[GRASS-SVN] r68023 - grass/branches/releasebranch_7_0/lib/vector/Vlib
svn_grass at osgeo.org
Tue Mar 8 12:53:29 PST 2016
Author: mmetz
Date: 2016-03-08 12:53:29 -0800 (Tue, 08 Mar 2016)
New Revision: 68023
grass/branches/releasebranch_7_0/lib/vector/Vlib/net.c
Vlib: support different graph versions
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/net.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/net.c 2016-03-08 17:02:53 UTC (rev 68022)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/net.c 2016-03-08 20:53:29 UTC (rev 68023)
@@ -78,7 +78,7 @@
\param abcol column with backward costs for arc (if NULL, back costs = forward costs),
\param ncol column with costs for nodes (if NULL, do not use node costs),
\param geo use geodesic calculation for length (LL),
- \param algorithm not used (in future code for algorithm)
+ \param version graph version to create (1, 2, 3)
\return 0 on success, 1 on error
@@ -89,7 +89,7 @@
int nfield,
const char *afcol,
const char *abcol,
- const char *ncol, int geo, int algorithm)
+ const char *ncol, int geo, int version)
int i, j, from, to, line, nlines, nnodes, ret, type, cat, skipped, cfound;
int dofw, dobw;
@@ -148,11 +148,14 @@
Map->dgraph.node_costs[i] = 0;
+ if (version < 1 || version > 3)
+ version = 1;
if (ncol != NULL)
- dglInitialize(gr, (dglByte_t) 1, sizeof(dglInt32_t), (dglInt32_t) 0,
+ dglInitialize(gr, (dglByte_t) version, sizeof(dglInt32_t), (dglInt32_t) 0,
opaqueset);
else
- dglInitialize(gr, (dglByte_t) 1, (dglInt32_t) 0, (dglInt32_t) 0,
+ dglInitialize(gr, (dglByte_t) version, (dglInt32_t) 0, (dglInt32_t) 0,
opaqueset);
if (gr == NULL)
