[GRASS-SVN] r68064 - grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge
svn_grass at osgeo.org
Tue Mar 15 08:00:21 PDT 2016
Author: Giulia
Date: 2016-03-15 08:00:20 -0700 (Tue, 15 Mar 2016)
New Revision: 68064
grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
r.green: set the pixel area based on the resolution in meter
Modified: grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py
--- grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py 2016-03-15 10:56:34 UTC (rev 68063)
+++ grass-addons/grass7/raster/r.green/r.green.hydro/r.green.hydro.discharge/r.green.hydro.discharge.py 2016-03-15 15:00:20 UTC (rev 68064)
@@ -94,7 +94,7 @@
#% type: string
#% key_desc: name
#% description: Name of raster map with minimum flow along the river [m3/s]
-#% required: yes
+#% required: no
#%end
#%option G_OPT_R_OUTPUT
#% key: a_river
@@ -195,7 +195,7 @@
the accumulation map and the new streams
pid = os.getpid()
- info = gcore.parse_command('g.region', flags='pg')
+ info = gcore.parse_command('g.region', flags='pgm')
area_px = float(info['nsres'])*float(info['ewres'])
tmp_stream = 'tmprgreen_%i_stream' % pid
tmp_tmp_stream = 'tmprgreen_%i_tmpstream' % pid
@@ -219,7 +219,7 @@
""" Compute the discharge along the river given the specific discharge
pid = os.getpid()
q_cum = "tmprgreen_%i_q_cum" % pid
gcore.run_command('r.watershed',
