[GRASS-SVN] r68028 - in grass-addons/grass7: . db db/db.join
svn_grass at osgeo.org
Wed Mar 9 02:08:11 PST 2016
Author: neteler
Date: 2016-03-09 02:08:11 -0800 (Wed, 09 Mar 2016)
New Revision: 68028
Added:
grass-addons/grass7/db/
grass-addons/grass7/db/db.join/
grass-addons/grass7/db/db.join/Makefile
grass-addons/grass7/db/db.join/db.join.html
grass-addons/grass7/db/db.join/db.join.py
db.join addon: first attempt; derived from v.db.join
Added: grass-addons/grass7/db/db.join/Makefile
--- grass-addons/grass7/db/db.join/Makefile (rev 0)
+++ grass-addons/grass7/db/db.join/Makefile 2016-03-09 10:08:11 UTC (rev 68028)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = db.join
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/db/db.join/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/db/db.join/db.join.html
--- grass-addons/grass7/db/db.join/db.join.html (rev 0)
+++ grass-addons/grass7/db/db.join/db.join.html 2016-03-09 10:08:11 UTC (rev 68028)
@@ -0,0 +1,47 @@
+<h2>DESCRIPTION</h2>
+<em>db.join</em> joins the content of one attribute table into another
+attribute table through common attributes.
+<h2>NOTES</h2>
+<em>db.join</em> is a front-end to <em>db.execute</em> to allow easier usage.
+The attribute table must be stored in a SQL database (SQLite, PostgreSQL,
+MySQL, ODBC, ...). The DBF backend is not supported. Tables can be
+imported with <em>db.in.ogr</em>.
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+# join soils_legend into mysoils attribute table
+db.join mysoils col=label otable=soils_legend ocol=shortname
+# verification of join
+db.select mysoils
+cat|label|id|shortname|longname
+1|Aab|||
+2|Ba|2|Ba|Barnum silt loam
+3|Bb|3|Bb|Barnum silt loam, channeled
+4|BcB|4|BcB|Boneek silt loam, 2 to 6
+5|BcC|5|BcC|Boneek silt loam, 6 to 9
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="db.execute.html">db.execute</a>,
+<a href="db.in.ogr.html">db.in.ogr</a>,
+<a href="db.select.html">db.select</a>,
+<a href="v.db.join.html">v.db.join</a>,
+<a href="v.db.update.html">v.db.update</a><br>
+<a href="sql.html">GRASS SQL interface</a>
+</em>
+<h2>AUTHOR</h2>
+Markus Neteler
+<p><i>Last changed: $Date$</i>
Property changes on: grass-addons/grass7/db/db.join/db.join.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/db/db.join/db.join.py
--- grass-addons/grass7/db/db.join/db.join.py (rev 0)
+++ grass-addons/grass7/db/db.join/db.join.py 2016-03-09 10:08:11 UTC (rev 68028)
@@ -0,0 +1,170 @@
+#!/usr/bin/env python
+# MODULE: db.join
+# AUTHOR(S): Markus Neteler
+# Derived from v.db.join
+# PURPOSE: Join a table to another table
+# COPYRIGHT: (C) 2016 by Markus Neteler and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Joins a database table to another database table.
+#% keyword: database
+#% keyword: attribute table
+#%end
+#%option G_OPT_DB_TABLE
+#% description: Table to which to join other table
+#% required : yes
+#%end
+#%option G_OPT_DB_COLUMN
+#% description: Identifier column (e.g.: cat) in the table to be used for join
+#% required : yes
+#%end
+#% key: other_table
+#% description: Other table name
+#% required: yes
+#% guidependency: ocolumn,scolumns
+#%end
+#%option G_OPT_DB_DATABASE
+#%end
+#%option G_OPT_DB_DRIVER
+#% options: dbf,odbc,ogr,sqlite,pg
+#%end
+#% key: other_column
+#% description: Identifier column (e.g.: id) in the other table used for join
+#% required: yes
+#%end
+#% key: subset_columns
+#% multiple: yes
+#% required: no
+#% description: Subset of columns from the other table
+#%end
+import sys
+import string
+import grass.script as grass
+from grass.exceptions import CalledModuleError
+def main():
+ table = options['table']
+ column = options['column']
+ otable = options['other_table']
+ ocolumn = options['other_column']
+ if options['subset_columns']:
+ scolumns = options['subset_columns'].split(',')
+ else:
+ scolumns = None
+ database = options['database']
+ driver = options['driver']
+ # this error handling is completely different among th db.* scripts - FIX
+ if not database:
+ database = None
+ if not driver:
+ driver = None
+ if driver == 'dbf':
+ grass.fatal(_("JOIN is not supported for tables stored in DBF format"))
+ # describe input table
+ all_cols_tt = grass.db_describe(table, driver=driver, database=database)['cols']
+ if not all_cols_tt:
+ grass.fatal(_("Unable to describe table <%s>") % table)
+ found = False
+ # check if column is in input table
+ if column not in [col[0] for col in all_cols_tt]:
+ grass.fatal(_("Column <%s> not found in table <%s>") % (column, table))
+ # describe other table
+ all_cols_ot = grass.db_describe(otable, driver=driver, database=database)['cols']
+ # check if ocolumn is in other table
+ if ocolumn not in [ocol[0] for ocol in all_cols_ot]:
+ grass.fatal(_("Column <%s> not found in table <%s>") % (ocolumn, otable))
+ # determine columns subset from other table
+ if not scolumns:
+ # select all columns from other table
+ cols_to_add = all_cols_ot
+ else:
+ cols_to_add = []
+ # check if scolumns exists in the other table
+ for scol in scolumns:
+ found = False
+ for col_ot in all_cols_ot:
+ if scol == col_ot[0]:
+ found = True
+ cols_to_add.append(col_ot)
+ break
+ if not found:
+ grass.warning(_("Column <%s> not found in table <%s>") % (scol, otable))
+ select = "SELECT $colname FROM $otable WHERE $otable.$ocolumn=$table.$column"
+ template = string.Template("UPDATE $table SET $colname=(%s);" % select)
+ for col in cols_to_add:
+ # skip the vector column which is used for join
+ colname = col[0]
+ if colname == column:
+ continue
+ use_len = False
+ if len(col) > 2:
+ use_len = True
+ # Sqlite 3 does not support the precision number any more
+ if driver == "sqlite":
+ use_len = False
+ # MySQL - expect format DOUBLE PRECISION(M,D), see #2792
+ elif driver == "mysql" and col[1] == 'DOUBLE PRECISION':
+ use_len = False
+ if use_len:
+ coltype = "%s(%s)" % (col[1], col[2])
+ else:
+ coltype = "%s" % col[1]
+ colspec = "%s %s" % (colname, coltype)
+ # add only the new column to the table
+ if colname not in all_cols_tt:
+ try:
+ grass.run_command('db.addcolumn', table=table,
+ columns=colspec)
+ except CalledModuleError:
+ grass.fatal(_("Error creating column <%s>") % colname)
+ stmt = template.substitute(table=table, column=column,
+ otable=otable, ocolumn=ocolumn,
+ colname=colname)
+ grass.debug(stmt, 1)
+ grass.verbose(_("Updating column <%s> of table <%s>...") % (colname, table))
+ try:
+ grass.write_command('db.execute', stdin=stmt, input='-',
+ database=database, driver=driver)
+ grass.fatal(_("Error filling column <%s>") % colname)
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
Property changes on: grass-addons/grass7/db/db.join/db.join.py
Added: svn:executable
+ text/x-python
+ native
