[GRASS-SVN] r68047 - in grass-addons/grass7: . models
Sat Mar 12 10:32:27 PST 2016
Author: martinl
Date: 2016-03-12 10:32:27 -0800 (Sat, 12 Mar 2016)
New Revision: 68047
Added:
   grass-addons/grass7/models/
   grass-addons/grass7/models/model_modis.gxm
re-enable user models in SVN, uploaded first model (done by Ludka Furkevicova)
Added: grass-addons/grass7/models/model_modis.gxm
--- grass-addons/grass7/models/model_modis.gxm	                        (rev 0)
+++ grass-addons/grass7/models/model_modis.gxm	2016-03-12 18:32:27 UTC (rev 68047)
@@ -0,0 +1,63 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE gxm SYSTEM "grass-gxm.dtd">
+<gxm>
+    <window pos="220,113" size="640,465" />
+    <properties>
+        <name>model</name>
+        <description>Script generated by wxGUI Graphical Modeler.</description>
+        <author>ludka</author>
+        <flag name="overwrite" />
+    </properties>
+    <variables>
+        <variable name="ndvi" type="string">
+            <value>original</value>
+            <description>Suffix for original data</description>
+        </variable>
+    </variables>
+    <loop id="1" pos="275,55" size="444,40">
+        <condition>map in ['MODIS_NDVI_2008049', 'MODIS_NDVI_2008145', 'MODIS_NDVI_2008241', 'MODIS_NDVI_2008305']</condition>
+        <item>2</item>
+        <item>3</item>
+        <item>4</item>
+    </loop>
+    <action id="2" name="g.rename" pos="275,125" size="125,50">
+        <task name="g.rename">
+            <parameter name="raster">
+                <value>%map,%map.%ndvi</value>
+            </parameter>
+        </task>
+    </action>
+    <action id="3" name="r.mapcalc" pos="275,200" size="125,50">
+        <task name="r.mapcalc">
+            <parameter name="expression">
+                <value>%map = %map.%ndvi * 0.0001</value>
+            </parameter>
+        </task>
+    </action>
+    <action id="4" name="r.colors" pos="275,270" size="125,50">
+        <task name="r.colors">
+            <parameter name="map">
+                <value>%map</value>
+            </parameter>
+            <parameter name="color">
+                <value>ndvi</value>
+            </parameter>
+        </task>
+    </action>
+    <data pos="505,125" size="175,50">
+        <data-parameter prompt="raster">
+        </data-parameter>
+        <relation dir="from" id="2" name="raster">
+        </relation>
+    </data>
+    <data pos="510,270" size="175,50">
+        </data-parameter>
+        <relation dir="from" id="4" name="map">
+        </relation>
+    </data>
+</gxm>
Property changes on: grass-addons/grass7/models/model_modis.gxm
___________________________________________________________________
Added: svn:mime-type
   + text/xml
Added: svn:eol-style
   + native
