist_command(&Out);
nlines = Vect_get_num_lines(&In);
+ max_cat = 1;
+ G_percent(0, nlines, 4);
for (i = 1; i <= nlines; i++) {
int comp, cat;
+ G_percent(i, nlines, 4);
type = Vect_read_line(&In, Points, Cats, i);
if (!Vect_cat_get(Cats, afield, &cat))
continue;
@@ -232,29 +242,23 @@
/* Vect_get_line_nodes(&In, i, &node, NULL); */
node = Vect_find_node(&In, Points->x[0], Points->y[0], Points->z[0], 0, 0);
+ if (!node)
+ continue;
comp = component[node];
covered[node] = 1;
else
continue;
+ cat = max_cat++;
+ Vect_reset_cats(Cats);
+ Vect_cat_set(Cats, 1, cat);
Vect_write_line(&Out, type, Points, Cats);
insert_new_record(driver, Fi, &sql, cat, comp);
- /* for(j=0;j<Cats->n_cats;j++)
- * if(Cats->field[j] == layer)
- * insert_new_record(driver, Fi, &sql, Cats->cat[j], comp);
/*add points on nodes not covered by any point in the network */
- /*find the maximum cat number */
if (add_f->answer) {
- max_cat = 0;
- for (i = 1; i <= nlines; i++) {
- Vect_read_line(&In, NULL, Cats, i);
- for (j = 0; j < Cats->n_cats; j++)
- if (Cats->cat[j] > max_cat)
- max_cat = Cats->cat[j];
- max_cat++;
for (i = 1; i <= nnodes; i++)
if (!covered[i]) {
@@ -267,10 +271,12 @@
db_commit_transaction(driver);
db_close_database_shutdown_driver(driver);
+ Vect_close(&In);
Vect_build(&Out);
- Vect_close(&In);
Vect_close(&Out);
+ G_done_msg(_("Found %d components."), components);
exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.net.components/v.net.components.html
--- grass/trunk/vector/v.net.components/v.net.components.html 2016-03-05 10:15:36 UTC (rev 68004)
+++ grass/trunk/vector/v.net.components/v.net.components.html 2016-03-05 22:25:33 UTC (rev 68005)
@@ -4,22 +4,28 @@
components in a network.
<h2>NOTES</h2>
-Two nodes, <em>u</em> and <em>v</em> are in the same strongly
-connected component if there are directed paths from <em>u</em> to
-<em>v</em> and from <em>v</em> to <em>u</em>. The nodes are in the
-same weakly connected component if, ignoring orientation of the
-edges, there is a path between them.
-<br>
+Two nodes, <em>u</em> and <em>v</em> are in the same strongly connected
+component if there are directed paths from <em>u</em> to <em>v</em> and
+from <em>v</em> to <em>u</em>. The nodes are in the same weakly
+connected component if, ignoring edge directions, there is a path
+between them.
+<p>
The type of components is specified by <b>method</b> parameter.
-<em>v.net.components</em> creates a table and links it to the given <b>layer</b>.
-This table contains only two integer columns: <em>cat</em> and <em>comp
-</em>. If a point or both endpoints of a line belong to the same
-component then the point/line is written to the output map and
+<em>v.net.components</em> creates a table and links it to layer 1. This
+table contains only two integer columns: <em>cat</em> and
+<em>comp</em>. If a point or both endpoints of a line belong to the
+same component then the point/line is written to the output map and
appropriate information is stored in the table. If <b>-a</b> flag is
-set then new points are added on the nodes without points. These
-points have category numbers larger than any category used in the
-input map.
+set then new points are added on the nodes without points. These points
+have category numbers larger than any category used in the input map.
+<p>
+One-way roads can be defined by assigning a cost of -1 to the
+appropriate cost column (<b>arc_column</b> or
+<b>arc_backward_column</b>. This affects only strongly connected
+components. Network nodes can be closed by assigning a cost of -1 to
+the node cost column. All nodes with a cost < 0 can not be traversed
+and are end points, while all nodes with a cost ≥ 0 can be traversed.
+This affects both weakly and strongly connected components.
<h2>EXAMPLES</h2>
@@ -39,6 +45,7 @@
<h2>AUTHORS</h2>
Daniel Bundala, Google Summer of Code 2009, Student<br>
-Wolf Bergenheim, Mentor
+Wolf Bergenheim, Mentor<br>
+Markus Metz
<p><i>Last changed: $Date$</i>
