[GRASS-SVN] r68031 - grass/trunk/lib/vector/neta
Wed Mar 9 12:38:32 PST 2016
Author: mmetz
Date: 2016-03-09 12:38:32 -0800 (Wed, 09 Mar 2016)
New Revision: 68031
   grass/trunk/lib/vector/neta/articulation_point.c
   grass/trunk/lib/vector/neta/components.c
   grass/trunk/lib/vector/neta/spanningtree.c
   grass/trunk/lib/vector/neta/utils.c
netalib: minor updates
Modified: grass/trunk/lib/vector/neta/articulation_point.c
--- grass/trunk/lib/vector/neta/articulation_point.c	2016-03-09 15:34:34 UTC (rev 68030)
+++ grass/trunk/lib/vector/neta/articulation_point.c	2016-03-09 20:38:32 UTC (rev 68031)
@@ -3,7 +3,7 @@
    \brief Network Analysis library - connected components
-   Computes strongly and weakly connected components.
+   Computes network articulation points.
    (C) 2009-2010 by Daniel Bundala, and the GRASS Development Team
Modified: grass/trunk/lib/vector/neta/components.c
--- grass/trunk/lib/vector/neta/components.c	2016-03-09 15:34:34 UTC (rev 68030)
+++ grass/trunk/lib/vector/neta/components.c	2016-03-09 20:38:32 UTC (rev 68031)
@@ -277,5 +277,7 @@
     dglNode_T_Release(&nt);
     G_free(stack);
+    G_free(order);
+    G_free(processed);
     return components;
Modified: grass/trunk/lib/vector/neta/spanningtree.c
--- grass/trunk/lib/vector/neta/spanningtree.c	2016-03-09 15:34:34 UTC (rev 68030)
+++ grass/trunk/lib/vector/neta/spanningtree.c	2016-03-09 20:38:32 UTC (rev 68031)
@@ -88,10 +88,12 @@
 int NetA_spanning_tree(dglGraph_s * graph, struct ilist *tree_list)
     int nnodes, edges, nedges, i, index;
-    edge_cost_pair *perm;	/*permutaion of edges in ascending order */
+    edge_cost_pair *perm;	/*permutation of edges in ascending order */
     struct union_find uf;
     dglEdgesetTraverser_s et;
+    /* TODO: consider closed nodes / node costs */
     nnodes = dglGet_NodeCount(graph);
     nedges = dglGet_EdgeCount(graph);
     perm = (edge_cost_pair *) G_calloc(nedges, sizeof(edge_cost_pair));
@@ -99,7 +101,7 @@
 	G_fatal_error(_("Out of memory"));
 	return -1;
-    /*for some obscure reasons, dglGetEdge always returns NULL. Therefore this complicated enumeration of the edges... */
+    /* dglGetEdge is only supported with graphs version > 1. Therefore this complicated enumeration of the edges... */
     index = 0;
     G_message(_("Computing minimum spanning tree..."));
     G_percent_reset();
@@ -136,6 +138,7 @@
 	    Vect_list_append(tree_list, dglEdgeGet_Id(graph, perm[i].edge));
+    G_percent(index, index, 1);
     G_free(perm);
     uf_release(&uf);
     return edges;
Modified: grass/trunk/lib/vector/neta/utils.c
--- grass/trunk/lib/vector/neta/utils.c	2016-03-09 15:34:34 UTC (rev 68030)
+++ grass/trunk/lib/vector/neta/utils.c	2016-03-09 20:38:32 UTC (rev 68031)
@@ -141,8 +141,12 @@
 	    if (!Vect_cat_get(Cats, layer, &cat))
 		continue;
 	    Vect_get_line_nodes(In, i, &node, NULL);
-	    if (db_CatValArray_get_value_double(&vals, cat, &value) == DB_OK)
-		node_costs[node] = value * In->dgraph.cost_multip;
+	    if (db_CatValArray_get_value_double(&vals, cat, &value) == DB_OK) {
+		if (value < 0)
+		    node_costs[node] = -1;
+		else
+		    node_costs[node] = value * In->dgraph.cost_multip;
