[GRASS-SVN] r68007 - grass/trunk/lib/vector/neta
svn_grass at osgeo.org
Sat Mar 5 14:32:01 PST 2016
Author: mmetz
Date: 2016-03-05 14:32:01 -0800 (Sat, 05 Mar 2016)
New Revision: 68007
grass/trunk/lib/vector/neta/flow.c
netalib: consider closed nodes
Modified: grass/trunk/lib/vector/neta/flow.c
--- grass/trunk/lib/vector/neta/flow.c 2016-03-05 22:27:31 UTC (rev 68006)
+++ grass/trunk/lib/vector/neta/flow.c 2016-03-05 22:32:01 UTC (rev 68007)
@@ -33,7 +33,7 @@
\brief Get max flow from source to sink.
Array flow stores flow for each edge. Negative flow corresponds to a
- flow in opposite direction The function assumes that the edge costs
+ flow in opposite direction. The function assumes that the edge costs
correspond to edge capacities.
\param graph input graph
@@ -53,6 +53,8 @@
dglInt32_t **prev;
char *is_source, *is_sink;
int begin, end, total_flow;
+ int have_node_costs;
+ dglInt32_t ncost;
nnodes = dglGet_NodeCount(graph);
nlines = dglGet_EdgeCount(graph) / 2; /*each line corresponds to two edges. One in each direction */
@@ -73,6 +75,9 @@
for (i = 0; i <= nlines; i++)
flow[i] = 0;
+ ncost = 0;
+ have_node_costs = dglGet_NodeAttrSize(graph);
total_flow = 0;
while (1) {
dglInt32_t node, edge_id, min_residue;
@@ -104,7 +109,13 @@
found = to;
break;
- queue[end++] = to;
+ /* do not go through closed nodes */
+ if (have_node_costs) {
+ memcpy(&ncost, dglNodeGet_Attr(graph, dglEdgeGet_Tail(graph, edge)),
+ sizeof(ncost));
+ if (ncost >= 0)
+ queue[end++] = to;
dglEdgeset_T_Release(&et);
@@ -280,6 +291,9 @@
if (node_costs)
cost = node_costs[v];
+ /* skip closed nodes */
+ if (cost < 0)
+ continue;
if (cost > max_node_cost)
max_node_cost = cost;
dglAddEdge(out, 2 * v - 1, 2 * v, cost, edge_cnt);
@@ -292,7 +306,14 @@
dglEdgesetTraverser_s et;
dglInt32_t *edge;
dglInt32_t v = dglNodeGet_Id(in, cur_node);
+ dglInt32_t cost = 1;
+ if (node_costs)
+ cost = node_costs[v];
+ if (cost < 0)
+ continue;
dglEdgeset_T_Initialize(&et, in, dglNodeGet_OutEdgeset(in, cur_node));
for (edge = dglEdgeset_T_First(&et); edge;
edge = dglEdgeset_T_Next(&et)) {
